Old 25th April 2020, 23:01   #5461
Thanked: 987 Times
Re: The Laptop Thread: Configs, deals & questions
Aliexpress is your friend here. Get the exact model number and search for the display on Ali. 99.99% you will get the exact OEM part at a reasonable...
I actually already tried that and it costs $150 which is a big gamble for me not worth the effort.
May be I will end up getting up wireless keyboard and mouse I already have and make use of it.
raksrules is offline   (1) Thanks
Old 26th April 2020, 10:34   #5462
rahulcmoulee's Avatar
Thanked: 992 Times
My Lenovo Yoga 370 conked out last night. Doesn't power on with or without power supply. Any ideas as to what might have gone wrong?
rahulcmoulee is offline
Old 26th April 2020, 12:58   #5463
diyguy's Avatar
Thanked: 588 Times
Open it up, reseat the RAM and the CMOS battery. Happened to my Lenovo when I was on business travel and this worked for me.
diyguy is offline   (1) Thanks
Old 26th April 2020, 13:27   #5464
GT3
Thanked: 400 Times
My Asus laptop suddenly turns off immediately(not shut down) when it runs on battery even if its 100% charged but it runs without any issues when its plugged in. When it is being charged it says "plugged in". I checked the battery report and it seems to be in good condition. I also disconnected and connected the battery. Can anyone tell what might be the issue.
GT3 is offline
Old 27th April 2020, 08:58   #5465
gautamkhadse's Avatar
Thanked: 314 Times
Originally Posted by GT3 View Post
My Asus laptop suddenly turns off immediately(not shut down) when it runs on battery even if its 100% charged but it runs without any issues when its plugged in. When it is being charged it says "plugged in". I checked the battery report and it seems to be in good condition. I also disconnected and connected the battery. Can anyone tell what might be the issue?
If you have windows 10
Open CMD ( Run as administrator )
type CD\
type powercfg /batteryreport
This will put a battery report on your C :
Read the battery report and check how old is the battery its rated capacity vs what capacity is it capable of today.
For instance, my ASUS ROG GL 502 VT came with a 64mWH capacity battery. Today even at 100% it just holds 23mWH and it about 5 years old. So it has regenerated over the years and doesn't hold a charge to its full capacity.
Reference :
https://windowsreport.com/laptop-bat...th-windows-10/
gautamkhadse is offline   (7) Thanks
Old 27th April 2020, 09:08   #5466
sagarpadaki's Avatar
Thanked: 6,810 Times
type CD\
Reference :
Wow! This gives a very comprehensive report!
Thanks!
sagarpadaki is online now
Old 27th April 2020, 11:51   #5467
GT3
Thanked: 400 Times
This was the same thing I did to get the battery report bro. My rated capacity was 34,560 mWh and my current capacity is 28,360 mWh. In this case what to do bro?
GT3 is offline
Old 27th April 2020, 13:07   #5468
Rohit_Quad's Avatar
Thanked: 351 Times
Ok, I have another option - Download HW Monitor - https://www.cpuid.com/downloads/hwmo...nitor_1.41.zip
Download and run the correct version - mostly 64bit english.
In the attached image, you can see 'Wear Level' under the battery (at the bottom of the image). That will give you a fair bit of idea of your battery status.
I feel that your battery's capacity to hold charge is gone and hence, the switching off when power is unplugged. Post an image here, it might help others to understand the status of your battery.
The Laptop Thread: Configs, deals & questions-capture.jpg
Rohit_Quad is offline   (1) Thanks
Old 27th April 2020, 13:33   #5469
GT3
Thanked: 400 Times
Here is the screenshot bro:
The Laptop Thread: Configs, deals & questions-screenshot-1.png
GT3 is offline
Old 28th April 2020, 11:38   #5470
Rohit_Quad's Avatar
Thanked: 351 Times
Attachment 1999168
Not sure what the issue might be, could be some internal IC issue. Can you post the battery specs? How old is the laptop/battery?
Old 28th April 2020, 15:36   #5471
GT3
Thanked: 400 Times
Mine is a 3 -Cell 36 Wh Battery and my laptop is 2.5 years old.
GT3 is offline
Old 30th April 2020, 10:51   #5472
RaceHorse's Avatar
Thanked: 340 Times
Check for the blinking pattern of the power indicator. If it blinks 5 Times white and 2 times Orange then it signifies RAM issue.
It might be the case of RAM slot getting lose. You need to open the Laptop and change the slot. It worked for me on my Dell Laptop. Hope it helps.
RaceHorse is offline
Old 1st May 2020, 03:44   #5473
JMaruru's Avatar
Thanked: 430 Times
Re: Dell 'Vostro' HDD Upgrade?
I would like to upgrade the HDD on Dell 'Vostro' 1440 to SSD.
The stock HDD is '320GB 5400RPM SATA Hard Drive'.
1. Can I upgrade to 512GB SSD for this model?
2. Also, What I need to look out for in the SSD so that it is compatible?
Please advise!
JMaruru is offline
Old 1st May 2020, 05:44   #5474
Joxster's Avatar
Thanked: 2,230 Times
Please advise!
1. Yes, you can upgrade to a 500+GB SSD. You can go for a higher capacity if you want as well.
2. The only requirement that you need to look out for in terms of compatibility is to ensure that it is a SATA SSD.
Joxster is offline   (1) Thanks
Old 1st May 2020, 12:18   #5475
Please advise!
1. You can upgrade to 2TB SSD if you need. No issues with that.
2. It should be a SATA SSD. Crucial MX500 is what i have since past couple of years and it is one of the best out there. Samsung, Kingston, WD are other reputable brands.
I use this one.
https://www.amazon.in/Crucial-MX500-.../dp/B0786QNS9B
sagarpadaki is online now   (1) Thanks
