An end of the year break is not complete without a long bike ride. This time I had some routes in mind and although almost all the routes are repeats of what I had done years ago on my Bullet, it felt different because of the many changes over the years to the roads and riding a faster bike.
Unfortunately, I ended up doing the ride on the first day of a long weekend or week for most of the people in Bangalore. I knew it will be bad, but was in for a surprise. The ride plan was to head to Sakleshpur and cover the Shirdi ghats and head back, depending on the road conditions post Sakleshpur. I left home by around 530am and actually ended up leaving at 545am after realising I left my phone after riding for couple of kms. The traffic jams started nearing Tumkur road via the Hebbal ring road and from there the traffic density was high all the way to Tumkur, but was even bad on the Hassan highway. I escaped most of it since I was on a two wheeler and I cut off to the service road at one point before Nelamangala. The main carriageway was clogged for most part and this was around 615am. After noticing the number of vehicles cutting off towards Hassan, I changed the plan and headed towards Tumkur which was a bit better.
The ride after Tumkur was much better and enjoyable with the cool weather and heavy fog in some parts. The traffic was almost nil on the newly made 6 lane highway which for most part is complete except for the bypasses. The sceney on this route has changed drastically from what it was earlier, but now the travel time is much shorter when heading towards Shimoga.
The K1000 rally was in progress outside Gubbi which I got to know after chatting with a driver at a roadside breakfast joint. I had half a mind to stop and have a look, but remembering a Special stage I attended near Nelamangala years ago and how much I had to wait for some action, I continued on my ride which was to be a long one.
I was cruising at around 90kmh which is what I have settled at on most rides. It is comfortable for me, good on the fuel efficiency side, wind blast is contained and safe for our highways as well. I planned on going to Chikkamagalur on a road I had done on my car few years ago but forgotten which town the cut off was at. I checked the map I noticed the cut off from Kadur which I thought was the same one, but infact it was the next cut off at the town of Tarikere. The route via Kadur, I had done on my 500 earlier around 2014.
I reached Chikkamagalur quite fast from Kadur and was deciding on the next route and decided to head to Sakleshpur via Mudigere. What I didn't realize was the holiday makers whom I saw in droves leaving Bangalore had reached the Western ghats after fighting it out on the Hassan highway and I was in the opposite direction of their travel on the narrow hilly roads. Thankfully after cutting off from Mudigere to Sakleshpur, it wasn't that bad and it nice curvy well paved roads. I reached Sakleshpur and the highway across the town was jammed solid in both directions for kms. Lucky for me that I was on a bike with no pannier boxes sticking and the well behaved traffic that I was did the full stretch of the jam for around 5 kms in the gap between lines of traffic. The locals were nice enough to even give me way without having to honk. Compare that to Bangalore traffic where I have experienced drivers blocking my way at a signal when I have enough space to pass.
Post Sakleshpur it was an uneventful ride since the roads were clear ahead and behind me because of the jam. The Sakleshpur to Hassan highway is done on one side with concrete topping, but it was one of worst surfaces I have ridden on. The traffic on the opposite side was still high all the way and I was thanking my stars that I decided in the morning not to take the Hassan highway.
I took the Hassan bypass and continued towards Nelamangala and the road from the looks of it has been relaid recently. Less traffic, afternoon time and probably having woken up early, led me to be extremely drowsy. I couldn't find a spot to stop either since there were no shade or trees for most part. I reduced the speeds to what I do on my Bullet which was around 70 kmh for around an hour which made me feel even more drowsy. Finally, with around 100 kms left, I found a nice clean bus stop with a shade and dozed off for few minutes which helped. The ride from there was quick mainly because half of Bangalore had left town and the roads were not congested.
The bike performed perfectly as always. The engine keeps getting smoother and more responsive after every long ride. The fuel efficiency was the highest till date which was 33.33 kmpl. I have gotten used to the new seat as well which is not as painful as the previous ones and I can manage more than hour before a break. The only issues was the wind blast in my helmet and that is because of the windshield which I am planning to remove and put back the fly screen. Having wind hit the full upper torso should be better than just the helmet.
Covered 565 kms and the odo stands at 11300 kms.
Topping up at a fuel station at Kadur.
Between Chikkamagalur and Sakleshpur.
A small note of the tyres. Although the CEAT tyres has not had much good opinions, I feel they do the job. Maybe not for racetrack kind of riding, but for normal riding and some high speeds, it does fine. The only drawback is when hard braking where the rear becomes lifeless and not knowing if the ABS actually worked or not.
Finally found a place for some shut eye.
