Old 28th January 2009, 12:43   #466
devarshi84's Avatar
Thanked: 213 Times
you are still comparing interfaces.
devarshi84 is offline
Old 28th January 2009, 12:47   #467
vikram_d's Avatar
Thanked: 1,189 Times
Those are not interface results. They are results of actual data written on the disk. The interface speed of the Raptor is 3Gbps where as in reality it only writes at 135mbps.
vikram_d is offline
Old 28th January 2009, 12:49   #468
Thanked: 311 Times
Because interfaces cannot be bypassed! Any kind of storage device or RAM will HAVE to go through an interface, so it is very relevant what the interface permits. Then comes the technology of the drive itself - whether it can utilize the interface to full potential, or whether a new technology is required.
Strangely, even though USB 2.0 supports 480 Mbps, no flash drive or HDD has been able to offer that kind of transfer rate. How come? Would appreciate it if someone can throw light on this.
anupmathur is offline
Old 28th January 2009, 13:01   #469
anujmishra's Avatar
Thanked: 529 Times
Originally Posted by vikram_d View Post
What is for XP and not for Vista.
Vista already has a ReadyBoost feature built in where as XP does not.
Some reference material
ReadyBoost - Wikipedia, the free encyclopedia
Explore the features: Windows ReadyBoost
Edit: The fast SATA HDD is a Western Digital Raptor at 135Mbps and the fastest USB drive is a Corsair Flash Voyager GT at 33.8Mbps. The results are from real world tests.
I have Dell Inspiron 6400 laptop with Windows Vista Home Premium installed in it. It has only 1 GB of RAM. But now I am using 4GB pen drive along with ReadyBoost feature in Vista. The result is very encouraging. It actually makes laptop fast compared to 1GB performance. I use certain heavy softwares and context switching along with all vista graphics is really not bothering me.
anujmishra is offline
Old 28th January 2009, 19:20   #470
vivekiny2k's Avatar
Thanked: 212 Times
I applied SP1 again, after computer goes to sleep and wakes up, the network and sharing center freezes. the network is lost.
any clues? any other way to get to my network and try to start it?
vivekiny2k is offline
Old 28th January 2009, 20:12   #471
gendarmee's Avatar
Thanked: 32 Times
Vista problem: After,When the machine is left idle and the screensaver get activated, the sound stops. Starts working again after a 10 second job of pressing the power button, turning off the laptop turning it on and logging in.
Can it be done away with?
gendarmee is offline
Old 28th January 2009, 20:26   #472
Thad E Ginathom's Avatar
Thanked: 30,033 Times
I'm about to install Win XP SP3, but a little nervous --- can someone confirm that the XP SP3 disasters were on on non-Intel machines?
Thad E Ginathom is offline
Old 28th January 2009, 21:38   #473
abhibh's Avatar
Thanked: 39 Times
no disasters using SP3 on Athlon X2 for months now but i prefer SP2.
abhibh is offline
Old 29th January 2009, 09:03   #474
aaggoswami's Avatar
Thanked: 3,000 Times
@Vikram_D:
The copy in genuine of vita basic. Bought it for around 4.5K.
Do you think I was cheated here ?
Also now even Window 7 beta is not getting installed.
@devarshi84:
3GBPS is on paper. Max I saw on my 7200.10 250gb was 130 mbps.
NO. I am running SP3 XP on Athlon X2 for quite some time now. No errors. And installing SP3 wont slow the machine down.
aaggoswami is offline
Old 29th January 2009, 11:04   #475
vikram_d's Avatar
Originally Posted by aaggoswami View Post
@Vikram_D:
If it came with proper packaging and genuine license then you were not cheated. Did you buy an OEM version by any chance? An OEM version is generally shipped in a plain brown card board box or just the DVD and licenses shrink wrapped.
Also there is a tool to check if your PC is compatible with Vista. It is available on the Microsoft site. Just download it and run it. It will tell what hardware will and will not work with Vista on your PC.
vikram_d is offline
Old 29th January 2009, 21:26   #476
aaggoswami's Avatar
Yes, I am having a genuine copy.
That stuff says I can run Vista, but in reality I am not able to do.
Also Windows Server 2008 ( based on Kernel of Vista ) is also not getting installed. Something wrong with my machine it seems.
Old 29th January 2009, 22:26   #477
vikram_d's Avatar
Seems like a hardware issue to me also. At what stage does the installation hang?
vikram_d is offline
Old 30th January 2009, 10:30   #478
grvanand's Avatar
@aaggoswami, Vista requires a bios update if your system is from a pre-vista era. Check up with the mobo supplier for the update.
grvanand is offline
Old 30th January 2009, 10:50   #479
aaggoswami's Avatar
Well, after the " Windows is loading files " the installation will hang. After repetitive trials, it will show first menu where we select language, etc. and then again the installation wont go ahead.
This is true for
1) Vista Basic
2) Server 2008 ( thanks to dream spark ).
3) Windows 7 Beta.
For the record, even Fedora 10 installation had this problem and it took me around 25 tirals to get the installation of Fedora 10 done. It did not work well. I dont know what is wrong.
Sometimes the installation will start but at around 50% or so, it will just hang up.
My motherboard is MSI K9N Neo V3 with nVidia 560 chipset ( MCP65 ). I go it changed around 4 months back. So I dont think this is actually BIOS issue. I have even flashed the BIOS.
Old 30th January 2009, 11:06   #480
vikram_d's Avatar
The biggest problem with Windows installation is that if it hangs you have no way of finding out what is causing it. Try scanning the HDD with Chkdsk and see if there are any errors on it.
vikram_d is offline
