Re: Hella Light Bar 470 Review Quote:
Originally Posted by vishal9999 Sandeep does not do installation ,can you suggest where did you get installation done in Pune.
Black magic series is available with lead period of two weeks for Rs.28500/- is this worth the upgrade over Hella 470 as its almost 2.5times costing of hella 470. |
He is a distributor so does not install, he will deliver the product in a good price. any retail accessories shop can install. just make sure you connect directly to the car's battery with the wiring harness. keep a separate switch inside the car to on-off the light. may plug into the fuse box to make sure the switch works only when the ignition is on. I had installed on Nagar Road, not sure of the shop name.
I have not seen the output of the black magic bar, but on paper, it looks superior. |
