Old 7th June 2007, 22:15   #181
Hello! I finally got to install my Max 2000. Max 4000 got dropped out because the thin long bulb would go inside the parking bulb socket, no problem, BUT the other hook type bulb would go ONLY into a H3 socket. It wouldn't go into my existing fogs. I thought of buying extra empty driving lamps to put in the 2 H3 type strobes, but i didn't want to add those to my car, so settled for Max 2000. Im a happy boy after I got this. It cost me 3.2k.
I got some issues in the installation, which took me 3-4 hours .
#1. I couldnt find a hole from the engine bay into the passenger cabin to take the EZ switch, so i ran it through the door gaps as temporary.
#2. The headlamp cover at the back isn't closed properly because of the thick wire of the strobe bulb.. Dunno what to do for this.. Ill take pictures tomorrow to show you.. Then you can suggest.
#3. I accidentally put the PIN CONNECTOR plastic clip for the SOCKET pins and the SOCKET CONNECTOR plastic clip for the PIN clip. One of them I was able to take out, but the other I wasn't.. I gotta find a way to take it out to clip it in properly..
#4. Oh yeah, I haven't screwed in the Power Supply to the engine bay yet. Its held with rubber clips temporarily until I find out how to make holes and screw it in.
Any help for the issues above?
A
Originally Posted by Mugen_Power View Post
Absar,
Which strobes do you bought ? Max 4000 ? Do you want pic of innova installation ?
Thank you, but I managed to install it myself. Luckily it came with instructions.
Absar is offline
Old 7th June 2007, 22:28   #182
Thanked: 19 Times
Absar,
Congrates for strobes.. Max 2000 is also awesome..
1 - The wires should be came inside cabin from near clutch and brakes. There should be rubber with hole. Check it out.
do post rest pics so all can help.
Mugen_Power is offline
Old 7th June 2007, 22:33   #183
^ Yeah Mugen_Power! Its even more than enough I think. Im very happy overall. I did check near the clutch and brakes. But I donno what didn't allow me to try through that. Will check tomorrow and update you.
Btw one more Q.. Do you have the Low Power enabled?
A
Absar is offline
Old 7th June 2007, 22:36   #184
rOaD AsSaSin!!'s Avatar
Thanked: 19 Times
Originally Posted by low_bass_makker View Post
Kp is using a very old one when the strobes were not popular ..the stuff is very solid built and the brightness is more than the MAX one....
yes lbm is right!!!
but i think the real potential showed off after kp got the old lamps changed for the clear lamps isnt it??
the strobes were a little dull but bright during the old lamps but now they
better work as the road lamps in his car!!!
(high beemers beware of the strange light no they are not cops nor aliens
its our kpzen with 36mm smile with bling bling strobes)
rOaD AsSaSin!! is offline
Old 7th June 2007, 23:02   #185
Thanked: 19 Times
Originally Posted by Absar View Post
^ Yeah Mugen_PowerBtw one more Q.. Do you have the Low Power enabled?
No... I have not enabled low power. Its for exhibition purpose.
Old 7th June 2007, 23:09   #186
kpzen's Avatar
Thanked: 1,882 Times
Congrats Absar on your strobes........
Pls post some pics of your install which will make it easier to solve your issues..
kpzen is offline
Old 8th June 2007, 14:59   #187
Pictures of the installation:
Pictures for issues:
The socket on the right is from the power supply box, the socket on the left is actually the same as the socket from the power supply box. It was supposed to go to the strobe side, But am unable to remove it.
This is how the headlight looks with the strobe bulb..
So, any help for the issues above?
Btw,
I still havent found a way for this above. Near the clutch and brake there's no hole sufficient to take the wire through.
A
Absar is offline
Old 8th June 2007, 15:16   #188
Thanked: 19 Times
You will have to drill the plastic cover.
Have a look at picture.
Old 8th June 2007, 15:29   #189
WHAT? Drill the plastic cover of the headlamps??? Are you serious?? How did you do it for your Innova?
A
Absar is offline
Old 8th June 2007, 17:08   #190
Thanked: 19 Times
I will post all the pictures tomorrow..
Old 8th June 2007, 17:43   #191
kpzen's Avatar
Surprsing!! how come there's no rubber holder for the bulb?? I got one with mine which helps in keeping the dust n water away from entering......
Absar..! Do not wash your car else water will enter the HL assembly...!!
Only thing u can do here is insulate that gap with the help of tape else go for the drilling option....
kpzen is offline
Old 8th June 2007, 22:47   #192
Thanked: 306 Times
KP nowdays cost cutting is on the max and thats why on the kits there is no rubber holder.....
low_bass_makker is offline
Old 8th June 2007, 22:52   #193
kpzen's Avatar
Ok...so is there anyway Absar can fix that wire without having any gap....
Don't u think the gap will cause the water & dust to enter n spoil the HL assembly...
Also do u think drilling is a good option in a DIY ??? Mind u the Ikon HL costs 3.2 K..
kpzen is offline
Old 8th June 2007, 23:21   #194
Thanked: 19 Times
I will post the pic of diy job tomorrow..
Old 9th June 2007, 10:31   #195
I got rubber holders for the bulbs yeah! But actually, its just the rear cover of the HL unit that doesn't close properly. I will try to post a picture of the rear cover of HL unit..
What if the cover of the HL unit is available for a cheap price n I wouldnt mind drilling it then. I'm sure it must be available separately and not as sold with new HL unit..
And, Mugen_Power, waiting for your DIY job pictures
A
Absar is offline
