Old 8th April 2014, 22:55   #12616
ampere's Avatar
Thanked: 13,615 Times
Re: The DSLR Thread
Originally Posted by Karthik1100 View Post
Thanks Amp. Yes, have decided on D3300 with Kit lens and 50mm Prime. There is 50mm f/1.8D at 5.5k and 50mm f/1.8G at 9k. Which one to buy?!
No idea on that one Karthik. I am on Canon. So no idea on G vs D versions.
Also, can you guide me from where to buy these in Bangalore for best prices. GK V, EGK, Croma, Whizz, Ezone etc are some of the options.
I mostly get things from FotoCricle. He is a south India distributor for Nikon and Canon. Maybe online prices would be lesser. But I prefer going there and buying.
His main outlet is at Anand Rao Circle. He also has a showroom Koramanagala on the 80 Feet road next to Ganapathy Temple.
ampere is offline
Old 8th April 2014, 23:10   #12617
NetfreakBombay's Avatar
Thanked: 1,130 Times
Re: The DSLR Thread
You need to buy a 35mm lens since that would become ~50mm on D3300 (35*1.5).
It would cost 7.5k : http://www.flipkart.com/nikon-af-s-d...CXGEQHJVZ8QEB&
In stores, cost would be around 9k.
Just one note, "AF Nikkor 50 mm f/1.8D" will not work with D3300 (I.e. lens will work in full manual, but will not auto-focus).
NetfreakBombay is offline
Old 9th April 2014, 10:13   #12618
Karthik1100's Avatar
Thanked: 803 Times
Re: The DSLR Thread
Thanks Amp, will check out this store today.
Thanks for this info! Can you please tell me more about "50mm on D3300 (35*1.5)."
Karthik1100 is offline
Old 9th April 2014, 10:44   #12619
Thanked: 830 Times
Re: The DSLR Thread
I have selected Nikon D3300. D3300 comes with Kit lens 18-55. My doubt is for my requirement, is the 18-55mm lens enough? Or should I buy the 55-200mm lens too in the combo offer, where 55-200mm costs 9k.
There would be situations where you would want a close up of the subject without getting too near. So 55-200 makes a lot of sense. Also ask them if they can give you 18-105 instead of these two lenses. I would have recommended 18-200/18-300 but they are way too expensive. One zoom with a wide range offers the convenience of not having to change lenses.
Lovely shots! What's the rim and tyre size on your Multijet?
directinjection is offline
Old 9th April 2014, 11:39   #12620
Thanked: 347 Times
Re: The DSLR Thread
You can have better explanation in Dpreview Article (read Sensor size )or this wiki article. All Nikon APS-C camera's have Crop factor 1.5 and lens focal length are marked w.r.t to 35mm film or Full frame (even for Dx lens). Hence whenever you use certain mm on lens on APS-C camera, effective filed of view (when compared to Full frame) is same as focal length X crop factor of the sensor.
RaguHolla is offline
Old 9th April 2014, 15:53   #12621
Thanked: 904 Times
Re: The DSLR Thread
I broke the 18-55 kit lense on my Nikon D3100, and ended up buying 70-300 one on an emergency basis without any research and with an assumption that I'll be able to get the lense repaired later.
Sadly it seems repair won't help matters, and now I'm inclined towards buying either the 18-55 or some suitable replacement. Need is not specific, just the usual indoor pics and occasional outdoor ones where 70mm doesn't serve the purpose. Talked to a friend and he suggested 35mm 1.8g.
I want to know if this would be a suitable replacement? I am willing to spend upto 25K if a single lense can serve the purpose for most needs below 70mm.
avisidhu is offline
Old 9th April 2014, 16:11   #12622
Re: The DSLR Thread
35mm 1.8g is a pretty good lens for indoors since it lets in so much more light.
I would recommend purchasing another 18-55 + 35mm.
Old 9th April 2014, 17:26   #12623
jkdas's Avatar
Thanked: 1,497 Times
Re: The DSLR Thread
The 50mm's are a pain to use if your cam doesnt support auto focus of it. I have a brand new one which I have put aside for sale since its a pain to use when needed without autofocus.
The 35mm is a nice lens. Get it but you will need the 18-55 too.
jkdas is offline
Old 9th April 2014, 17:41   #12624
Thanked: 904 Times
Re: The DSLR Thread
Thanks for your inputs guys. If that's the case then will buy both.
Inquired about the prices, 35mm is 9K and 18-55 is retailing for 5.5K. I'm hoping the prices are not on a higher side.
Would I have to then buy another one if some day I intend to try those wide angle shots many of you so beautifully capture?
avisidhu is offline
Old 9th April 2014, 18:23   #12625
Thanked: 2,097 Times
Re: The DSLR Thread
I have both the 35 mm and the kit lens. But my daily driver is the 35 mm. Of course it means that you have to move closer to or farther from the subject. As far as focusing is concerned, I prefer to use M/A mode rather than fully auto mode and manually focus. This gives much better pics. It is quite easy to learn to focus manually and is really useful when shooting crowded frames.
For ex, if i'm shooting a pic of my daughter playing, in auto mode, the focus is often the toys in the foreground. With manual focus it is easy to correct. It is especially useful when shooting a frame with many people. My wife never complains that she is blurred.
And it is a very fast lens.
Using D3100 with 35 mm f/1.8G lens.
wildsdi5530 is offline
Old 9th April 2014, 18:27   #12626
Mr_Bean's Avatar
Thanked: 241 Times
Nikon D3200 (or) D5100 for a beginner?
Folks,
I have experience using a "point and shoot camera", no in-depth idea of lenses.
Please suggest a good DSLR camera, I have the D3200 and D5100 in mind, my budget is 30K inclusive of basic lens provided in the kit.
I am keen on using my DLSR for basic video recording also, my budget does not permit me to buy a camcorder in addition to a DSLR.
Rgds,
Mr_Bean is offline
Old 9th April 2014, 20:37   #12627
Re: The DSLR Thread
I would recommend getting 35mm from Flipkart for 7.5k (next day delivery + cash on delivery).
18mm is pretty wide to begin with. I think you can wait for wide angle lenses since those cost 30k+.
I would suggest Nikon D3300 and Canon 1200D. Both cost 31 - 33k and have similar capabilities. Out of these two, D3300 is better in Video.
Old 10th April 2014, 11:14   #12628
Thanked: 3,010 Times
Re: The DSLR Thread
For most of your "baby" shots the 18-55 kit lense is enough.
The "D" lense does not have a built in motor, so you will have to focus manually. Avoid it if you are not used to manual focus. I have the previous version of this lense, but then I was brought up on manual focus.
I would advise you to get the AF-S DX 35mm F1.8, instead of the 50mm. That will give you a good low light lense. If you want a bargain, then search the e-retailers - Flipkart, Snapdeal, Amazon. They are basically front end for a lot of sellers. The advantage over small e-retailers is that they manage the whole sale from collecting money to delivery. I bought both my D3300 and the 35mm F1.8 lense on the net.
Here are some links
http://www.amazon.in/gp/product/B001...d_i=1320006031
http://www.flipkart.com/nikon-af-s-d...1-1159ad8d0cba
http://www.snapdeal.com/product/niko...-f-18-g/416896
Mind you the prices keep changing so check all the sites.
Aroy is offline
Old 11th April 2014, 12:33   #12629
PatienceWins's Avatar
Thanked: 985 Times
Re: The DSLR Thread
35mm is a very good lens, very good for low light photography and bokeh. It is the only lens I use for indoor photography. The price was 14k when I bought it 6 months back. With the crop factor, it becomes a 50mm lens on my D5100. It is really value for money at the current price.
I use 18-55 for outdoor photography - suffice for most of the uses. Planning to get a 18-140 for a better zoom range.
PatienceWins is offline
Old 11th April 2014, 12:42   #12630
sumathindra's Avatar
Thanked: 569 Times
Re: The DSLR Thread
I would suggest go for a 18-200. This will be a general purpose lens and you will never have to remove it till the time you want to go for higher lenses.
sumathindra is offline
