![]() | #16 | |
BHPian ![]() Join Date: Mar 2008 Location: Southern Calif.
Thanked: 1,750 Times
| ![]() Quote:
https://www.ecosoch.com/work/ "Really thick cables" is a very generic term. Depending on the fuse/breakers you use and the max amperage you install and draw, you will need to have adequate cables. Going overboard is expensive as copper is expensive. As you are dealing with high voltages and lot of amps, you cannot cut corners either. So, no experimentation. Last edited by GutsyGibbon : 18th December 2019 at 04:58. | |
![]() | #17 |
BHPian ![]() Join Date: May 2015 Location: Pune
Thanked: 28 Times
| ![]() As an afterthought, you may also want to make provision for a wifi AP / router to help with connected vehicle technologies. There are also some videos available on YouTube which you can refer for "future proofing your home / office". You do get some good knowledge. Since every individual situation is unique, you will need to make a decision. Gathering this information from various sources will help you make informed decisions. |
![]() | #18 | |
BHPian Join Date: Feb 2015 Location: Pune
Thanked: 340 Times
| ![]() Quote:
So let's assume that in your state, bunglows normally get a 10kw connection by default. You will need a 10+11kw connection. Also when you ask your electrician to setup a 11kW 3-phase connection, he will also ask what is the intended amps that is expected to be drawn. Just ask for 40 amps, it should be enough. You should be able to get anywhere between 46-64 km/hr charging rate.(And if you need to go lower, set the limit option in the car). Thus you will be able to charge your car overnight and will help charge multiple cars on alternate nights with just one socket connection. | |
![]() | #19 |
BHPian ![]() Join Date: Dec 2014 Location: Chennai
Thanked: 786 Times
| ![]() I just did the basic wiring for my kona fast charger. Used 10 sq mm wiring culminating in a 40 amp breaker. However, my earthing isnt upto the mark so i will need to address that issue before Hyundai is willing to move any further. Having a new 6 foot copper pole dropped to address this. |
![]() | #20 | |
BHPian Join Date: Oct 2013 Location: Bangalore
Thanked: 201 Times
| ![]() Quote:
https://www.team-bhp.com/forum/offic...-review-9.html (Hyundai Kona : Official Review) I hope you find these useful. Advice provided in the preceding posts are an accurate reflection of the process. My house has a 5KW domestic connection and using the level 2 charger was causing lots of tripping and malfunction. I have got an additional 3phase connection with a sanctioned load of 8Kw under the LT-6(c) scheme of BESCOM - that is for EV charging stations and this works fine. It allows a draw of upto 40 amps. In Bangalore, the BESCOM guys are slowly getting used to these applications and installations and it should not be too difficult to get this done. | |
![]() | #21 |
Team-BHP Support ![]() ![]() | ![]() Team, Am doing up the driveways and setting up a couple of EV chargers on both sides. I want to make them future-proof. What would be the best practices now? • 3 phase line for power? • 15 / 16 ampere socket? • Should be thick low gauge wire (10 gauge???). • Different ELCB for it. Anything else? This will be a one-time install for the next 20 - 30 years. Thanks! |
![]() | #22 |
Newbie Join Date: Oct 2008 Location: Gurgaon
| ![]() Most EV AC chargers (Delta etc) are single phase. In my installation a 40A ELCB is put after the meter and a 40A MCB just before the charger. The cable used in 10mm three core. The distance is about 40 meters. As the charger is about 72 KW, I think the cable has to be 40A capable. I think 8mm copper (to minimise losses) is a goo start. 10mm or larger if the distance is 20 to 50m. |
![]() | #23 | |
Newbie Join Date: Nov 2020 Location: Chennai
Thanked: 30 Times
| ![]() Quote:
Hi .. -Yes .. 3 phase is mandatory -You can have an additional 15amps socket. I have one fitted next to my wall charger. I can use it incase the wall charger runs into trouble. It also helps for vacuuming. -For a wall charger, Wire should be 10 Sq mm 3 core. This is the wire that runs from your Meter to the wall charger spot. If the wall charger spot is more than 30meters from your EB meter, the wire should be 16 sq mm (armored cable) .. -For a 15amps socket, 2.5 sq mm if distance is within 30 meters, 4sqmm if distance is more than that. -A two pole MCB should be enough. However, I was advised by my apartment electricians to add an ELCB. They said it gives better control during fluctuations and reduces hazards. | |
![]() | #24 |
BHPian ![]() | ![]() |
![]() | #25 | |
BHPian ![]() Join Date: Nov 2006 Location: CJB-Driel
Thanked: 430 Times
| ![]() Quote:
At office here in The Netherlands, we have something simple like this, which is just a basic 3kW (230V, 15A) plug socket with cover at parking location, with a switch inside office to turn it ON/OFF. ![]() because most of the colleague's cars are parked for atleast 7-8 hours and no need to charge with Type2 (mostly 11kW). At home, we have a Tesla wall charger (https://shop.tesla.com/product/wall-...or?tesref=true). Probably it will take some time for Tesla to launch this in India. In India, I think ABB has a product line up called terra AC wallbox. It is basically a type 2 AC charger which can support upto 1-phase 7.2kW/32A or 3-phase 22kW/32A depending upon your input. Almost all current and to be coming EVs in the future should support type 2. This is faster than the normal plug point and has all bells and whistles like energy monitoring, networking possibilities for future integration with your home network. Most importantly it has all safety built in. You need to feed the requested input current and should be good to go. I would suggest a 3-phase 22kW setup. ![]() https://new.abb.com/ev-charging/terra-ac-wallbox If you are going to have more than 1 EV in your drive way (Of course, who is going to review all the newer EVs coming out in Indian market ![]() Last edited by carthick1000 : 11th February 2021 at 02:05. | |
![]() | #26 |
Thanked: 30 Times
![]() | #27 | |
BHPian ![]() | ![]() Quote:
For a 10 years horizon, not sure about power rating. The charger controller would evolve several generations in just 10 years. You may opt for a separate connection for charger in a few years, depending on the way government regulates EV charging. The high "approved load" on household connection to feed the charger would increase fixed charges and even higher unit rates in the monthly power bill. Please check with the utility on this. Spending on very high capacity charging at home is required only for specific cases where user wants a full charge within hour or two. To keep your installation future ready and to save the hassle of reinstallation, i think investing in higher capacity cable would make sense. Limited by the fact that home chargers are not required to be very fast, as the car would be parked overnight. With the basic infrastructure in place, upgrading to charging solutions would be like to change the wall mounted charger module and a breaker at supply end. | |
