Old 7th August 2007, 11:52   #16
Got this quote from Super Tyre Tec, JC Road. All for 195/60/R14
Michelin PP (Not PP2) - 4050/- [PP2 is not available in R14]
ES100 - 3000/-
Maxxis MA-V1 - 4200/-
S.drive - 3800/-
Wanted to know how is Maxxis MAV1. Also, the old PP is it as good as PP2? Came to know that S.drive while is very good in performance, the tread wear is high. Is this so? Anyone having S.drive?
kruzader is offline
Old 7th August 2007, 14:56   #17
kpzen's Avatar
Thanked: 1,884 Times
ES100 - 3000/-
S.drive - 3800/-
Why are u even thinking of Maxxis when u are gettin S Drive, PP & ES100 at lower price..??
rjstyles69 (Riju) has S drives on his Baleno.
kpzen is offline
Old 7th August 2007, 15:04   #18
iraghava's Avatar
Thanked: 281 Times
At this price I would prefer the PP's or the S-Drive's over the Maxxis any day. But that is purely my opinion.
iraghava is offline
Old 7th August 2007, 15:56   #19
rapideffect's Avatar
Try this 205/55 R 15 yoko S drive. It will cost you 3700/- per tyre. This could be a better option for your Verna.
I have one of my friend having the same setup on OZ alloys on his verna. This has got an amazing road grip.
rapideffect is offline
Old 7th August 2007, 15:56   #20
Maxxis name was suggested to me by the dealer. My first preference will be michelin/yoko. Planning to pick it up soon.
kruzader is offline
Old 7th August 2007, 16:22   #21
I was not looking at 205's as suggested by some of the experts here. Looking at only 195 R14. Anyways, hope your friend is very happy about the S.drive...
kruzader is offline
Old 8th August 2007, 07:27   #22
@rjstyles69 (Riju) : How are the S.drives?
How does it compare to the PP?
kruzader is offline
Old 11th August 2007, 10:21   #23
i took verna sx abs on 19 july 2007, i modified with prestege wheels 15" Rs 21000/-, nankang tyres 205/55-15 Rs 20000/-, llumar atr 20% charcoal Rs 1600/-, semileather seats and stearing cover Rs4500/-.
i got only Rs 12500/- for old wheel and tyres.
[IMG][/IMG]
srimaan is offline
Old 11th August 2007, 15:19   #24
other images of my car
srimaan is offline
Old 29th May 2009, 10:32   #25
icemanz's Avatar
Hi All,
Its time for me to change the stock 14" mrf zvts 170/70/R14 tyres on my Verna VGT. It has been over 2 years since I brought the car and has run 37K kms. The front tyres looks totally worn out, where as the rears and the stepnee are in good condition. I had the rotation done on the last service that was at 28K.
Please advice whether I should change all 5 or just change the front tyres for now?
I would like to stick to the stock size unless upsizing will really help. I am looking for good grip, ride comfort and better mileage. Please suggest which brand and model should I ask for when approaching the dealers.
I would also like to go for alloys - again my query is whether 15" will help in anyways or staying with 14" is better? Please advice on the brand of alloys I should consider.
Looking forward for your guidance and suggestions.
Thanks!
icemanz is offline
Old 29th May 2009, 11:40   #26
WasavaTyres's Avatar
Thanked: 460 Times
Icemanz I suggest you stick to 14 and if you're particular about ground clearance you can go for Yokohama A-Drive 195/65/R14.
WasavaTyres is offline
Old 11th September 2009, 09:56   #27
dinu2506's Avatar
Thanked: 977 Times
Im getting a new Verna 1.5 CRDI SX last week of this month. The standard car comes with 185 65 R14 on Alloys. I have specifically asked for Bridgestones and not MRF. The Bridgestone model is B250 tubeless. In this situation, do you suggest an upgrade or will I be fine with this set? Will appreciate your advice.
dinu2506 is offline
Old 11th September 2009, 12:16   #28
kpzen's Avatar
The B250s are anyday better than the MRFs but they aren't exceptional either.
Upgrading options:
185/65-14
Michelin XM1
Yoko A drives
Continental CPC
195/60-14
Bridgestone Turanza ER60
Michelin PP
Michelin XM1
If u have plans to upgrade then get the new set within couple of days of your purchase so that you get the best possible buy back value for your B250s.
kpzen is offline
Old 11th September 2009, 12:57   #29
dinu2506's Avatar
Thanked: 977 Times
Upgrading options:
185/65-14
Michelin XM1
Yoko A drives
Continental CPC
195/60-14
Michelin PP
Michelin XM1
Thanks for the quick response. If I'm sticking to 185 65 R14, is it necessary to upgrade? I have the same size Michelin XM1 on my Indigo and I have found that they are not very resilient to rough roads. I had a bad tear on two of my Michelins. I wanted to go in for BS ER60 but they do not have in that size.
I'm fine with upgrading to 195 60 R14, but even though it is within tolerance, the GC reduces a bit. Do you think it is advisable?
Or just forget the upgrade and stick to the BS B250?
dinu2506 is offline
Old 12th September 2009, 01:45   #30
pras.oct25's Avatar
Thanked: 7 Times
can someone please give me a comparison/review specifically for the verna, for xm1 vs yoko s drives, and also 195/60/r14 vs 195/65/r15. I am looking to upgrade and am confused between the combination of tire brand and size I should go for. I am upgrading for better handling and a slightly heavier steering, but dont want to end up with a bumpy and irritating ride.
Some help would be appreciated.
pras.oct25 is offline
