Re: Cleaning and lubricating motorcycle chain Quote:
Originally Posted by Balthazar ...
But wouldn't applying or re-applying any lube without cleaning the chain not remove fine dust and sand particles, and they can in turn act as an abrasive?
If you use oil to lube the chain, the oil and any dirt mixed with it will move to the outer side of the chain and will be flung off because of centrifugal force every time the chain goes around the 2 sprockets.
If you use spray chain lubes that are usually quite thick and sticky, the centrifugal cleaning effect will not be enough to move the lube and dirt because of the stickiness and dirt remains on the chain. So cleaning the chain becomes mandatory.
I use 90 grade gear oil to lube my bike chain. It's cheap and effective. Applying it takes about 5 minutes when done regularly. I use an oil can to dispense it and toothbrush to apply it.
