Old 16th March 2008, 18:07   #91
adityamunshi's Avatar
Did you buy it or DIY ?
Originally Posted by moralfibre View Post
I did change the sub enclosure long time back when I got the HU. I have a 1 cu.ft sealed enclosure now.
adityamunshi is offline
Old 16th March 2008, 19:53   #92
moralfibre's Avatar
Thanked: 14,474 Times
I bought it. Its from a company called Bassworks which makes these enclosures in Chennai.
5440-10231.jpg - 2000 Maruti Esteem VX The Night Rider
4839-8234.jpg - 2002 palio 1.2ELX
moralfibre is offline
Old 17th March 2008, 00:17   #93
payam's Avatar
Looks so familiar to me
payam is offline
Old 23rd March 2008, 23:49   #94
razor4077's Avatar
Thanked: 300 Times
Have a Bassworks sub enclosure too. Very good quality. Cost me 1500 bucks.
razor4077 is offline
Old 24th March 2008, 11:09   #95
amit_mechengg's Avatar
Thanked: 2,263 Times
Originally Posted by kumar_ranjan View Post
I agree with you that we have the same car. I have a 2 channel amp that I plan to use to power it. I was just confused between illusion EL12 used by Kiran and GZTW 30T. I have made up my mind for GZ .
what watts do u have on ur 2 channel amp. believe me 150 watts RMS cannot power any sub to its full potential. i have tried 3 amps of 3 different makes. finally i landed up selling everything and buying jbl 75.4 amp. 284 watts RMS.
it makes a world of difference
amit_mechengg is offline
Old 24th March 2008, 14:12   #96
kumar_ranjan's Avatar
Thanked: 19 Times
I am using Panasonic CY-PA2003U Amps. The specs are as follows:
RMS Power (4 Ohms): 200 x 2 Watts
Power at 2 Ohms: 600 x 2 Watts
Bridged Power: 1200 Watts
Bass Boost: 0-15dB
Channel Operation: 2
Signal-to-Noise: 85dB
Frequency Response: 10Hz-30kHz
I guess in Bridged mode 4 Ohms RMS would be 350+
kumar_ranjan is offline
Old 24th March 2008, 14:21   #97
Bass Boost: 0-15dB
great amp that is. then u got the power to fire almost anything. where did u get the panasonic from? i was too looking at the panasonic 1200 watts RMS.
Old 24th March 2008, 16:10   #98
Thanked: 19 Times
Thanks. I had purchased the Amps from Bhandari Car Accessories located on JM road pune. You can call them ask for 1200 Watts RMS AMPS. The contact number is:
020 - 553 5323, 553 3427,
Mob: 9822097547
Old 24th March 2008, 20:53   #99
mohang_j's Avatar
Thanked: 18 Times
Where do i get JBL CS1204 woofer parameters,i could not find it in JBL website.Can somebody help.Also how do we reduce port length - i am building wedge shaped box and 4 inch/13.XX inch port will be very lengthy.
mohang_j is offline
Old 24th March 2008, 23:35   #100
hey just design a box that is similar to JBL Bass Reflex box. i have put my gt5-12" in the same box. it works amazing. i am waiting for mu GZ MK2 sub. that too i will be putting in the same box.
Old 25th March 2008, 08:37   #101
moralfibre's Avatar
Don't build a Bass Reflex box. And Amit, I have time and time again tried to explain that your box is NOWHERE close to what a Bass Reflex box from JBL is. If you do not believe me, please open the box to see what is inside. They are cheap after market lookalikes and the similarity ends there. Most people on the forum would always prefer to put the sub in a sealed enclosure.
mohang_j, PM Sam Kapasi for details of enclosure options for the JBL CS1204. He will provide you with the exact enclosure dimensions for your sub.
Old 25th March 2008, 12:55   #102
can i seal the same box and use it as sealed enclosure?
Old 25th March 2008, 13:08   #103
abhibh's Avatar
Thanked: 39 Times
No, please don't even think about that! Get a sealed or ported box made of MDF.
abhibh is offline
Old 25th March 2008, 13:16   #104
i will get a good sealed box for GZ MK2.maybe the same as moralfibre
Old 25th March 2008, 13:31   #105
moralfibre's Avatar
Poona motors / Music corner have these ready made sealed enclosure by Bassworks / BaassFx retailing for about Rs. 1,500/- for 12" subs. They also have a terminal plug making it easy for removing your sub when you have excessive luggage.
