Old 16th September 2021, 20:08   #61
scorpian's Avatar
Thanked: 1,320 Times
Re: DIY: EGR Valve Cleaning (1.3L DDiS / MJD)
Originally Posted by advaithraju View Post
Thanks for the info. Will ask MASS to physically open these parts and clean the carbon build-up in my next visit.
Incase of pipe leak there will a big drop in pick up and lots of black smoke, you will definetly feel it if something like that happens.
On my car obd shows boost of 21psi,mine is remapped please keep that in mind.
scorpian is offline   (1) Thanks
Old 17th September 2021, 20:51   #62
advaithraju's Avatar
Thanked: 22 Times
I went for a quick drive today on an empty road with the OBD and torque app running. Drove the vehicle sedately until it reached the optimum temperature and did back to back high speed runs. These are the boost figures shown as per torque app when brought close to the redline with the pedal floored. Please correct me if I am wrong:
Boost while idle: 0.1psi
1st gear:21.9psi
2nd gear:18.5psi
3rd gear: 16psi
(The whole drive was with AC off and only me as the driver.)
How can a stock engine with no performance upgrades show 21.9psi which is higher than your remapped one? Is the device or the app at fault?
Also it showed a boost of around 12psi in 2nd gear at 2.5k rpm
Now speaking about the experience, never felt something like this actually. Wheel slips when shifted from 1st to 2nd at the redline. The pull is felt only after 4k rpm in1st gear. The pull felt in 2nd gear doesn't last long. The acceleration is linear in 3rd gear. Used to drive all these days with the AC on, so maybe I never really felt the true potential of the 1.3MJD.
I also got some EGR commanded% figures. (I know nothing about this)
1.96%at idling
54% while driving
advaithraju
advaithraju is offline
Old 7th August 2024, 12:05   #63
Originally Posted by Safari_Beast View Post
ASC charges 1100 to 1500 rupees for cleaning the EGR , i find it reasonable as it takes lot of time to remove and assemble it back to ddis engine . Hyundai have placed their egr in front so its takes very less effort and time to clean the egr .
I drive a stage 1 Brezza ddis just crossed 1L km and the sa asked me to clean the egr and the estimate he gave me was 13k so I humbly denied and wanted to take second opinion on the necessity and its pricing
what’s your opinion bhpians should I do it . If yes should I do it in the Suzuki showroom for 13k or a reputable mechanic outside
Abhishek_fridjo is offline
