The AC cooling fan does make a lot of noise and kick up quite a bit of dust, but it comes on only when you use the AC.
OK, a new one just cropped up!
The 52,500 km service was planned to be a routine job. However, the night before I hit the brakes at a speed of 120 kph to slow down to 80 kph and boy, what vibrations on the brake pedal! It's time to get the brake discs machined on a lathe.
The problem is I have rarely braked at those speeds, so maybe this problem's been around for a long time. I don't think Fiat is going to give me new discs in Extended Warranty.
Elegant has given me two options. Either leave the car for a full day so that the dics can be removed and sent to the lathe for machining (from FIE Patparganj to Karol Bagh) or replace my discs with machined discs from another car kept ready. The latter is obviously a no-no from my side.
Third option is to take it one of the numerous non-authorised guys. Planning to go to one recommended by Suman in Gurgaon.
52,500 km was a routine affair. The bad news is that cost of fuel filter has gone up from 1100-odd with tax to 1700-odd with tax.
Originally Posted by architect
(Post 2105843)
The AC cooling fan does make a lot of noise and kick up quite a bit of dust, but it comes on only when you use the AC. |
I noticed this some time back in a Friend's Palio MJD. The fan is so strong that it blows all the dust below the car to create a tornado like effect, strong enough to annoy the bystanders.
The Palio belongs to the Siena family. The first Siena that came to India(Yes the one which resembled a fish and had Turbocharged diesel) has overheating issues due to weak radiator fan, Fiat did a permanent fix by installing this fan. :)
Originally Posted by .anshuman
(Post 2106166)
The Palio belongs to the Siena family. The first Siena that came to India(Yes the one which resembled a fish and had Turbocharged diesel) has overheating issues due to weak radiator fan, Fiat did a permanent fix by installing this fan. :) |
Except when I climbed from Bir to Billing Top (some 600 - 700 metres) over 14 km without AC, I have never seen the temperature needle go anywhere close to half mark. Once the 'tornado' fan starts up on switching on the AC, the temperature settles down to quarter mark.
Let's hope disc machining happens fast and easy at Gurgaon tomorrow. :)
(Post 2106193)
Let's hope disc machining happens fast and easy at Gurgaon tomorrow. :) |
Please update the thread after the machining job. I have started feeling the brake Judder in my Elantra at triple digit speeds, i may also go in for a disc skimming job this week. Suman just got this job done in his Fiesta, his ownership thread might give you some good tips.
Where can one locate the vin number on a multijet . Is it embosed somewhere on the body frame.
(Post 2106251)
Please update the thread after the machining job. I have started feeling the brake Judder in my Elantra at triple digit speeds, i may also go in for a disc skimming job this week. Suman just got this job done in his Fiesta, his ownership thread might give you some good tips. |
Disc machining was done at the same place as Suman's Fiesta: Rakesh Automobile, near Atul Kataria Chowk. The guys there seem to be good and the actual lathe is in Sector 12, Ggn.
Vella that I am, I took a ride on the mechanic's scooter to drop and get the discs back.
The braking is much smoother and progressive now. The downside is that the brakes need to be pressed a little more for the same amount of braking effect, because the discs have become thinner. Maybe, the pads will have to be replaced soon (they have done 30,000 km and the disc is thinner too). I was carrying disc pads from Kashmiri Gate (for 500 bucks), but I was advised that they were not needed.
I finished the day with wheel alignment at Star Wheels which is practically next door to Rakesh Automobiles.
Thanks, Suman
da and GD sir.
Originally Posted by Ravi Yadav
(Post 2107472)
Where can one locate the vin number on a multijet . Is it embosed somewhere on the body frame. |
Open the Bonnet. The label is fixed to the body, just above the front grille, where the lever for opening the bonnet is located.
@architect
I have noticed the insides of a couple of my tyres having more tread wear than the outside. I have been regularly undergoing wheel alignment at an interval of about 7000-8000 km. Is it time to get the tyres fitted inside out? How do I know if I also have the "camber out" problem that you had faced?
PS. The much maligned GY-GPS2s have held firm without a single puncture till now, touchwood!
It is the camber issue most likely. Get it checked from a good independent tyre shop, but don't jump to the solution provided by him. If you've managed so far, you can manage for some more time.
Architect ,where can one locate the engine number on the multijet.
(Post 2127009)
Architect ,where can one locate the engine number on the multijet. |
Same plate has the engine number.
(Post 2107591)
Open the Bonnet. The label is fixed to the body, just above the front grille, where the lever for opening the bonnet is located. |
(Post 2105843)
My Palio MJD was making a racket in recent days. Then three days back the AC conked out. Took the car to Concorde, Hyderabad, and the problem was diagnosed to be the AC condenser giving way. Extended warranty came to the rescue. However, the part was not in stock. Now that the Deepavali is falling in between, I believe, the part will be available only in the next week. I took the car back and asked them to inform me when the part is ready.
A couple of things that I observed after the AC stopped working: the loud noise made by the fan completely stopped. Secondly, the temperature needle which always used to hover around the quarter mark, even after driving 6 hours non-stop, easily climbs to the half-way mark in the start-stop city traffic.
Guys,
Has anyone got Bosch wiper blades for Palio Stile?
Bosch set for Palio is only available in 24" & 16". But actually my SDX's stock wipers are 24" & 18".
I have checked with Prasad trading and Vikas, JC road. But no luck. Vikas suggests me to go for Hella which can be bought in single units.
Originally Posted by ch.nathan
(Post 2149015)
Guys,
I have checked with Prasad trading and Vikas, JC road. But no luck. Vikas suggests me to go for Hella which can be bought in single units. |
I was able to get single unit Bosch at Bosch Car Service.
I got aerotwin for driver side and normal for passenger side. aerotwin is quite expensive.
