Old 1st April 2025, 20:51   #5431
Jaggu's Avatar
Thanked: 17,296 Times
Re: Mahindra Thar : Official Review
Originally Posted by ashishfmcg View Post
Should I get a Dead Pedal installed or not?
One of the most value for bucks mod I did on my vehicle, did a 620 kms drive over Sunday and that dead pedal is a real saviour!
I have these
https://swastikfabs.in/index.php?rou...arch=thar+dead
Originally Posted by aashish_84 View Post
The TPMS has started acting up in strange ways for the Rear Right and the Spare tyre]
Did you sort this? Is it a dying battery issue? Not sure if they are replaceable, you will have to get a new unit from Mahindra I guess.
Jaggu is offline   (1) Thanks
Old 1st April 2025, 23:38   #5432
amolpol's Avatar
Thanked: 2,207 Times
Looking for info on the Thar 4x4 ATs,
1. Does the Petrol behave better than the Diesel in terms of power and road manners when using the 20hp additional power?
2. I read about throttle enhancers for the Petrol which are okay but not a solution for more power, are there tuning boxes or remaps for both?
3. Does it make sense to buy the Diesel AT mainly because it’s better on mileage or the Petrol AT because it doesn’t have DPF regen issues?
4. Are there options to make the sound system better with the stock head unit?
amolpol is offline
Old 2nd April 2025, 08:29   #5433
asingh1977's Avatar
Thanked: 831 Times
Originally Posted by s4ch View Post
Having just sold my previous gen Scorpio, I'm on the prowl for my next beast. Seems like the Thar is the one. A few questions to all current owners:
Been using the Thar Petrol AT 4X4, since May last year. Some answers I can probably chime in:
1) Can the Thar be daily driven (specifically the Petrol AT)?
We are a family of 2 (no elderly, no kids), and 90% of our running is within the city. I am not worried about mileage, but more about usability and the reduced space coming from a Scorpio. How much space is really available for luggage when you have 4 inside? I found the prev gen Scorpio's suspension manageable, is the Thar better or worse?
Yes, it can be a daily driver. Length wise it has a form factor of a hatch-back, so easy to navigate around. Of course it is wide, but the high seated driving stance makes it easy to push into narrow spaces, and drive in dense traffic. Space wise. There is minimal. The boot is tiny, and soft bags can be fitted in, but hard suit cases are difficult. We are a family of three. (Child is 7 years). So when we go on trips, we use small suitcases (those Swiss Army ones), and duffel bags, which we "throw" in the back, by pulling back the front passenger seat. So it is alright. The Thar is a bouncy ride. That is about it, for the suspension. No issue for the driver, since he/she is holding onto the steering.
2) Has anyone found out a way of opening the fuel lid from the inside?
I hate the thought of getting out at Petrol Stations, especially in the summer, and no way am I giving the attendant my keys. What are my options?
You would need to get out and open it. I used to give the keys to the attendant. They broke the inside cap connected cable -- though that has nothing to do with the fuel lid opening from the inside or not.
3) How are the stock Ceat tyres? Useable for city running and once in 3 months highway runs?
They are perfect.
4) Do I really need 4WD or is RWD ok? My Scorpio was RWD and I never felt the need for more. If I go RWD now in the Thar, will I regret it later?
I have never engaged 4x4 even once. You will only regret, for not buying it. Not for missing out a feature.
5) In the monsoon, I never had to worry about water logging in the Scorpio. Am I right in assuming the Thar would be the same, if not better?
Same!
6) In case I go the pre-owned route (1-2 years old only), anything particular I need to lookout for? (Again, specifically for the Petrol AT).
Unless it is a tbhp member, for sure the 4x4 drive train has been misused. So would not go for a 4x4 pre owned.
asingh1977 is offline   (2) Thanks
Old 2nd April 2025, 22:12   #5434
Thanked: 47 Times
While 32 psi/28 C is high pressure, 34psi/ 26 C is low Pressure.. as a result its throwing constant warning.
I've tried completely emptying and refilling with Nitrogen and also re-calibrating the TPMS, but to no respite
The psi readings are accurate compared to the filling machines, so they are reading the correct pressures.
Not sure what's the fix here. Any ideas?
Attachment 2731003
Attachment 2731002
My Thar doesn't show tyre pressure numbers for Spare tyre. It does show up for 4 tyres. Should I get it checked or is it normal?
sandeeprawat is offline   (1) Thanks
Old 4th April 2025, 19:18   #5435
lurker's Avatar
Thanked: 1,478 Times
I hate the thought of getting out at Petrol Stations, especially in the summer, and no way am I giving the attendant my keys. What are my options?.
make a duplicate key and hand it over to attendent for opening fuel lid. the duplicate key for fuel lid doesn't need any sensor or rfid, it is just a plain key, so just get a 100₹ duplicate made and keep it in your glove box
lurker is offline   (4) Thanks
Old 5th April 2025, 11:21   #5436
Roy.S's Avatar
Thanked: 1,383 Times
Originally Posted by lurker View Post
make a duplicate key and hand it over to attendent.....
I was on the verge of getting a regular key cut for this very purpose. Then I had a premonition. A vision from a possible future. A nightmarish future where a careless pump attendant scratches the fuel tank lid as he tries to open it.
Getting out of the car to open the lid is the lesser evil, as far as I'm concerned.
The only other car in which I had to do this was a M800 that I had in my 20s and even then I would not hand the pump guys my key.
Roy.S is offline
Old 5th April 2025, 11:56   #5437
lurker's Avatar
I never had to face this problem in 3+ years of implementing this solution. But if you have this issue then just wrap the fuel lid in PPF,
lurker is offline
Old 5th April 2025, 14:20   #5438
akp
akp's Avatar
Thanked: 181 Times
I think that is normal. It only shows the readings for the four active tires, but it does keep track of the fifth one too, and will give warning if the pressure goes too low.
akp is offline   (2) Thanks
Old 5th April 2025, 23:11   #5439
I wanted to know if a new/facelift version of 3-door Thar releasing in 2025? The dealer in Pune says they don't know, however some news websites have reported that it could be as soon as June 2025.
bhuvanmisra is offline   (1) Thanks
Old 9th April 2025, 22:25   #5440
harshavardhan's Avatar
Thanked: 33 Times
Dear All,
Any review on the Thar AX - 4 x 4 Version , Diesel . I searched and couldn't find a review.
Feedback on this version would be appreciated.
Regards.
harshavardhan is offline
Old 12th April 2025, 18:36   #5441
Thanked: 3,183 Times
Fellow Thar owners in Bangalore. If anyone has got a custom bumper installed and wants to dispose off the original bumper. Pls message me. Scouted on OLX but did not find anything in Bangalore.
I bought a used thar which has a custom front bumper but want to restore it back to the original, if possible. Like the stock look of the car (just with the modified grill). Hence this query.
Hope this is not in violation of the forum rules.
sachinayak is offline   (1) Thanks
Old 21st April 2025, 17:46   #5442
s4ch's Avatar
Thanked: 814 Times
I have booked a single owner, Black, June 2023 Petrol Automatic 4WD on Spinny. Price is 15.24 in Pune. A few questions to the experts:
1) Is this a good price? Seems like a great price to me but would appreciate some inputs.
2) The previous owner (I've spoken to him) has installed Cobra springs. I believe this gives a slight 1 inch lift to the front. Any feedback on Cobra springs and how the handling is for city/highway use?
3) The car is still in Mahindra warranty and I plan to get it checked there for a full inspection. Anything in particular that I should get checked?
4) How do I activate 4L and 4H when not on off road to check they engage ok?
I have spoken to the previous owner and he seems like a car guy who has taken care of it so I am tempted to go ahead with the deal, but would appreciate any insights from fellow members. Thanks!
s4ch is offline
Old 23rd April 2025, 23:51   #5443
s4ch's Avatar
Thanked: 814 Times
Any thoughts on whether the Thar Petrol AT is practical for a daily driver, approx 800km per month? What kind of mileage can I expect? I feel like I am done with Diesels but abysmal mileage of the Petrol does get me very slightly worried, or is it not really that bad?
s4ch is offline
Old 24th April 2025, 05:47   #5444
Thanked: 957 Times
If you're worried about fuel efficiency (nothing wrong with it), then the turbo petrol isn't for you. You can expect 8-9 kmpl in city and 12 kmpl on highways with a reasonably light foot.
Amrit@wheels is offline   (1) Thanks
Old 24th April 2025, 07:23   #5445
Dippy's Avatar
Thanked: 4,196 Times
Been driving a petrol AT 4x4 for almost two years now as my daily. I consistently get 9.6 to 9.8 kpl in city driving. The worst I have got till daye is 8.3. This is via the tankful to tankful method.
If those FE figures work for you then you can surely go for it. The mStallion engine is very refined and a fantastic engine.
Dippy is offline   (1) Thanks
