Old 4th August 2020, 17:00   #76
Thanked: 62,287 Times
re: DIY: Metal model engine building UPDATE: build complete (page 16)!
The chuck does not screw onto the spindle. Right?
No! Bolted down!
I just checked as I don’t think I ever ran it in reverse.
Mine has simple controls, variable RPM by means of a simple potentio meter and a three position switch reverse/off/forward.
Switching between reverse and forward gives a very noticeable difference in RPM. Much slower in reverse. Wonder why?
Jeroen
Jeroen is offline   (1) Thanks
Old 4th August 2020, 20:44   #77
Thanked: 6,234 Times
No! Bolted down!
The chuck is bolted to the backing/ holding plate. How is that plate attached to the spindle?
Sutripta
Sutripta is offline
Old 4th August 2020, 22:59   #78
Good point! Had not thought that through. But all my mates on the Dutch model building forum advised me a very strong terms not to give it a try. Especially not on a little hobby lathe like mine. Of course, all the various forces that you will create by reversing/having the blade upside down are opposite of what the lathe is designed for. So in the end I decided not to risk it.
Swapped the cylinder over and had a go at it, the conventional way. Got the RPMs up even a few more notches. Going pretty good!
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040002.jpg
A bit more tidying up with some very grit sandpaper and some very small, narrow files:
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040003.jpg
The cylinder on its support:
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040006.jpg
Turning this cast iron is very messy business. I was wearing a mask for all the dust. It gets everywhere:
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040007.jpg
I won’t be able to do much for Debbie the coming week. Getting the Spider ready and we will be out for almost a week.
So I made sure I cleaned everything very thoroughly:
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040008.jpg
Cleaned and oiled the lathe, cleaned the worksurfaces, oiled them too (WD40!), mopped the floor.
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040009.jpg
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8040010.jpg
I like everything neat and tidy for the next job!
Jeroen
Jeroen is offline   (3) Thanks
Old 4th August 2020, 23:09   #79
Thad E Ginathom's Avatar
Thanked: 30,165 Times
There's a file manufacturer in Italy that represent themselves as being as good as Swiss, but cheaper. Have you heard of them? Corradi Shop. They seem to make every conceivable file or rasp, and may that I never conceived of.
If I lived in Europe, I could probably spend a lot of money on their site. Yes, I like files
Edit: that's for USA. Maybe see here for Europe. They seem to be distributors for a heap of stuff.
Thad E Ginathom is offline
Old 5th August 2020, 09:53   #80
No, I had not heard of them before. I looked around the website. Some really nice stuff. I could do with some proper files. HBM doesn’t have anything like this. Somehow files seem to be a bit underrated in hardware shops these days.
I do prefer proper wooden handles to the plastic ones though.
Jeroen
Jeroen is offline
Old 5th August 2020, 15:33   #81
I think I've only seen files with handles in the DIY-shop ranges. Engineer/etc stuff comes bare-tanged (and I admit that I have not always fitted a handle).
These files, which I posted in the DIY thread back then, are Vallorbe, and were rather expensive
They may look like needle files, but they are not: for scale, overall length is 210mm. I was happy to see that Stefan Gotteswinter has the same set. He has modified the inbuilt needle-file-style handle by adding shrink-fit tubing.
A while back, I took my used-used file, which seemed to be worn out, and soaked it in vinegar for a couple of days. It came out sharp and fresh! And there was a lot of crud left in the vinegar.
Old 17th August 2020, 23:44   #82
Back behind the lathe/mill after our holiday! So tonight I had a go at milling the exhaust port on the cylinder.
Challenge one, setting it up in the mill. My vice is too small, so I had to improvise. I also was cautious not to damage the outside of the cylinder. So just some 4x folded paper as a little protection.
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8170003.jpg
Going well. My little mill did remarkably well, much better finish on parallel passes than before. Not sure why, same bit, same RPM, different material though, cast iron? Also, I am feeding quite slowly with very small cuts, about 0,2mm. I am not that confident of the improvised clamp down. Taking it nice and slow, with as little forces as possible.
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8170004.jpg
In the end it worked out really well. Sorry, forgot to clean properly, but it looks good and it is pretty good measurement wise too!
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8170005.jpg
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8170006.jpg
Jeroen
Jeroen is offline   (2) Thanks
Old 18th August 2020, 01:00   #83
Very good!
I guess that looked and felt firm, but I'm nervous. and I would have wanted something that prevented it flying at me if it was let go. Something at the back would be nice too. A picture of a V block is forming in my mind!
Thad E Ginathom is offline   (1) Thanks
Old 18th August 2020, 16:10   #84
The TSlot groove is taking the place of the V Block. Certainly not ideal, but workable, with some caveats. Otherwise cylindrical objects between straight parallel faces is a recipe for trouble.
Sutripta
Sutripta is offline   (2) Thanks
Old 18th August 2020, 16:53   #85
I did notice that. It gives three points of contact, which is a start. Without that, a sneeze would move the thing!
Old 19th August 2020, 12:22   #86
Last night I continued with the last tricky part of machining the cilinder. The entrance for the injection gas mix.
Had to be machined under a 70o angle.
DIY: Metal model engine building UPDATE: build complete (page 16)!-cylinder-sheet-3.jpeg
With no other means or options available to me, I swivelled the mini mill head in position once again. I dialled in the angle on the little scale on the mini mill head. Next I checked visually with a protractor. I checked all measurements afterwards and everything came out good!
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180001.jpg
I had to be very careful for clearance of the various bits of the drill as well as not hitting the cool rib. For additional safety I had also put a bolt in the T groove, locked with two nuts. It is not ideal, but it is the only option I have until I get myself a bigger machine clamp.My little poxy proxxon clamp won’t hold the 50mm diameter of the cylinder.
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180002.jpg
I am taking very slow 0,2mm passes, so the forces on the cylinder are not that huge. Took about an hour. End results look pretty good. Even though you can see a line between the two passes, you can’t feel a thing. Not with a nail or your finger. So pretty smooth surface.
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180003.jpg
With the mini mill all set up I also drilled the holes. I took the right clamp of to measure and mark the exact spot. Auto Centre punch to the rescue!
Centre drill first, obviously.
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180004.jpg
Next a 3,5mm all the way through.
Next up to 5mm for the M6 thread, 8mm depth. I still need to tap the thread
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180005.jpg
Pretty pleased with the result:
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180007.jpg
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180008.jpg
I still need to drill a bunch of holes and some thread to be tapped too. I won’t start with that until a have the various other parts ready so I can align the holes on both parts precisely and easily.
I also need to drill the intake port. Once that is done, and all the other holes drilled/tapped I will hone the cylinder again, before starting on the piston.
I aim to visit HBM this Saturday and get myself a larger machine clamp.
Jeroen
DIY: Metal model engine building UPDATE: build complete (page 16)!-p8180006.jpg
Old 19th August 2020, 20:10   #87
Super, Jeroen, well done!
Old 20th August 2020, 14:25   #88
Attachment 2044932
Good call on the longitudinal stopper.
And job well done, esp. given the resources at hand.
Sutripta
Sutripta is offline   (1) Thanks
Old 20th August 2020, 16:56   #89
I mentioned watching Adam Booth on Youtube taking half an inch off a block of steel... with a K&T mill that must weigh a ton or two. But heck, this and more, is what the machine was designed and built to do. Not to mention a lifetime of every-day machining experience and a workshop full of three generations' collection of tools.
Hats off to Jeroen and the humble Proxxon!
Old 20th August 2020, 18:46   #90
Being able to make do with what you have is a good approach for anything in live! As a former merchant navy engineer it was important too.
Even so, I have come across a couple of youtube video where this little Proxxon does pretty good. I can’t understand what is said or written, but have a look at this:
This does look encouraging for when I start machining the supports from Aluminium! I might want to practice a bit more though
But it is really slow going! To a certain degree that is also true of the lathe. But again, I never bought these machines with this sort of work in mind. If I ever upgrade, I do know much better what to look for.
Just soldiering on and very much enjoying it. Thanks for all the encouragement.
Jeroen
