City bumper to bumper driving takes more toll on the clutch. From what I have heard, your clutch starts wearing out when you have to half clutch it.
For example
1. Jams on flyover - I work around this problem by making it a rule that as long as the clutch is pressed even 1mm, I won't give any throttle input, and let her coast on idle. This minimizes the problem. I have seen people give throttle and clutch at the same time on flyover jams.
2. Steep hairpin turns uphill - Worst thing, esp in reverse. I have seen people wreck their clutches. I make it a rule, that if I have to reverse up a very sharp slope, and the engine will stall without clutch, I shift to 4L momentarily, and let has reverse up a little bit and then disengage 4L. Goes a big way in preserving clutch
So unless you are half pressing the clutch 4x4 or 4x2, it does not make a difference. The golden rule is never to half clutch. Infact, once in Manali, there was a huge jam on the road leading upto hot springs, instead of torturing the vehicle, we turned back. We did not go there. Like people avoid bad roads, I try and avoid stretches which require half clutching. Its with such careful driving that I have a safari which has done ladakh twice, rohtang pass countless number of times, and also gone on the Batal section(total torture), done jalori pass 2-3 times and yet does not rattle.
If you take care of your vehicle, and baby it regularly, you can use it to the full, and I won't call it abuse.
The only components of this safari which got terrain related wear and tear
1. Brake pads- I had to get them changed at 45K, if I was not doing so much mountain driving, they would have lasted me 20K more
2. Bushes - The achilles heel of this vehicle, probably the biggest design flaw in my opinion.
Rest, if you look at the ownership history and component failures, you have the 4x4 hubs failing within 4000kms. The warranty replaced hubs have lasted 40K and there are no issues, inspite of so much 4x4 driving.
Then the fuel temp sensor and injector circus everybody is familiar with. The hand primer pump, which I have used 2 times after it got replaced. Before that I had never touched it.
The radiator, which developed and evaporative leak. and last but not the least, the timing belt almost failure.
Except for the bushes, the only terrain related failure has been the skid plate, which I replaced at the first sign of rusting and tearing.
Even the wheel bearings gave way before my first ladakh trip. She had probably seen 2-3 spells of normal rain, no water fording.
Speaking of the clutch, Sudev's GV clutch lasted 120000kms. He has done official duty on Raid and storm multiple times, not to mention many trail driving trips. If I can get 40k more from this clutch(done 30K), I would be happy, and I do not think its going to fail anytime soon.
