Old 7th February 2013, 15:17   #11356
tsk1979's Avatar
Thanked: 23,487 Times
Re: The DSLR Thread
Originally Posted by nilanjanray View Post
Yes, I did some research before downloading CNX2.
So here is the workflow I am favouring:
1. Make WB, exposure, local adjustments (which I seldom do) etc. adjustments in Capture NX2.
2. Save as a TIFF file
3. Make further adjustments - if required - in GIMP
I don't think I will buy CNX2, will see if I can get along with ViewNX2.
Try Rawtherapee first.
GIMP native TIFF support is not very good(for example EXIF is lost).
That way you can simply save JPEG and then work with GIMP if needed. Most of the times, you can create a good enough image out of RT. Only for heavy noise you will need to use GMIC or wavelet denoise.
tsk1979 is offline
Old 7th February 2013, 22:22   #11357
ampere's Avatar
Thanked: 13,613 Times
Re: The DSLR Thread
What is Nikon's native s/w which one gets when one buys a Nikon.
Something equivalent to Canon DPP. That should also be good to convert RAW to TIFF to reproduce the colours before extra post processing.
ampere is offline
Old 8th February 2013, 09:31   #11358
tsk1979's Avatar
Re: The DSLR Thread
View NX2. Its a pretty useless non intutive software which does not even do levels adjustment.
tsk1979 is offline
Old 8th February 2013, 09:48   #11359
MindSpeeDs's Avatar
Thanked: 84 Times
Re: The DSLR Thread
Originally Posted by athanedar View Post
What do you think will the problem be with Cameta? Will they send me a preowned or refurbished camera?
I checked reviews of Cameta and found it to be alright. I also checked other deals for example www.Costco.com ( very reliable wholesale retailer with 3 month return policy) and I am getting almost the same deal. It looks like Nikon is giving 200$ discount on the D3200 as limited time promotion.
I have purchased quite a few times from Cameta (directly and also through Amazon) with absolutely no issue. They are pretty reliable.
MindSpeeDs is offline
Old 8th February 2013, 10:17   #11360
ampere's Avatar
Re: The DSLR Thread
Wow! Canon DPP is much better in that aspect. I just use to covert it to TIFF without any adjustment. And then follow it up with all changes after I take the TIFF to Aperture.
ampere is offline
Old 8th February 2013, 10:40   #11361
Samurai's Avatar
Thanked: 49,816 Times
Re: The DSLR Thread
I use the free DNG converter to convert OM-D raw files to DNG. Only then I can open in CS4.
Samurai is offline
Old 11th February 2013, 02:21   #11362
govigov's Avatar
Thanked: 1,222 Times
Re: The DSLR Thread
live time on omd. super useful.
govigov is offline
Old 11th February 2013, 16:20   #11363
rkbharat's Avatar
Thanked: 724 Times
Re: The DSLR Thread
With Capture NX2, you don't need any other tool , unless you are into heavy post processing and layers.
Try its selective adjustments, and selection tools, very helpful. I really love the feature of applying multiple changes on same selection, very helpful in Landscape shots
View NX is good for nothing other then a file expolrer, exif viewer and Raw conversion, though I still use it for managing, ranking, labelling my images
rkbharat is offline
Old 11th February 2013, 22:34   #11364
nilanjanray's Avatar
Thanked: 2,946 Times
Yes I am liking it. Much simpler than GIMP, and the colours are accurate.
Any idea where to buy it from cheaply? The Nikon India site says 11k! Perhaps download the key from US where it is much cheaper?
nilanjanray is offline
Old 13th February 2013, 12:43   #11365
mpksuhas's Avatar
Thanked: 8,407 Times
Re: The DSLR Thread
I own a Nikon D7000 with kit lens (55-105). I am planning of getting a telephoto lens, on checking for list of Nikkor lenses came across these two -
Fx format - 70 - 300- MRP Rs: 32450 http://www.nikon.co.in/en_IN/product...tLink=gp11zkzb FX Format/AF-S VR Zoom-Nikkor 70-300mm f4.5-5.6G
Dx format - 55-300 -MRP Rs: 21450 http://www.nikon.co.in/en_IN/product...tLink=gp11zkz8 DX Format AF-S DX NIKKOR 55-300mm f4.5-5.6G ED
Iam inclided towards 70-300 since the zoom range is less and hence pictures may be sharper. However its almost 50 % expensive than 55-300 and both have same F -stops. However first is Fx and second is Dx format lens, what is the difference between these?
Also on higher budget there is Dx format 18-300 - MRP Rs 73000 http://www.nikon.co.in/en_IN/product...tLink=gp11zkz8 DX Format 18-300mm f3.5- 5.6G
And Fx format 28- 300 with MRP Rs: 74000 http://www.nikon.co.in/en_IN/product...tLink=gp11zkzb FX Format 28-300mm f3.5-5.6G
These both are above my budget as of now, however will it be worth the money since the F-stop values are 3.5 compared to 4.5 for first two lenses.
mpksuhas is offline
Old 13th February 2013, 14:19   #11366
StarScream's Avatar
Thanked: 667 Times
Re: The DSLR Thread
Fx format - 70 - 300- MRP Rs: 32450 http://www.nikon.co.in/en_IN/product_details.page?DCRPath=templatedata/en_IN/saleable_product_information/data/Nikkor Lenses/FX Format/Zoom/Telephoto Zoom/AF-S VR Zoom-Nikkor 70-300mm f4.5-5.6G IF-ED.xml&CategoryID=gp11zkyu&currentTab=gp11zkz5&cur rentLink=gp11zkzb FX Format/AF-S VR Zoom-Nikkor 70-300mm f4.5-5.6G
Dx format - 55-300 -MRP Rs: 21450 http://www.nikon.co.in/en_IN/product_details.page?DCRPath=templatedata/en_IN/saleable_product_information/data/Nikkor Lenses/DX Format/Zoom/AF-S DX NIKKOR 55-300mm f4.5-5.6G ED VR.xml&CategoryID=gp11zkyu&currentTab=gp11zkz4&cur rentLink=gp11zkz8 DX Format AF-S DX NIKKOR 55-300mm f4.5-5.6G ED
Also on higher budget there is Dx format 18-300 - MRP Rs 73000 http://www.nikon.co.in/en_IN/product_details.page?DCRPath=templatedata/en_IN/saleable_product_information/data/Nikkor Lenses/DX Format/Zoom/AFS DX NIKKOR 18300mm f3556G ED VR.xml&CategoryID=gp11zkyu&currentTab=gp11zkz4&cur rentLink=gp11zkz8 DX Format 18-300mm f3.5- 5.6G
And Fx format 28- 300 with MRP Rs: 74000 http://www.nikon.co.in/en_IN/product_details.page?DCRPath=templatedata/en_IN/saleable_product_information/data/Nikkor Lenses/FX Format/Zoom/Normal Zoom/AF-S NIKKOR 28-300mm f3.5-5.6G ED VR.xml&CategoryID=gp11zkyu&currentTab=gp11zkz5&cur rentLink=gp11zkzb FX Format 28-300mm f3.5-5.6G
First up the 28-300 makes no sense on a D7000. You'll get an effective focal length of 50mm to 450mm.
If you get the 18-300 DX, you don't need your kit lens because you'll be duplicating focal lengths. The 18-300 or the 18-200 VR are great do-it-all travel lenses on DX.
However, if you don't mind changing lenses and want a dedicated telephoto, I'd choose the 70-300 VR for a couple of reasons: The DX crop factor gives FX telephoto's extra reach and that makes the 70-300 a 105-450; If you ever shift to full frame the 70-300 will remain a valid lens; it is much better built than the 55-300 DX and I'd assume outperforms it as well.
Also, about f-stops. don't be fooled by the 3.5 starting number. For the operative 70-300 part, the 18-300 may be the same or actually slower, compared with the 70-300 FX.
StarScream is offline
Old 13th February 2013, 15:05   #11367
Rachit.K.Dogra's Avatar
Thanked: 1,891 Times
Re: The DSLR Thread
Guys just need one suggestion. I have a D5100 with the kit lense 18-55mm. I have used this camera for almost an year now. Since the time I have bought this camera I wanted a prime lense. Couldnt buy it then and still cannot buy a new one now. But if I exchange my 18-55 for the 35mm prime I might just be able to manage that. I am still contemplating it and have not decided on it yet. I will be having this lense only as of now and would gradually buy a 55-300 sometime later.
Can you guys share what you think on this? Should I keep the 18-55 and only get 35 mm when I have another telephoto or It is will be worth it to swap the 18-55 for 35 mm and later add the 55-300.
What kind of photography I do? Well some portraits of my family and my car, landscape and some general street photography.
Rachit
Rachit.K.Dogra is offline
Old 13th February 2013, 15:14   #11368
arvind71181's Avatar
Thanked: 1,788 Times
Re: The DSLR Thread
My friend (aravind84 on this forum) owned both 55-300 and 70-300 at different points of time and he says that the clarity with the 70-300 is much better. He also uses the D7000. So I guess the 70-300 would be a better buy if the cost is not a constraint for you
arvind71181 is offline
Old 13th February 2013, 15:15   #11369
mobike008's Avatar
Thanked: 17,125 Times
Re: The DSLR Thread
Originally Posted by Rachit.K.Dogra View Post
Guys just need one suggestion. I have a D5100 with the kit lense 18-55mm. I have used this camera for almost an year now. Since the time I have bought this camera I wanted a prime lense. Couldnt buy it then and still cannot buy a new one now. But if I exchange my 18-55 for the 35mm prime I might just be able to manage that. What kind of photography I do? Well some portraits of my family and my car, landscape and some general street photography.
I too have a D5100 and was in same dilemma when I bought my camera last October
A prime lens is a must in everyone's kit. The results of a prime lens are truly wonderful. The sharpness and bokeh is just perfect for potraits and street photography. It also shines in low light photography too due to its large F stop (F1.8)
Btw, I too tried selling my brand new 18-55mm and you wont beileve it. There were no buyers for it. Everyone wants to upgrade...lol!..So I just gifted those brand new lens to my BIL
You might as well keep it if you too dont find any buyers for the kit lens and just buy the prime lens.
mobike008 is offline
Old 13th February 2013, 16:01   #11370
Re: The DSLR Thread
Thank you so much for the advice. Even I am not very optimistic of finding any buyers for the 18-55. I would try to exchange it in the shop for 35mm. The downside being I will not be getting a decent price for it but lets see. Will try to negotiate.
