Old 25th September 2013, 23:36   #12181
SPARKled's Avatar
Thanked: 664 Times
Re: The DSLR Thread
Originally Posted by nilanjanray View Post
True. But the buffer sucks in RAW, even with a ExtremePro card.
With the D800e the cost of reach goes up exponentially.
Btw, here's one with the venerable D90:
Actually with the AA filter gone from the D7100, you can get pretty sharp JPEGs SOOC. Also the buffer is poor only for RAW, the JPEG buffer is quite decent. So unless you absolutely need fast 6-7 FPS RAW burst modes all the time, the D7100 buffer should suffice.
SPARKled is offline
Old 26th September 2013, 02:06   #12182
govigov's Avatar
Thanked: 1,222 Times
Re: The DSLR Thread
Thank you, @amit. I think I will shell out 1200 and get it cleaned from a centre. How long does it take? Can i like wait and collect it back after cleaning from the centre?
@all, in between EOS 6D vs 7D vs 70D, can the 60D be considered for the sheer VFM factor? Apart from the 19 cross type AF points and slightly better FPS, I dont think there is any other reason to choose other camera's.
How is the low light performance of 60D ?
govigov is offline
Old 26th September 2013, 08:12   #12183
sridhu's Avatar
Thanked: 2,756 Times
You will be disappointed.
Far better to learn how to do it yourself. Check out Thom Hogan's site. Good info on how to do it.
sridhu is offline
Old 26th September 2013, 09:35   #12184
R2D2's Avatar
Thanked: 5,857 Times
That's fine if you are okay to take a chance of messing up the sensor. A part that's good fraction of the price of a camera. Not recommended for most people. Take it to the service centre and get it cleaned. They will also perform other checks on the body.
R2D2 is offline
Old 26th September 2013, 12:07   #12185
manim's Avatar
Thanked: 925 Times
Re: The DSLR Thread
I own a Nikon D3100.
The kit lens is damaged (had taken many hard knocks).
I recently bought a prime-lens 'Nikon 35mm f/1.8' and am satisfied with it (from Flipkart).
I was hoping to have this as my only lens.
Now I am planning to visit the TajMahal, Agra for a (maybe) once-in-a-lifetime holiday.
For photography of monuments like the Taj, will the 'normal' focal length be okay, or will a wide-angle+zoom be better?
My heart wants the 'Nikon 18-105 mm' to replace my damaged 18-55 mm kit lens.
My brain says not to waste money!
This is listed in Flipkart for Rs.19.300.
(This lens is also sold as a kit lens with some packages with bodies).
Though I read a lot of reviews of this lens on the net, hope to get some advice on here please!
manim is offline
Old 26th September 2013, 12:12   #12186
gr8guzzler's Avatar
Thanked: 87 Times
Re: The DSLR Thread
A wide angle is a must if you want to capture the beauty of Taj. Why not rent one as it is just a one time need?
gr8guzzler is offline
Old 26th September 2013, 15:19   #12187
h@r$h@l's Avatar
Thanked: 743 Times
Re: The DSLR Thread
A cousin is looking for a wide angle lens for a one time use. can you pls guide as to where in BBY can he rent one?
h@r$h@l is offline
Old 26th September 2013, 15:41   #12188
gr8guzzler's Avatar
Thanked: 87 Times
Re: The DSLR Thread
www.accordequips.com
Usually Canon lenses are easily available, Nikon are hard to get.
Old 26th September 2013, 17:43   #12189
Thanked: 11 Times
Hello guys
I have a question for all my seniors.
I have Canon 550d with kit lens(18-55mm). After clicking about 10k pics i want to upgrade to Canon 15-85mm bcoz of its focal length. I like clicking landscapes, monuments and macro (flowers, bees and butterflies) and occasional portraits.
Now the question is what should i expect from 15-85mm lens in terms of image quality ? (I have a decent copy of the kit lens)
Would the macro pictures taken by 15-85mm be better than 18-55mm because of extra zoom of 15-85mm. And what about the magnification ratio of both the lenses ?
I searched regarding last query on net but could not get any satisfactory answer.
Thankyou in advance
Rajvir Singh Bains
Rajvir Bains is offline
Old 29th September 2013, 03:20   #12190
govigov's Avatar
Re: The DSLR Thread
I took it to camera scan, authorized canon service center, they said, they have to send it to Bangalore for cleaning. The cost is 2900/- plus additional if any parts have to changed. Takes 15 days minimum.
This is to be sold after cleaning along with 18-55 & 55-250, Cash to be used for body upgrade. Is the EOS 60d worth it?
govigov is offline
Old 29th September 2013, 14:38   #12191
clevermax's Avatar
Thanked: 2,902 Times
How to recycle Silica gel in 15 minutes
Found a way to recycle silica gel that you normally use to preserve photography equipments in dry boxes. This is a quick and easy way.
Things needed:
1) Hair dryer
2) One from a pair of old socks
Time required is just 15-20 minutes, it can dry up to around 200 grams of Silica gel.
If you go the microwave way, the crystals may break up into tiny pieces owing to quick heating.
If you use the bulb method, it will take a lot of time.
The set-up:
Drop the crystals into the socks through this, it is easier. (If your Hair Dryer has a removable jet like this)
Run the dryer in its highest setting for a minute or two, then switch to lower speed and let it run. Give a blast of hottest air by switching to top speed every 3 minutes or so. Repeat for about 15 minutes.
In action:
And the before and after photos:
Before:
After:
Let the crystals cool down a bit and put it back into the dry-box.
CAUTION: Hair dryer may get overheated if the hot air can't escape easily through the fabric. Do not use thick fabric. Some hair dryers have overheating protection and they may go into cut-off during this exercise but don't worry, the relay will be closed once the temperature falls down.
EDIT: It is better to repeat the whole exercise once more in two hours after the crystals settle down (Initially the dryness of crystals will not be too deep into the crystals.)
clevermax is offline
Old 30th September 2013, 07:44   #12192
nileshch's Avatar
Thanked: 481 Times
The latest 18-55mm IS has a magnification of 0.34x (is that the one you have?) and the 15-85mm IS has a magnification of 0.21x so you might lose out a bit. But given that you are looking for a general purpose lens, I'd recommend you go for the 15-85mm. It is superior in quality overall and the photos are much sharper.
Thanks @clevermax, this is a great tip! I actually have a bag of used silica gel that I was about to throw out.
nileshch is offline
Old 30th September 2013, 08:11   #12193
Rudra Sen's Avatar
Thanked: 6,879 Times
Re: How to recycle Silica gel in 15 minutes
This is a new way no doubt but easiest way is this:
> Take a roti making tawa and place it on lower gas flame.
> place moisture loaded silica gel once the tawa is slightly hot
> Use a fork or spoon to move those crystals around (as you normally do while cooking )
> Switch off stove when the crystals are blue.
> Leave it as it is for a while. Residual heat from tawa will make those crystals deeper blue.
Rudra Sen is offline
Old 30th September 2013, 10:28   #12194
Thanked: 3,029 Times
Or if you have an OTG use it to heat the crystals and they will loose all their moisture.
Aroy is offline
Old 30th September 2013, 10:50   #12195
R2D2's Avatar
Re: The DSLR Thread
Talking about silica gel, you guys may be aware of this. But just thought of sharing here. Indicating SG has a known carcinogen - Cobalt Chloride.
http://en.wikipedia.org/wiki/Silica_gel#Hazards (read section on humidity indicator)
http://en.wikipedia.org/wiki/Cobalt_poisoning
I buy fresh SG for e.g. from here:
http://www.ebay.in/itm/Silica-Gel-De...item43be2fdbb2
Old SG is discarded.
R2D2 is offline
