Old 6th April 2009, 22:51   #136
HIGHNOON's Avatar
Thanked: 70 Times
For most users LPg conversion is means of saving on fuel cost. A perfectly tuned LPG kit performs exceptionally well. And believe me with due respect to bhp figures , the performance on lpg is actually a shade better than on petrol. Atleast for my car it is. On LPG the car has got enough power most of the time. Practically no knocking even if you find yourself in a wrong gear once in a while. Pulls cleanly without strain.
So sporty performance modification on LPG ? Interesting... but a bit of paradox !
i would need to spend quite some money which would negate all i would save on the fuel . Plus in most cases of open loop systems , frequent tune ups to the gas air combos are required.
As far as i know possible. But Long term reliabilty.... that maybe a different storey altogether...
Maybe a high end sequential gas injection kit would be a better bet for a good modern mpfi.
BTW latest fig.
316 km - 26.5 lit = 11.92 kmpl with 168 km in Mumbai and 148 km on highway @ Rs.25.92 / lit
Rs.2 and paise 17for every km of fuel cost!!! Diesel ( economy.... )territory buddy
HIGHNOON is offline
Old 7th April 2009, 09:56   #137
ask77's Avatar
Thanked: 25 Times
Originally Posted by HIGHNOON View Post
BTW latest fig.
I second that . My optra performs much better on LPG than on petrol . At first I used to think that is because maybe the injectors get choked or perform not so well due to regular use of LPG but I got the injectors and the throttle body cleaned but even then the smoothness and performance on LPG was clearly noticeable . I think that this is due to the higher octane ratings of LPG combined with higher compression ratios of modern engine which now come built with anti-knock sensors and adjust automatically to the quality of fuel available
ask77 is offline
Old 9th April 2009, 17:31   #138
HIGHNOON's Avatar
Thanked: 70 Times
hi
Another thing i would like to add is that i have done 25000km on LPG now and the car seems as good as it was at the time of acquisition. Still very smooth.
Another 50k possible ? reliabilty wise ? hope so......
The engine still seems fresh @ 50850 km , atleast no apperent effects of the gas. I still maintain a 6000 km / 6 months interval even after shifting to gas. The oil seems quite ok but i do not want to take risk.
I drive a bit on petrol as well but stil have had to clean the injectors twice during the last 25k km.
I should have taken a compression test before retrofiting and one now to actually know the effects of use of the dry gas on the engine instead of petrol which has got great lubricity.
@ ask77, how much u've clocked after retrofitting ? Do you notice any loss in the motor performance , any increase in nvh ?
How often does the kit need resetting / tune up? Whether the kit needs tuneup @25000km. The manual says so but the fitter says otherwise.?
I am confused. Do u have any clue ?
HIGHNOON is offline
Old 9th April 2009, 23:17   #139
ask77's Avatar
Thanked: 25 Times
I have done around 10K on my kit. The evaporator should be cleaned every year or so as preventive maintenance and maybe the filter inside the gas relay may need cleaning and of course it is important to have a clean air filter at all times but otherwise hardly anything in the kit to maintain . Is your check engine light coming on ? usually if the CEL lights up frequently then only the kit needs maintenance
ask77 is offline
Old 26th May 2010, 11:05   #140
JayD's Avatar
Thanked: 2,616 Times
Sorry for bumping up an old thread, but what is the current price of auto lpg?
JayD is offline
Old 30th May 2010, 14:31   #141
Thanked: 387 Times
around 33 in bangalore. Dont remember the exact price
rajesh1868 is offline
Old 10th December 2011, 10:15   #142
coolclouds's Avatar
Thanked: 519 Times
Re: LPG @ Rs. 32.55, is it worth it ? Edit: now Rs.36.20
Can anyone update the gas price in Bangalore?
coolclouds is offline
Old 10th December 2011, 12:23   #143
Thanked: 3,038 Times
Unlike CNG, LPG is a derivative of crude oil, hence its price will keep in synch with crude prices. CNG is a different product and priced differently. From what I have read (having no direct experience in LPG cars), the FE in an LPG car is roughly half that of a factory fitted diesel, so the cost per kilometer will be pretty same at the current prices. In such a scenario I would prefer a diesel as that would give me both mobility and protection from a fire in case of rear ended collision.
Aroy is offline   (1) Thanks
Old 10th December 2011, 19:09   #144
nanduchitnis's Avatar
Thanked: 301 Times
Pune LPG is around Rs 40/- per liter or is it kg? Petrol is around Rs 70/-
I have a factory fitted Wagon R for Pune city driving last 3 years and am totally satisfied. No issue with engine/clogged spark plugs.
Savings are great. Milage is 12.4/ltr.
nanduchitnis is offline
Old 29th December 2011, 09:37   #145
Thanked: 24 Times
Please let me know a good place in Hyderabad/Secunderabad to convert my Swift Zxi to Gas. Some idea on the cost of conversion would be also welcome
ajitsank is offline
Old 1st January 2014, 17:33   #146
deehunk's Avatar
Thanked: 3,312 Times
Infractions: 0/1 (5)
The AutoLPG price has been increased by Rs.11.5 and the price stands at Rs.66.5 today in Bangalore, I fail to understand the logic behind the price hike as Auto rickshaws are dependent on LPG alone, this hike will have an impact on their operating cost. The minimum fare was increased to Rs.25 in Bangalore and the per kilometer cost was increased to Rs.13, is the hike done to give more profits to Oil companies which are white elephants. With the current pricing the running cost of LPG vehicles becomes more than petrol vehicles, is the resonsibility factor of promoting cleaner fuel missing with the policy makers?
deehunk is offline
