Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 219,840 views |
9th July 2014, 16:18 | #46 | |
BHPian Join Date: Aug 2005 Location: Cochin
| Re: Understanding Car Air-Conditioners Quote:
Oh, OK thanks, so the idea behind should be like this, as you indicated in your earlier post the refrigerant is shared between front/back compressor, so for better refrigerant cooling they might have kept it controlled from the front switch itself, is this be the possibility? Thanks for the clarification, so the A/C compressor gets de-activated once the specified temp is reached, that seems to be good. I was more worried on this part, and in my short span of ownership I never tried these things as well. thanks for the info Last edited by Manoj : 9th July 2014 at 16:20. Reason: Quote didn't came up properly | |
() Thanks |
14th July 2014, 23:44 | #47 | ||
Senior - BHPian Join Date: Sep 2006 Location: zxc
Thanked: 726 Times
Even if the cooling coil is dirty, some cooling will be there. I assume installation was done by an expert mechanic, But make sure he tuned the thermostat and expansion valve to the setting just so. Quote:
AC unit is single but with dual cooling coil in a closed loop. It has control for fans only. AC condenser switch off- i assume you meant AC compressor. Condenser is nothing but a kind of radiator. It even looks the same and sticks in front of radiator. All AC Compressor gets switch off, even home ones, (except newer inverter ones) after a predetermined temp is reached. | ||
(2) Thanks |
The following 2 BHPians Thank SirAlec for this useful post: | dr. sen, Perakath |
24th July 2014, 16:59 | #48 | ||||||
BHPian Join Date: Feb 2009 Location: Chennai
Thanked: 31 Times
| Re: Understanding Car Air-Conditioners This is a really useful thread! Thank you everybody Quote:
A couple of other questions: (1) I had some issues with window a/c's at home recently and was ticked off by the repairman for not having 'serviced' them more frequently. I have no problems at all with the cooling in my Innova. Is any particular preventive maintenance servicing of the a/c system required if there are no symptoms? Or will it be covered under the general periodic servicing at the ASS? The owner's manual stipulates inspection of the "cooling and heater system" at 40k km, 80k km, and every 20k km after that (inspection and cleaning of radiator and conderser, and inspection of hoses). It also stipulates checking the refrigerant level every 20k km. But I'm not sure whether service centres follow these guidelines exactly. As far as I know the refrigerant has never been topped up in the 90k km that the car has run so far. It is due for the 90,000 km service next week but I am taking it to a tyre and a/c shop this Saturday (day after) so could have it checked out there-- but since the cooling is working fine, the last thing I want is for them to needlessly drain and replace the refrigerant (and charge me for it) just because I mention the words "AC" and "service". (2) Is it normal for water to drip onto the driver's legs from behind the dashboard (presumably from the evaporator)? It does not happen often but I would imagine there is a system which should prevent it from ever happening, in a semi-premium vehicle. (3) Of late I have been getting more than the usual amount of smells from outside the vehicle, even though the slider is set to cabin recirculation. I'm guessing this is a mechanical system and due to age the flap is no longer fully covering the external air inlet. Can this be rectified without affecting the rest of the system (and replacing the gas)? Here is another guy with the same issue in the same car (of same vintage): Quote:
() Thanks |
25th July 2014, 18:37 | #49 | |||||||||
Senior - BHPian Join Date: Aug 2005 Location: New Delhi
Thanked: 2,281 Times
You are welcome! Quote:
Having said that, once the A/C is switched on, there is a thermostat in the electrical line, which would turn the compressor off -from time to time once max. cooling is reached. But you won't notice that as the threshold is not normally reached in Indian conditions. Quote:
b) Once in a while hose down the engine bay with clean water spray. Pay particular attention to the spray reaching the radiator and the condenser (behind it). c) Once in 2 - 3 years get the cabin air filters changed. Note this will mean getting the evaporators out, which also means that the entire system needs to be evacuated of refrigerant,and then refilled to manufacturer recommended psi. d) Over time, rubber perishes. So every once in a while say around 5k kms check the hoses, particularly at the joints, for any cracks. It's at the joint that the hose is usually maximally stressed- so that area wears out quicker. If you notice cracks - just replace it. Quote:
No the service centers don't follow them. You need to remind them. And then they will do it. It's been 90k km, but no drop in cooling efficiency. I suggest you to just get the cabin filters replaced. Note, this would require evacuation of refrigerant and refilling. Quote:
(1) Thanks |
The following BHPian Thanks joybhowmik for this useful post: | dr. sen |
13th September 2014, 23:24 | #50 | ||
Senior - BHPian | Re: Understanding Car Air-Conditioners May feel a stupid question, but all these years of 'IT' has transformed me into a noob. Quote:
Or in other words, when does the refrigerant show a maximum reduction in temperature? A) Is it at the condenser? { Quote:
OR B) At the expansion valve, due to reduction in pressure? It would be nice to mention the same in the above quoted paragraph of the opening post. | ||
() Thanks |
14th September 2014, 11:33 | #51 | |
In the expansion valve, the compressed liquid (which btw is still at its boiling point) for that high pressure is De-pressurized, reaching the low side pressure point. See chart below. At ambient temperature of 32 degrees celcius , the pressure of refrigerant in the expansion valve reduces from 260 psi to about 50 psi. The temperature of the refrigerant also reduces (subcooling) at this stage. At this low side pressure, the refrigerant's boiling point is lower. So when it goes into the evaporator, at this low pressure, it starts boiling, taking away the heat energy from the ambient air, thus dropping the temperature in the cabin. Hope this explains. | |
(2) Thanks |
The following 2 BHPians Thank joybhowmik for this useful post: | dr. sen, thoma |
2nd November 2014, 15:22 | #52 |
BHPian Join Date: Dec 2005 Location: Mumbai
Thanked: 9 Times
| Re: Understanding Car Air-Conditioners Slightly OT, but still related to ACs. In case of manual AC (non-climate control), does cabin cooling temperature selection have absolutely no impact on fuel efficiency? Reading the article on the front page it seems the compressor's clutch will be engaged for the entire duration AC is operational irrespective of what temperature is set. The answer may lie in knowing how the pressure is modulated inside the compressor. Thoughts? |
() Thanks |
2nd November 2014, 20:08 | #53 | |
It has absolutely nothing to do with the high or low side pressures in the AC system. Compressor clutch is engaged for as long as the AC Switch , Low-ressure Cut-off switch and thermistor are all closed. For all practical purposes this implies the the AC switch as it's rare for the low pressure cutoff switch or the thermistor to open under normal operating conditions. So a delta fuel efficiency impact due to selecting a very low or very high setting, will be marginally different if at all. Last edited by joybhowmik : 2nd November 2014 at 20:14. | |
() Thanks |
5th January 2015, 18:29 | #54 |
BHPian Join Date: May 2010 Location: New Delhi
Thanked: 292 Times
| Reasons why AC Cooling gets very poor with time At 70,000 I was advised to go for a comprehensive ac service that would have set me back by Rs. 3000. I almost believed them till my brother-in-law told me that his wagon R has been giving him ac cooling for 7 years and he has never got the ac serviced. I googled and realized that it was most probably the ac filter causing me trouble. I googled for ways to clean it and did a DIY. The AC filter was very very dirty and uncleanable. The website that showed how to remove it also told me that it could be washed with detergent and I used Arial detergent to clean at least 1 kg of black dirt from it. It has to be completely dry before use or it can cause problems. So let it dry for a day in hot sun and when I put it back and switched on the ac the cooling was as good as new. For lazy people, you can go for replacement , costs Rs. 400 + taxes. But if you put a little effort you can prevent the manufacture of one extra piece and contribute to greening the earth. That is the way I approach all replacements, including a mobile phone. I try not to discard something, till it is serving the functionality. Have cleaned the same filter twice and it is still running good. My advice is to clean the filter every month in summers for a great cooling experience. Also clean the radiator with a high pressure jet every 15 days or a month. You will have top see the dirt that seeps out of the radiator to believe that this is an important step that will ensure cooling. Summers are dusty and the dust gets into the ac filter and the radiator to lower the cooling effect. |
(7) Thanks |
The following 7 BHPians Thank syravi for this useful post: | F2005, goandude, GTO, JoseVijay, Mr.Boss, PGNarain, sidhu_hs |
6th January 2015, 09:04 | #55 |
BHPian Join Date: Feb 2008 Location: Raipur
Thanked: 322 Times
| Re: Reasons why AC Cooling gets very poor with time Thanks a lot Syravi, cleaning AC Cabin filter can indeed bring a drastic changes in the cooling performance, however with time you still need to clean the cooling coils; which are tucked deep behind the dashboard and is generally NOT a DIY job. These coils trap the dust particles which enters directly through the AC vents when you drive in dusty conditions with windows rolled down. I would still advice you to go for cleaning these coils and experience the difference.This job is worth 3K bucks and would take around half a day. |
(1) Thanks |
The following BHPian Thanks beast_within for this useful post: | GTO |
6th January 2015, 11:30 | #56 | |
Senior - BHPian | Re: Reasons why AC Cooling gets very poor with time Quote:
Did you take any photos of DIY? Which car are we talking about here?? In case no photos, can you post the steps for undertaking this DIY, with due reference to the car we are talking about. Usually the filter is located under the left vent, ahead of windshield. As mentioned by B_W, internal cooling may require some service and at some gas refilling too. This is better left to experts, as one may end up doing something that may leak gas or do more damage than good. Tks. Sonu | |
(1) Thanks |
The following BHPian Thanks ariesonu for this useful post: | GTO |
6th January 2015, 11:43 | #57 | |
I would say no to using water jets. Maybe using compressed air to clear dead insects, leaves and other debris will be a better idea. | |
(4) Thanks |
The following 4 BHPians Thank deetjohn for this useful post: | ariesonu, GTO, Mr.Boss, syravi |
6th January 2015, 12:07 | #58 |
Distinguished - BHPian | Re: Reasons why AC Cooling gets very poor with time |
(3) Thanks |
The following 3 BHPians Thank Mr.Boss for this useful post: | dr. sen, GTO, syravi |
6th January 2015, 12:24 | #59 | |
BHPian Join Date: Sep 2014 Location: Trivandrum
Thanked: 1,910 Times
BTW I do change the AC/Cabin filters at 10K or 15K intervals. Currently using "Bosch Active Carbon Filters". | |
(1) Thanks |
The following BHPian Thanks kozhissery for this useful post: | GTO |
6th January 2015, 13:02 | #60 | ||
Thanked: 292 Times
| Quote:
Mod Note: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD! To know how to multi-quote, click here. Last edited by Rudra Sen : 6th January 2015 at 13:27. | ||
() Thanks |
