Old 7th February 2014, 22:42   #12481
rameshnanda's Avatar
Thanked: 1,240 Times
Re: The DSLR Thread
Any particular reasons for an upgrade? Because if not into serious photography, do you really need that as an upgrade is the question.
My take : slowly you should build lens fire power. Unless and until you push the limits of your current camera to extreme, you should not feel the need to upgrade. (If I remember through one of your TLs, you have a D7000 right? )
Of course you know your needs better. But just trying to make the point that don't go for an upgrade till you have not pushed your current camera to the maximum.
I have a 4 year old 550D Canon. I am still OK with it for landscapes and other snaps. But I built up on lens based on checking out my own shooting profile preferences.
No Amp. I am not looking at upgrading immediately and totally agree with your point of exploring the limit of my current camera.
Most importantly I fully agree with what ampere has stated below - upgrade only if you must, not coz you want the latest and greatest, and before upgrading the body, upgrade/invest in better lenses. If you have a D7K with DX lenses, you'd be better of purchasing FX lenses which can be expensive rather than buying a Df. The camera body should be the last to be upgraded.
Thanks. After I got D7000, the only DX lens I have is 35mm and the 11-16 Tokina. My 24-85 and 70-300 are FX lenses.
rameshnanda is offline
Old 8th February 2014, 08:29   #12482
R2D2's Avatar
Thanked: 5,858 Times
Re: The DSLR Thread
The 24-85 and 70-300 (assuming it's the VR II version) are good enough to start with, but you could get better ones to work with a D800. The D800/E is pretty sensitive to the quality of glass. Just IMO of course.
Ok, let me throw this whole thing for a loop, IF and a very big IF you are serious about a full frame camera, consider getting a D610. You will get a very good FX camera and save money. Use the money you save for some renowned lenses like the 24-70 F/2.8 and/or the delicious 70-200 F/4 or 70-200 F/2.8. Not right away...maybe some day down the line.
With a 24MP D610 you wont be bogged down by the massive files the D800/E can generate, saving still more on a possible PC upgrade. Trust me, you will be happier overall. The camera body should be the last on your upgrade list.
BTW, Nikon is offering rebates on camera + lens combinations right here in India...no I am not smoking any strange substance. Looky here:
http://www.nikon.co.in/en_IN/about/e...nikon&Section=
Good luck!
R2D2 is offline
Old 8th February 2014, 08:34   #12483
Re: The DSLR Thread
Good luck!
Thanks again R2D2. Yes, I have the VR version of 24-85 and 70-300.
A dealer in Chennai offered me the Df at 1.55 and D800 at 1.56. That is the reason for me to get tempted. Anyway, I have now decided to put this on hold for now and instead get a good FX glass as you suggested.
Old 8th February 2014, 09:38   #12484
ampere's Avatar
Thanked: 13,649 Times
Re: The DSLR Thread
Started with Kit lens. In 6 months, got the 50mm prime when I realised I needed to get portraits in low light. Played a lot with that lens. In another six months, I realised I need a telephoto. Some suggested 55-250 while some 70-300. Ditched both and bought the 70-200 F4 IS L. Did not repent that decision one bit, as I am not into birding and 200mm is more than enough for me. 70-200 was perfect all round walk-though lens. Awesome glass. Still having a great time with that lens. Another six months to one year down the line, I realised 18mm of the 18-55 is not wide enough. Needed an Ultra Wide angle. Invested in a 10-22. So my outdoors were well taken care off with 10-22 and 70-200.
Though 10-22 is an APSC mount and 17-40 would have been nice, but since I am on an APSC body thought other wise. 3 years down the line felt need for aspects. Firstly was not satisfied with 50mm portraits. Was looking for something better. But 50mm 1.4/1.2 or 35mm were not solving my needs. Rudra gave a perfect class on how to get the 50mm work for oneself. Esp. the lens and its working length. At the same time, I was also looking out for macro learning capabilities. Combined the two and ended up buying the 100mm Macro IS L. Initially thought of non-L and then bought the L because of IS and could get it for good portraits as well. 100mm Macro is a super performer and in many cases, I use it more often than 70-200 in the outdoors too. Brilliant portraits on the outdoors.
But with all this not one for instant felt my 550D is under-performing. True its ISO performance beyond 400/800 is not all that great. But for such cases I think spending a 30K on a flash would better than the 1/1.5L FF frame new body. To summarise perfectly at peace with current set-up.
The other significant investment I think which is paramount is setting you work flow very clean. It should be seamless and also lend itself to back-ups. Else all the work can go down the drain. With that aspect I am on MAC with Aperture (LR like). May be its not that great compared to Adobe. But with integration to all the filters, it works seamlessly. I don't know if there many Aperture users out there.
ampere is offline
Old 8th February 2014, 12:54   #12485
R2D2's Avatar
Re: The DSLR Thread
With a minor difference like that I'd definitely take a D800. The Df doesn't quite float my boat.
From your current set of lenses me thinks you are into landscapes, walk-about & people photos. If that's true the 70-200 F/4 and/or 24-70 F/2.8 will bring a smile to your face.
If you want to have only one good lens it's the 24-120 F/4. Classic walk about lens.
Between the 3 suggestions my order of purchase would be:
a) 24-70 (this is also the most expensive)
b)70-200
c) 24-120
Hope this helps!
Cheers!
R2D2 is offline
Old 8th February 2014, 15:01   #12486
Thanked: 3,034 Times
Re: The DSLR Thread
Inspite of the lucrative price, I would still recommend the D610, and your dealer may have it at a lucrative price also. The sensor is as good and the files smaller, so unless you need 36MP for large prints or severe cropping, the 610 is a better proposition. Add a 300mmF4+TC1.4 and you have a perfect hand holdable wild life rig.
Aroy is offline
Old 8th February 2014, 19:46   #12487
amitoj's Avatar
Thanked: 3,508 Times
Re: The DSLR Thread
Originally Posted by amitoj View Post
But latest CC version has a filter that is supposed to treat camera shake as well (although however i tried i could not get it to work on the trial version that i have).
I had posted in Adobe Support forums about this problem and got a reply the very next day by an Adobe staff member! Amazing support! I am a fan!
amitoj is offline
Old 11th February 2014, 21:50   #12488
Unknownsatan's Avatar
Thanked: 1,537 Times
Re: The DSLR Thread
Hi all,
I use a 600D and is looking for a lens now. Now I have seen 2:
1. 18-200 (Tamron)
2. 55-250 (Canon)
Pricewise not there is not much diff
200-250 range may not matter much for me
I am inclined to 18-200 because otherwise I have to keep changing lens.
Now my question is, is there any difference in the picture quality taken in the range of 55-200 with both these lenses?
Unknownsatan is offline
Old 11th February 2014, 21:58   #12489
Re: The DSLR Thread
Got a call from my dealer today. He offered me the following prices.
D610 - 1.06
D800 - 1.48
Df - 1.515
Old 12th February 2014, 11:10   #12490
Re: The DSLR Thread
D610 - 1.06
D800 - 1.48
Df - 1.515
Go for the D610. 24MP is more than enough resolution and 2 SD cards are, in my opinion, better than 1 SD and 1CF card. The 610 has 2 User modes, which are lacking in the 800. User modes let you save setting.
Aroy is offline
Old 13th February 2014, 08:20   #12491
Re: The DSLR Thread
b)70-200
c) 24-120
Hope this helps!
Cheers!
If I get the 24-70, why would I need the 24-120? I think 24-70 (with 70-300 or 70-200) would do the job well.
Old 13th February 2014, 09:09   #12492
R2D2's Avatar
Re: The DSLR Thread
The 24-70 is a f/2.8 and the 24-120 is a f/4. The former lens weighs 900g and latter 670g. Choose any one of them. To quote:
R2D2 is offline
Old 13th February 2014, 09:23   #12493
ampere's Avatar
Re: The DSLR Thread
Same Confusion in Canon World.
24-70, 24-105, 70-200. (All L series). And on top Canon has multiple flavours of F stops.
24-70 F2.8/F4
24-105 F4
72-200 : F4zF/2.8 IS/no-IS (IS is VR in Nikon world)
Why should one buy 24-70 F4 compared to 24-105 F4? But one thing is clear. In Canon world 70-200 glass is notches above 70-300. So if one is not interested in the 300 mm range and has the cash, 70-200 is a perfect choice.
ampere is offline
Old 13th February 2014, 11:27   #12494
Re: The DSLR Thread
24-70 F2.8/F4
24-105 F4
A low cost alternate to the 24-70 is Tamron 28-75, I bought it and very pleased, tack sharp.
skartik2 is offline
Old 13th February 2014, 12:03   #12495
anujmishra's Avatar
Thanked: 529 Times
Re: The DSLR Thread
I agree 100%. But, I want to add more into it. Canon/Nikon 70-200 are insanely priced. You can get better alternatives in Tamron/Sigma. I have already got Sigma 70-200 F2.0 OS and quite pleased with its sharpness & performance. It costed me less than 50% of equivalent Canon. Two pages back I posted image of my 70-200 F2.8 OS (IS, VR, OIS, VC)
anujmishra is offline
