Old 28th May 2014, 21:05   #12796
nilanjanray's Avatar
Thanked: 2,946 Times
The 'new' Nikon 80-400mm AF-S VR
So I was playing around with the Nikon 80-400mm AF-S lens, which weighs appx. 1kg more than the lens I usually use.
The latest generation VR (IS for Canon folks) is extremely good. I am yet to shoot it in the field (I will be renting it for my upcoming Kanha/Tadoba roadtrip), but I am able to take sharpish handheld photos at 1/60s at 400mm, and even some at 1/20 sec at 400mm.
It is easier to shoot (balance) when fully extended - feels like shooting a smallish gun.
In the field, I will probably maintain a minimum shutter speed of 1/150s just to be safe, depending on the light situation. But it is good to know that one can shoot at 1/60s if required.
The AF is fast - seems marginally faster than the 70-300mm at the moment.
The tripod collar is a pain. Too small to hold it and carry the lens. And it gets in the way.
I plan to handhold the lens 100% of the time, no monopod or beanbag. Will need to figure out a way how to rest the weight for hours at an end, yet be ready to shoot fast.
So here is what you have to do to get 100mm extra reach in the Nikon telezoom world:
1. Carry 1kg more weight
2. Pay 1.5Lakhs extra, if you were to buy the new 80-400 over the 70-300mm AF-S
nilanjanray is offline
Old 31st May 2014, 08:48   #12797
Thanked: 1,793 Times
Sensor cleaning advice
Once in a while I take a blue sky photo at infinity/f16 to check for sensor dust by jacking up contrast all the way up. I noticed a few spots, one of which is almost certainly oil, on my 2500 actuation old nikon d610, that were not there when it was new.
Now for my actual use, since these aren't going to be a problem, I am going to ignore this.
However, a couple of questions to anyone that has successfully dealt with this:
1. If they don't matter to picture taking, is there any problem in just leaving things the way they are, until picture taking is affected? Leaving a sensor undisturbed isn't going to make a spot more difficult to take out later?
2. Assuming that one wants to do the cleaning at home, is there any good pointer/link to best practice?
PS: Some research turned up this answer to Q2:
http://www.howtogeek.com/162413/how-...s-dslr-sensor/
Seems very sensible advice on the how to.
Sawyer is offline
Old 31st May 2014, 10:11   #12798
M35
M35's Avatar
Thanked: 2,880 Times
Re: The 'new' Nikon 80-400mm AF-S VR
Have you tried using a Tele-converter, say 1.4X, with your 70-300mm for the extra reach ? I know it is better suited with a f 2.8.
I have been thinking of getting one for my 55-300. I am fine shooting wildlife manually and I assume in day light it should be fine.
Anyone tried a Tele-Converter [1.3x or 2.0x] with a f/ 4.5 Zoom lens ?
M35 is offline
Old 31st May 2014, 10:48   #12799
NetfreakBombay's Avatar
Thanked: 1,128 Times
55-300 is a DX lens, I.e. glass element is quite close to mount. Nikon TC will not mount on this lens.
You need AF-S 70-300 lens (or cheaper manual 70-300) for TC.
Alternatively, you can use Kenko TC if you have 7100 or better camera that can focus at F8 (Nikon does AF at aperture wide open even if shot is going to be taken at higher F number).
NetfreakBombay is offline
Old 31st May 2014, 11:11   #12800
R2D2's Avatar
Thanked: 5,852 Times
Re: The DSLR Thread
The Nikon 70-300 and 55-300 are not compatible with any Nikon TC. Please check compatibility charts before purchasing.
ttp://www.nikonsupport.eu/europe/Manuals/DrdIaQvRZv/TC_converter_compatibility-EN_01.pdf
R2D2 is offline
Old 31st May 2014, 11:22   #12801
M35
M35's Avatar
Re: The DSLR Thread
Thanks for the reply.
I know the 55-300 DX [In fact No DX lens is] isn't compatible with a Nikon TC. I am contemplating on a Kenko DGX MC4 or Pro 1.4x TC.
You meant AF, I assume. I know 55-300 AF is slow in the first place. On a D3100 +TC , it only gets worse.
Will a D3100 + Kenko TC [1.4x] + 55-300 at f/4.5 f work for manual focus for fast wildlife shots?
M35 is offline
Old 31st May 2014, 12:13   #12802
R2D2's Avatar
Re: The DSLR Thread
A 1.4x TC drops your aperture by 1 stop. So your F/4.5 lens will be approx. F/6.3.
It will work with MF and AE for sure but the drawback is the viewfinder also will become slightly dimmer making it hard to use MF. Personally if you ask me you are better off upgrading your lens than buying a TC.
R2D2 is offline
Old 31st May 2014, 12:53   #12803
Re: The DSLR Thread
It should work with Kenko 1.4x in full manual.
Noticed that TC is available on rent for 500 Rs and Sigma 150 - 500 for 1800 Rs.
Might be a good idea to try both before buying (might be cheaper to rent Sigma 150 - 500 or Nikon 80-400 for few days as compared to buying TC).
Old 31st May 2014, 18:24   #12804
Thanked: 3,007 Times
Re: The DSLR Thread
That is quite steep. The TC is around 25K. Rent the long zoom and try it out. Not only AF is slow at F6+ but the quality of the zoom is nothing to boast about and becomes quite soft at the long end with the TC.
TC is viable with fast Super Telephoto primes, the IQ suffers a lot with lower end zooms.
Aroy is offline
Old 2nd June 2014, 10:31   #12805
JASMEET MATTOO's Avatar
Thanked: 273 Times
Re: The DSLR Thread
Noticed that 5200 is now available for 37k on Flipkat by "WS Retail".
I would recommend 5200, but this is subjective.
I have 5300, these are the benefits of 5300 over 5200
1. Higher ISO + better image quality since it removed one filter from sensor.
2. WiFi (you can take pictures from cell phone, it acts as a viewfinder for DSLR)
3. GPS
I do not find WiFi that useful and GPS is mostly used for travel/vacation photos (E.g. you can quickly sort all photos taken in Coorg / Delhi) .
Thanks for your suggestion and to everybody else for their inputs. I just got my Nikon D5200 with a 18-55mm yesterday from Croma. The cost is Rs.41650. They had a scheme running which according to them closed on 31st May, but when I insisted to the staff the same scheme was given to me. Here are the list of freebies :
1) An Additional 16 GB card M.r.p Rs.850 (8 GB card is already being given as a standard feature)
2) A tripod (M.r.p 1200)
3) A 2600 Mah powerbank charger for mobiles/ tablets M.r.p Rs.2000
4) Disc cleaner CD M.r.p Rs.200.
Yesterday evening pretty much went into exploring the same. Got to get ready for the clicking spree.
My one and a half year wait comes to an end
JASMEET MATTOO is offline
Old 2nd June 2014, 16:49   #12806
M35
M35's Avatar
Re: The DSLR Thread
TC from Kenko doesn’t cost 25k but in the 10-15k range. Also the Nikon TC isn't compatible with my DX 55-300.
Even with no TC, there is nothing to write home about, the AF performance of my D3100 + 55-300mm VR for fast shots in the first place. And closer you get towards the 300mm, softer gets the image. With the subject even in slight motion, it simply doesn’t focus, when you want it to, hence doing it in full manual these days.
Thanks all for the replies.
Just ordered a Sigma 150-500mm today. Should reach in a couple of days.
Now I will have the following lenses to be used with my humble D3100
  • Nikon 50mm f/1.8 D for portraits and Macro with Extention Tubes + LED flash ring lights
  • 10-20mm F4-5.6 EX DC (HSM) for ultra wide angles [ bought recently]
  • 150-500mm F5-6.3 APO DG OS (HSM) for super telephotos
Gotten rid of the following.
  • Nikon AF-S DX NIKKOR 55 - 300 mm f/4.5-5.6G ED VR
  • Nikon AF-S DX NIKKOR 18 - 55 mm f/3.5-5.6G VR
Never knew this DSLR thingy is so additive and an ever expensive affair !
M35 is offline
Old 2nd June 2014, 17:53   #12807
Re: The DSLR Thread
That's cool, how much did 150-500 cost ?
Yes, it can cost more than a hatchback
Old 2nd June 2014, 18:32   #12808
M35
M35's Avatar
Re: The DSLR Thread
USD 860 = around INR 50k
Sigma 150-500mm
Flipkart sells it for around 62k at 9 % discount [ of the original price of 68k]
M35 is offline
Old 3rd June 2014, 06:22   #12809
govigov's Avatar
Thanked: 1,219 Times
Does anyone know if the Tamron 150-600 is available for purchase locally?
govigov is offline
Old 3rd June 2014, 11:54   #12810
Re: The DSLR Thread
Originally Posted by govigov View Post
Tamron 150-600
Available on Amazon, price seems to be on a higher side. Should come down in couple of months.
http://www.amazon.in/gp/offer-listing/B00HR6IPSE/
