Apologies exhaustpipe, I missed your post.
Originally Posted by exhaustpipe you are an expert at VCDS and VW systems. |
I am not. I am just tinkering with whatever is available at my disposal and reporting the findings here.
Originally Posted by exhaustpipe I was wondering if you could shed some light on a question I have regarding my Passat B7 2011 model (current Indian one). |
I haven’t worked on anything other than the Polo but have read a bit about the Jetta online on several forums so have some idea. Not the Passat though but will try my best regardless.
Originally Posted by exhaustpipe I have the RCD 510 stereo and a 9w7 Bluetooth module. Now from what I've read online, this module supports phonebook listing, audio streaming and even A2DP |
That’s correct.
Originally Posted by exhaustpipe however, in my car the RCD 510 doesn't display track information |
Something’s definitely wrong there. You should be able to see the track display on the cluster’s MFD.
Originally Posted by exhaustpipe and I can't change tracks from the stereo |
You mean the touchscreen presses aren’t responding?
Originally Posted by exhaustpipe or from the buttons in the steering wheel. It does not support A2DP functionality. |
Was it this way from day one? Or did it happen recently since a service or a battery swap?
Originally Posted by exhaustpipe Is it possible to fix this using VCDS? I used to have the cable in 2012 but most of the modules installed in my Passat B7 weren't support by the latest software from Ross-tech back then so I sold it. |
Yes it is possible but since you mentioned you can’t change tracks from the stereo, I am wondering if the HU itself has gone bad (extremely remote chances that it would have).
The MFD will enable the track display only if you enable the option Radio from the CAN Gateway module:
Similarly the MFSW buttons will work only if the corresponding bit is enabled under the relevant byte under Central Electronics:
And A2DP can be enabled from the 77-Telephone, Long Coding from here:
Originally Posted by graaja 1. I am considering either the RCD510 or the Android HU (the one FrankMehta has installed) for my Polo GT TSi. In his ownership thread, FrankMehta has mentioned that OPS is not available in GT TSi anymore. Do you know if this is true? |
That’s correct.
Originally Posted by graaja Is the reverse parking sensor setup that comes with the current GT TSi different from the one in your car? OPS integration is one of the main features I am looking for in RCD510. |
The previous generation GT and Highline models (both Polo/Vento) came with a superior OPS module which was accessible by VCDS. Check my post
here. The current generations now come with a module that only buzzes based on the proximity sensors, no display.
You will have to change the current module with this one (available on Ali) if you need the OPS display on the HU.
Originally Posted by graaja 2. If OPS is available, and if I also install a reverse camera, will the OPS be overlaid on the camera video, or only one of them will be active? |
On the RCD510, you have the option of getting only one of the two like this:
The overlay is possible only on the RNS 510 like this:
Originally Posted by graaja 3. I am thinking to go with 9W2 bluetooth module. From your description, I understand 9W7 will be useful if we have either the Bosch RCD510, or the maxidot instrument cluster. With the Delphi RCD510 and regular instrument cluster, we will not be utilizing the advanced features of 9W7. Is my reasoning correct? |
Yes, you can only pick up/disconnect calls by pressing the phone button on your MFSW. Dialing has to be done via the phone. You can stream BT music as well.
Quoting psispace’s post here since it is relevant to the current discussion:
Originally Posted by psispace The rear bumper sensors on my car were untouched when I added the front sensors. I have OPS display on the Blaupunkt 835 (photos in my ownership thread, so not repeating here).
Suffice to say they are indeed capable of it. |
Your car has an OPS module which supports both the front and rear sensors whereas the stock Polo comes with an OPS module that supports only the rear sensors. The current models roll out with a module that does not support OPS display (only beeps). Vagtune has replaced the stock OPS module on your car with a Parkhilfe 8K module supporting front and rear sensors and that's why you are getting this display on your HU.
This is that module:
Originally Posted by psispace Front sensors and cabling cost around 14k. |
Plus the new OPS module. Please check up with Vagtune and correct me if I am wrong.
