Originally Posted by graaja The link in the first post does not work anymore. It gives a "Sorry. This shop is currently unavailable" error. Even the CarplaySolutions.com throws the same error.
Maybe BMW is forcing them to shut shop and they keep moving to different shop names. If this is the case, how do we get any support in case of any problems - like rolling back before giving to BMW for any warranty claims etc.?
PS: This is something like the AliExpress stores that sell VCDS cables for VAG cars. They exist only for a short window of time and once they sell some number of cables, they just disappear from AliExpress.
I have a few questions:
1. So, using the E-Sys and FSC code method, you are just setting some flag to enable an already existing feature, not doing a complete upgrade of the iDrive firmware, right?
2. If the answer to #1 is yes, then if BMW upgrades the iDrive firmware sometime in the future during a service, that will disable CarPlay. In this case, do we have to get another FSC code to enable it again? Or the one we got earlier is enough?
3. I read in some forum that CarPlay can be enabled only if the iDrive hardware has the WiFi hotspot feature. In your 3GT, is CarPlay wireless or wired?
The more I read about this, my resolve to keep the BMW totally free of any mods is dissolving |
1- It's not a complete upgrade.. In fact its hardly a firmware flash at all
There are a few things that happen as a part of this
a) FSC Coding: Your idrive has a bunch of activation keys on it (called FSC files).. what keys they are is a function of what is enabled for your car (e.g. an India make 3GT will have a key for India maps)
B) VO Coding: It also has a bunch of vehicle order (feature set) identifiers (e.g. 6CP for carplay)
Not all features require an activation key (e.g. enhanced bluetooth) but all features do require the presence of a corresponding identifier.
At the time of bootup, Your idrive sytem will check what feature sets it is supposed to enable and will activate those
FOr feature sets that require the presence of a encryption key, it will check for the same
and will not activate features sets that require a key but the key isn't present
C) CAFD coding: once the feature set module is activated, the module will check for what parameters or flags are required to be enabled/disables/configured..
An easy analogy for A, B, C would be say MS office on a windows laptop
- B: When windows boots, the registry that loads will have MS office marked as present.. if it isn't present, you won't see MS office as a choice within available programs
- A : If B is true, When you click on say excel, office will check for presence of activation key.. if it is missing, excel won't load
- C : If A, B are true then excel will load - the features/options it presents will be a function of the choices you have selected within the excel settings menu
Now for certain features , like enhanced Bluetooth (two phones simultaneously connected), you just need to modify A and C .. In my case, my vehicle was marked as 6NH (normal BT) which I changed to 6NS (which corresponds to A) .. and then activated desired features by changing the active/inactive flags on the CAFD (which corresponds to C)
For features that require an activation key (like carplay), you also need to purchase the key (which cost me 50Euro) and do B
Even though it may sound complicated, like I said before, it is far removed from a complete firmware flash.
If you get all your ducks in a row, the whole process will take 10 mins from start to finish as all you are doing is 1) uploading a official BMW softkey, 2) adding 6CP flag to your VO, 3) marking carplay_swt and apple_enhancements as active (or aktiv as it appears on BMW)
For your other questions
2- it's possible the feature may disappear if BMW does a full firmware flash on your headunit but won't disappear on a normal update
even if it disappears, you should still be able to reupload the soft key (FSC) to reactivate
3) idrive hotspot - I guess what they meant is whether idrive has wifi hardware or not (which yours will for sure)
what you may or may not have is a wifi antenna
Now in my case, while the HU has wifi hardware, it does not have a wifi antenna plugged into the HU
I knew this upfront as in my earlier trysts with e-sys, i had enabled the hotspot and miracast flag as active
However, I also knew that my car does not have a wifi antenna as miracast would be slow/drop connection if I moved the phone away from the dash
Thus when I enabled carplay, I knew I may face the same issue
Now with carplay, I get flawless connectivity as long as the phone is placed near the cup holder/under the HU but start getting delayed response/connection drop if I move it away
I checked the wifi signal from the HU on my iphone with airplay on and it showed a RSSI (signal strength) of -72dbm when close to the HU which is usable but not perfect (think of it as a 3 bars of 5 on your laptop wifi)
Now I originally activated carplay just for kicks but now that since carplay is actually getting full time usage, I ordered a BMW wifi antenna yesterday (some 10 GBP odd) which I will get next week
In fact Aliexpress has the antennas for 4/5 USD but din't have the patience to wait a month (search for "BMW NBT Evo wifi antenna" or "BMW Fakra wifi antenna")
What this means for you is :
a) You may already have an antenna and don't need to do anything other than ordering the softkey and buying/building an enet cable
b) You may not have an antenna but are OK leaving the phone under the dash - don't worry, while under the dash, there is zero lag
c) or do what I did - try carplay, if you like it, order an antenna.. getting access to the antenna connector panel at the back of the headunit should be a thirty minute task ..attaching the antenna is plug & play.. or you can always ask a good workshop to do it for you
