Old 25th January 2011, 14:28   #3031
Thanked: 9 Times
re: The Tata Safari 2.2L Technical / Problems Thread
hi friends,
need some help. for the last six months there is some rattling noise coming from the backside of my safari. i feel it is coming from the back door. when i went to TASS they were doing some trial and error methods. now almost all the rubber bushings have been changed but sound still exists. (visited two TASS for this almost five times). it take some time to start the rattling, say some 4-5 kms drive then only the rattling starts. have anyone of you had this problem?
i.1979 is offline
Old 25th January 2011, 14:44   #3032
ankur_gupta10's Avatar
Thanked: 52 Times
Originally Posted by i.1979 View Post
hi friends,
I might sound a little stupid, but if you can make some video, it might help.. Many a times the sound in my car have been because of badly placed jack, or some stuff in back door side pockets. Rattling noise can also be because of back exhaust pipe hitting against the rear bull bar assembly (incase you have one.)
ankur_gupta10 is offline
Old 25th January 2011, 14:46   #3033
Thanked: 52 Times
My car clock has started missing time. I set it, and then again in few days the time goes haywire. Can anyone help as to what might be the problem?
Old 25th January 2011, 16:14   #3034
sheelz's Avatar
Thanked: 59 Times
HI Guys
My Dec 2010 Safari GX was behaving extremely well and I was pretty happy with it till today when it gave me the first shock. While retuning from the town, I revved the vehicle above 2000 rpm( running in is over). The max speed attained was 120 kmph and rpm 2400. I came home and switched it off. After some time, I started the vehicle again to take it inside the garage. Suddenly I felt change in engine noise and MIL coming on. I switched it off and started again after 30 seconds but light persisted. I switched it off and called TATA Helpline. After a couple of call, they informed me that mechanic is on the way and should reach my place by 30 min.
Waiting for him anxiously.
I will keep you guys posted for further story.
sheelz is offline
Old 25th January 2011, 16:42   #3035
tsk1979's Avatar
Thanked: 23,494 Times
What light came on?
Does it say "CHECK ENGINE"?
Or is it a yellow colored container type light which came on?
tsk1979 is offline
Old 25th January 2011, 17:16   #3036
sheelz's Avatar
Thanked: 59 Times
What light came on?
It is yellow colored light.
Ok the breakdown assistance guys just arrived and checked the vehicle. He tightened the big wire connector of ECU assembly ahead of battery and told me to start the vehicle again. Voila, the light has gone. Tried it no of times but it never came on.
He said that sometime the connection to the ECU become loose and hence the light.
I am relieved!!!!
One more small thing, after refueling the vehicle it takes about 15 min for the gauge to come to correct reading. The movement is very slow. Is that so or mine is faulty?
sheelz is offline
Old 25th January 2011, 17:49   #3037
cool_dube's Avatar
Thanked: 4,760 Times
Are you sure? I guess the RPM should be around 2,700-2,800 at 120 kmph.
There are two yellow colored lights - one for 'check-engine' and the other for sedimenter. In your case, I believe it was the first one.
Good to know that the issue got resolved. That said, this should not happen. Did you recently get your Safari serviced? Someone might have messed up the connectors during engine wash. Good-to-know info in any case.
This is normal behavior.
cool_dube is offline
Old 25th January 2011, 17:54   #3038
sheelz's Avatar
Thanked: 59 Times
What light came on?
Yes it was the MIL, the light on right topside.
I think I might be wrong in rpm. Thanks for correcting. I just glanced at rpm when it was winding down.
sheelz is offline
Old 25th January 2011, 18:28   #3039
tsk1979's Avatar
IS your ECU covered with the rubber thingy, if not better get it done for free
tsk1979 is offline
Old 25th January 2011, 20:29   #3040
Thanked: 9 Times
ankur,
no it is not from the jack box i checked it already by removing the jack. i don't have any bull bars on my vehicle.
i.1979 is offline
Old 25th January 2011, 20:32   #3041
SS-Traveller's Avatar
Thanked: 28,767 Times
Re: Car clock
...the time resets on the digital clock that is built in the front meter panel.
Pleae check the voltage across the battery terminals when cranking the starter for a cold start in the morning. If there is a substantial drop in voltage, the clock can reset. In that case you'll need a new battery (3 years is an acceptable time for a battery change).
Originally Posted by Kairalee View Post
...could be a issue with a loose contact in the clock connections...
Could be this too.
@Mods: Do you think this thread should be moved to the The Tata Safari 2.2L technical/Other problems/solutions Thread? A lot of people visit that thread and there is sure going to be more answers there?
+1.
SS-Traveller is offline
Old 25th January 2011, 20:37   #3042
Thanked: 52 Times
Re: Tata Safari CLOCK keeps resetting itself!
@SS traveller - Thanks for reply. I will set the clock before starting the car, and will check once it gets started. Will try keeping an eye on this for next 3-4 days. if the clock resets after the starting, then i would know the cause. Presently i do not have the voltmeter so cannot check the voltage..However my workaround should work also.
Thanks again.
Old 25th January 2011, 21:00   #3043
Thanks again.
Yes it would. Note if the clock display dims when you crank. And resetting - does that happen everyday or occasionally?
Old 27th January 2011, 09:57   #3044
Thanked: 52 Times
I found the clock resetting at the time of my morning restart. Looks like time to change the battery. Would get it checked in 1-2 days and post update. Thanks SS
Old 27th January 2011, 10:06   #3045
verditer's Avatar
Thanked: 110 Times
hi friends,
I guess most Safaris experience this problem, and some have rectified it by getting the dove tail joint fixed.. Newer safaris have this joint coming as default from factory I think.
Not sure if you have it or not, this is a joint on the body below the main latch of the back door, and has a corresponding thing on the door also.
Mine has this, but still it developed a squeak, so I've now placed a neatly folded cloth in the bottom where the door meets the body. Fold the cloth not too thick, or too thin, and bang shut the door and ensure it has latched on properly. Mostly this should solve it I would think.
Do try and report here.
Off topic, by the way, did anyone notice the 4-5 Safaris leading and trailing the Prime Minister's motorcadce in yesterday's republic day celebrations at Delhi? A sight to see. :-)
verditer is offline
