Closed Thread
Old 3rd October 2008, 13:48   #61
sk456's Avatar
Thanked: 7 Times
Originally Posted by low_bass_makker View Post
This specific model had a problem of tripping. Please you can pass on this one.
A very generalized statement and a highly misleading statement IMO. IMO any amp can trip if used incorrectly /tuned incorrectly/driven incorrectly.
But coming back to Audison -- have seen it on many high end set ups used both in sub and fronstage configs.. works like magic.
sk456 is offline
Old 3rd October 2008, 14:13   #62
Thanked: 306 Times
Originally Posted by speedzak View Post
I have an Audison LRX 1.400! My god! My god!
I don't think we need to have another debate to prove if the amp trips or not. In a special circumstance, any amp would just lock up and go for a trip. Maybe, it was a coincidence that the above mentioned amp was taken to that circumstance more often.
But please, can we avoid another cock fight? LoL....
No intention to start the fight....I had a opinion I shared it.
low_bass_makker is offline
Old 3rd October 2008, 14:24   #63
autopsyche's Avatar
Thanked: 36 Times
Have an Audison LRx 1.400 as well, which was specifically running a single sub with no tripping issues whatsoever. I guess it just depends on how someone (mis)uses an amp, be it audison or any other brand.
autopsyche is offline
Old 3rd October 2008, 14:30   #64
navin's Avatar
Thanked: 9,957 Times
Any amp can be made to trip. Sometimes with unexplainable reason.
navin is offline
Old 3rd October 2008, 14:35   #65
hydrashok's Avatar
Thanked: 18 Times
As Gunbir said, I was running an Audison LRx1.4, using it with an IDQ12d2v2 at 4 ohms.
The amp has never tripped or gone into protection. It is very a nice amp -- I'd have loved to keep it, but it had to go, to finance my recent amp upgrade.
hydrashok is offline
Old 3rd October 2008, 15:48   #66
Sam Kapasi's Avatar
Thanked: 2,479 Times
I have heard that Skodas have a tripping problem, especially when wearing wrong shoes.
Sam Kapasi is offline
Old 3rd October 2008, 15:53   #67
navin's Avatar
Yes but did you find the reason. We could not. Even the maestro was stumped.
navin is offline
Old 3rd October 2008, 19:06   #68
abhinav.gupta88's Avatar
Thanked: 341 Times
GF or no GF, I'm told, the backseat of LBM's Swift is positively dangerous.
1. the difference between 1114W and 1000W is less than 1db.
2. the amp are rated at 14.4V. What you will get from your battery is about 13.5V so please de-rate teh amps accordingly
3. the ratings are incomplete and as such tell you NOTHING. NOthing about the max SPL you will achieve with either combination, NOTHING about the F3 you will achieve with eithr combination and defintely NOTHING about the Sound Quality. Hence I would recoommend that you USE your ears BEFORE making a decision.
Met LBM Today ( Very nice guy - Gem of a person)
I was in the front seat and beanstalk_230 in the back and both of us were like God , how about a full carton of cotton Amazing Sound / Amazing Bass / Everything amazing
1. I meant that if i have a 1201.1 (1114 w) and run 2 subs of 500w on it wont the difference of 114w make any problems
Originally Posted by panky12345 View Post
abhinav: listen BEFORE you buy! audison is said to be a good amp when it comes to power comps/ speakers only; the results wouldn't be so good when you bridge it to power a sub. but thats my experience, may be you'd like them.
Audison is crossed out of my list
It's either 1201.1 / 7001 / 14001
Wrong shoes aka wiring?
I was told by my dealer that i should not cut any wires for any ICE install as it would void the warranty ( as it is my car is new )
He mentioned to do the connections from the coupler or something called male/female.
abhinav.gupta88 is offline
Old 3rd October 2008, 19:14   #69
Thanked: 341 Times
Also are there any rattling issues with the car
LBM said there should not be. Any 1st hand experienced users?
Old 3rd October 2008, 20:21   #70
Thanked: 306 Times
There will be non if played softly but will be when played hard.
But like Bhagwan Ji say, Skoda is the best car for Iceing because of MOTA PATRA (thick sheet)..
Old 3rd October 2008, 21:08   #71
Thanked: 341 Times
As you mentioned , that loud phase is for that very moment . Not always.
And its true.
Old 3rd October 2008, 21:23   #72
nitrous's Avatar
Thanked: 333 Times
The 1114 RMS value is @ 14.4V.
In real world conditions, you're going to recieve around 13.8 only.
Plus, the gains can be trimmed accordingly.
nitrous is offline
Old 3rd October 2008, 21:42   #73
Thanked: 341 Times
how much will that translate to?
And what are the gains?
Old 3rd October 2008, 21:49   #74
shrivz's Avatar
Thanked: 96 Times
There is no harm in running a 500watt subwoofer off a 1000watt amp. The amp will run cooler and on a lower gain setting. Bass will be a lot more controlled as I have personally experienced it.
There are more chances of a person blowing a speaker by underpowering it than by overpowering it..
Let me try and explain (I'm no guru and could be wrong, but this is what I have understood)
Consider a situation in which you are running a subwoofer rated at 500watts RMS off an amplifier rated at 100watts RMS.
Your ideal power requirement is say 250watts.
Now, you turn up the volume. Your amp is producing 250watts, but its clipping at the same time. There is distortion which the human ear can hear only beyond a certain point and in most cases its too late until then. Harmonic Distortion causes the voice coil to over-heat and you end up blowing you speaker.
As I said I could be wrong, but this is as far as my understanding goes. The general thumb rule is to choose a higher rated amplifier so that you have some headroom.
Gurus, please correct me where I'm wrong.
shrivz is offline
Old 4th October 2008, 11:31   #75
navin's Avatar
Yes get the coupler. But that is not what Sam and I were refering to. I had an unusual amplifier problem in my car which was fixed but we never got to know why the problem surfaced in the first place so that was not really meant for public consumption.
navin is offline
Closed Thread
