Old 6th December 2011, 01:28   #3961
himavanth_m's Avatar
Thanked: 429 Times
re: The Tata Safari 2.2L Technical / Problems Thread
changing back to mineral oil will not give any problems. If you are not the "high rev" kind of driver, and keep rpm at 2000-2500rpm, then go back to mineral oil.
Esp with 7.5K service intervals, mineral oil will do the job just as well.
Thanks a lot for your reply. I will be changing back to mineral oil then. It will save a lot of costs. And yes, I am not a high revving kind. I like to do trips at a leisurely pace say at 100kmph in 5th gear at max and I am not involved in any drag racing on the roads.
However I am planning to do a Sikkim trip in 3 months of time. Does mineral oil have any disadvantage as compared to Synthetic oil. I am from Hyderabad, And sikkim trip would involve around 7.5 k kms in 14 days and driving will be in high altitudes. Do you recommend sticking with synthetic oil atleast upto the trip?
TSK your advice on this would be especially helpful as you are a Safari Owner and you have done lot of trips at these altitudes and for long distances.
himavanth_m is offline
Old 6th December 2011, 11:15   #3962
tsk1979's Avatar
Thanked: 23,487 Times
I have done multiple ladakh trips on Mineral oil, as well as many other high alititude trips around kaza, rohtang, Jalori.
There will be no issues.
tsk1979 is offline   (2) Thanks
Old 8th December 2011, 06:57   #3963
sumannandy's Avatar
Thanked: 997 Times
Got front suspension bushes replaced from a garage at HBR Layout, supposedly run by ex-TATA workshop technicians. They also replaced the lower arm ball joints.
Total cost including labor and alignment: Rs. 4248.
So far so good.
sumannandy is offline
Old 8th December 2011, 09:02   #3964
Lukeskywalker's Avatar
Thanked: 1,244 Times
Could you please share the contact details and location of this garage?
Oh, thanks for the update on the other thread, saw it after I read this.
Lukeskywalker is offline
Old 8th December 2011, 19:21   #3965
Thanked: 402 Times
I have test driven Safari once and am considering buying.
I am 6'1". I had a feeling when td-ing that the pedals are a little too far from the seat. Had to bend the lower back a bit to reach there. Problem is I couldn't move the seat towards front since then the steering would nearly touch my legs.
Wasn't too discomforting in a TD, but not sure how it will feel in long run.
Anyone around that height faces problem of this kind?
mayuresh is offline
Old 8th December 2011, 19:52   #3966
Thanked: 9 Times
About synthetic versus mineral engine oil.
When oil change was due at 15K kms, I thought it is good to know how the 2.2 dicor behaves with synthetic. Since the 'push' at Concorde was for Castrol Edge and I had used the same in my previous car and that members here had discouraged using it on 2.2 vtt, thought it is a good idea to try Mobil 1.
Though it was a costly exercise, the engine ran smooth and a lot quieter than it was before reaching 15K kms. There was very very less smoke and it was not offensive while standing near the exhaust and trying to smell it at idling RPMs. In this state I had done an emission test. The technician was surprised to see the readings and near absence of soot which he mentioned.
At the next service to change engine oil at 30000kms I changed back to mineral oil for two reasons.
1. Cost of 8K or more for every 15K kms seemed prohibitive.
2. In the normal Bangalore city driving combined with highway drives, thought it is a better idea to change oil at 7500 kms.
But now after having run almost 5000kms after 30K kms service, I feel engine sounds harsh and the exhaust fumes are unbearable even if it is for idling time while parked at home. In the daily drives when an army of bikers are seen in mirror, behind the truck following in thick traffic, I start worrying.
From mid November it started cold mornings in Bangalore. Now with mineral engine oil, I see a lot more white smoke in cold start than last year. Do members feel this is normal?
vijuvarghese is offline
Old 9th December 2011, 07:19   #3967
Thanked: 1,281 Times
Please refrain from using Mobil 1 (API CF !).2.2 Dicor engine needs minimum API CH-4.If you want to use a synthetic for this engine,there's Mobil Delvac 1 (5W-40/API CI-4 Plus).
rb2399 is offline   (1) Thanks
Old 9th December 2011, 11:33   #3968
richie4u's Avatar
Thanked: 610 Times
I am in the same situation as above, I want to change my engine oil back to mineral from synthetic just because of the cost of it and my car is not used that much. I dont mind changing the mineral oil at 5000-6000 kms interval. So now since I have synthetic oil already being used in my engine is it recommended to change back to mineral(what is to be done if the oil is to be changed back to mineral) and which mineral oil is the best for the 6K interval.
richie4u is offline
Old 9th December 2011, 11:54   #3969
bj96's Avatar
Thanked: 1,552 Times
Originally Posted by mayuresh View Post
... I couldn't move the seat towards front since then the steering would nearly touch my legs...
Did you try lowering the seat? Safari pilot seat is height adjustable. The lever is on rhs of the seat.
bj96 is offline
Old 9th December 2011, 21:32   #3970
Thanked: 402 Times
Yes. I did. It's not so pleasing as it takes away some height advantage.
I don't know whether steering adjustment would help. Any tips on that?
I will soon visit a showroom soon to try this out.
mayuresh is offline
Old 12th December 2011, 12:09   #3971
verditer's Avatar
Thanked: 110 Times
Mine is at 36K kms on ODO, and my experience is similar to yours with regard to smoke.
On cold start in the morning, I let her idle for a minute or two, and for around 30 seconds there will be smoke coming out, and can very well smell it - it is a little strong on the nose.
The smoke dies down immediately after that. I am thinking this is normal.
I've always used mineral oil only.
verditer is offline   (1) Thanks
Old 12th December 2011, 14:24   #3972
Torque-ative's Avatar
Thanked: 90 Times
Dear Safari owners,
I know the safari as we know it is on its final run before it is discontinued / replaced.
Would it make sense to buy one new now (EX / GX).
I need a larger car (no minivans), and the attitude the safari still exudes is good enough for me.
I am only worried about reliability, fit and finish is not so much an issue.
I currently own a 2006 NHC GXI.
Thanks in advance
Torque-ative is offline
Old 12th December 2011, 19:03   #3973
Thanked: 402 Times
I sat in this state of mind for a while now, waiting for new version and all that.
Now just decided to take the plunge. Will be soon booking GX. I only want to re-check whether the ergonomics suit my height by taking TD one more time.
Mayuresh
mayuresh is offline
Old 13th December 2011, 09:20   #3974
Thanked: 9 Times
Thanks Suresh.
Here's a video of exhaust at coldstart on a November morning. Shows first ten seconds. Take a look.
Old 13th December 2011, 10:22   #3975
Thanked: 9 Times
Originally Posted by smsrini View Post
Anyone tried either Bilstein / Ironman / Tein shock absorbers + springs for the Safari ? I hear from Red Rooster that they have a kit for the Scorpio but not for the Safari.
thanks
Srini
There is a set of Bilstein shock absorbers which were imported for my Sierra Turbo, was used for nearly 20K kms and removed while selling the car. Now I am waiting for the shock absorber/suspension warranty on the 2.2 vtt to get over by 35K kms. This I believe is a direct fit (of the design for Sierra) for both front and back, need to check this though.
But I do not have any coils matching the truck.
