Old 10th August 2009, 14:08   #256
archat68's Avatar
Thanked: 642 Times
Originally Posted by gopinathann View Post
Thanks for sharing it. I have already used M-seal in my Numberplate light to prevent water. Next I am trying to create flexible LED strips.
For that you can use the flexible transparent pipes that are available with the plumbers. But these are not of good quality - tends to turn yellow after sometime.
archat68 is offline
Old 14th August 2009, 10:49   #257
benbsb29's Avatar
Thanked: 14,220 Times
LEDs on a circuit board
Thanks to all the suggestions and encouragement on this thread for this idea. I finally replaced the blue LEDs which served as the cabin light in my car with white ones. These are mounted on a dotted circuit board, and replace the existing ble LEDs which were mounted on a piece of cardboard.. a rather crude setup.
Here are some pics of the final setup.
Benny's first DIY : LEDs on an Ikon-img_5743.jpg
Benny's first DIY : LEDs on an Ikon-img_5744.jpg
Benny's first DIY : LEDs on an Ikon-img_5745.jpg
benbsb29 is offline
Old 14th August 2009, 12:34   #258
Thanked: 4,910 Times
looks nice. Seems like you could have added a lot more
how does it light up the cabin ?
greenhorn is offline
Old 14th August 2009, 15:15   #259
benbsb29's Avatar
I surely could have, but decided to try out how good this is for the time being. The cabin light is at the front of the car, and so there is good illumination at the front portion of the car. The rear is barely lit, but that was also the case earlier.
benbsb29 is offline
Old 14th August 2009, 16:46   #260
I'll probably have to do my LED's all over again, since the rear and side of my car is being replaced due to a recent accident :(
Old 14th August 2009, 17:49   #261
benbsb29's Avatar
OT : What happened? You could PM me with the details.
benbsb29 is offline
Old 24th August 2009, 00:24   #262
benbsb29's Avatar
I used the method mentioned by Greenhorn on this thread to fabricate an adapter to connect the LED setup in my car's boot to the existing bulb holder of the bootlamp. Worked like a charm, and the best part is its more secure then loosely connecting the wires to the holder as i was doing earlier. Most importantly, it eliminates the need for cutting the original wires.
Thanks Greenhorn, that was brilliant!
benbsb29 is offline
Old 7th September 2009, 22:38   #263
benbsb29's Avatar
I tried to go the LED way on the backlit lighting for the power switches on my car. With no real idea how to begin and in constant fear whether i would end up breaking anything, i managed to get to the final frontier and this was what i found.
Benny's first DIY : LEDs on an Ikon-300820092713.jpg
Benny's first DIY : LEDs on an Ikon-300820092714.jpg
This LED connected to a resistor emits the green light for the backlit lighting. Since it looked fragile, and also since i wasnt sure about the size of the LED, i decided to leave it as it is.
P.S. : The beautiful snaps are thanks to lack of a macro mode on my mobile cam, since i didnt have access to my digicam. Kindly adjust.
benbsb29 is offline
Old 8th September 2009, 10:43   #264
condor's Avatar
Thanked: 16,902 Times
Benny, no macro ? No Problem. Shoot regular, but crop the pic.
Now, pls re-post .. will really help see this more clearly. (even if you have to re-open)
condor is offline
Old 8th September 2009, 21:26   #265
benbsb29's Avatar
I agree with the cropping part. Too lazy to think of doing it again.
Thinking of doing the speedo console next. Let me see.
benbsb29 is offline
Old 14th September 2009, 13:34   #266
condor's Avatar
LED-ing the Sumo
BadboyScad, Benny & Greenhorn : thank you !. You guys have made this so simple that I was able to finish this in one sitting, even though it has been years since I last held a soldering iron.
So here it is :
5 rows of 3 LED's each.
5mm LED's, rated at 3.2 -3.4V
100 ohm resistor to limit the current.
Set-up, after soldering:
Benny's first DIY : LEDs on an Ikon-leds-mounted.jpg
Stock lighting :
Benny's first DIY : LEDs on an Ikon-stock-light.jpg
And the final look : (shot with a SE K810i, no post-processing)
Benny's first DIY : LEDs on an Ikon-light-er-up.jpg
The lighting is gooood .. much better than the current stock lights. Next step : Will try about 18 LED's (3x6).
Front row lighting yet to be done.
condor is offline
Old 14th September 2009, 14:23   #267
benbsb29's Avatar
Congrats Condor! Job well done.
How many sets of cabin lights does the Sumo have?
benbsb29 is offline
Old 14th September 2009, 15:15   #268
condor's Avatar
@Benny : Two stock roof mounted lights : front & middle row. Have been planning the third row (near rear door). Once done, I think this will be one welll illuminated truck.
condor is offline
Old 14th September 2009, 15:20   #269
any chance of coloured and possibly blinking LED's for a car-o-bar
I've been toying with the idea of putting up an LED VU meter
Old 14th September 2009, 15:41   #270
condor's Avatar
@Benny, that one's for you ;-)
condor is offline
