Re: My Mahindra XUV500: Engine overhaul required Recently, almost a few weeks back, I got a call / message from Mr. Prashant from Pune about a similar issue he faced with his per-worshiped XUV5OO.
This gave me a feeling of what could have happened to my car if I had driven my car further. However, again in his case the customer care / dealer couldnt identify the cause given that the engine rebuild was recommended within a few months of the recent service.
Sharing his note below as I feel - it would help him. He has been asking me to post this as his membership to tbhp is still pending.
His detailed experience has been mentioned on the email here. And this email was based on the dealers diagnosis.
Email from the service manager based on his request after they recommended an overhaul Quote:
Dear Mr. Arora,
This is in refernece to your vehicle XUV 5OO bearing reg no. ----- reported to our workshop for concern of abnormal noise coming from engiene side and further our discusion.
As explained to you, at the receipt of your vehicle there was no coolant level found in reservor and on further inspection it is observed that the rubber hose related to coolant circuit was found cracked leading to coolant leakage. For further inspection, it is recoommeded to dismantle engine to know extent of the damages and to provide you tentative repair estimate for the same. As discussed with you, vehicle is equipped with high temperature indicator with notification beep, same would have been triggred during runing conditon of the vehicle.
You are requested to approve us to go ahead further for engine dismantling to provide you necessary repair estimate.
For any further query, feel free to contact undersigned.
General Manager - Service
Sahyadri Motors, Wakad
He wanted to take this up with Mahindra, and I think the tag is close to 1.5 lakhs, I feel he has his car still lying idle at home - with engine oil topped up. He asked for my help in getting this forwarded to tbhp for advise and see if there is anything that could be done through Mahindra. Quote:
---------- Forwarded message ---------
Date: Sat, 24 Mar 2018 at 1:40 AM
Subject: Fwd: Abnormal sound in Engine HR10T6070
To: CUSTOMERCARE <customercare@mahindra.com>, <>
Hello Team,
This is to share my recent experience and issue with my XUV 500 (July 2012). While below are the details but this note is to draw your attention on a potential malfunctioning in the vehicle and unsatisfactory response form the authorized service center.
During my recent trip to city, I have noticed blinking of the overheat indicator which went off when I have halt my car for 15-20 minutes during my commute and again after resuming my drive, the warning of Low Engine Oil Pressure showed up intermittently. It was a blinking light came a couple of times and again went off. I have again stopped the car and called the service center (Shayadri Motors, Wakad Pune) and was advised that if the light was blinking and went off, I could drive the car slowly for a few KM and if the light is constant on the cluster, then I must stop the car immediately. Worried enough I stopped the car, turned off the engine and waited for about an hour for them to send somebody to check. After a long wait when I started the car again the warning was not there and I drove the car for 2.3 km to reach the service center.
After the inspection, the report came to me is in the thread below with a recommendation to dismantle the engine.
My concerns and questions are:
1. Despite of well maintaining the car, why this has happened specially the car has only covered 42000 km and about 5.5 years old?
2. Why there was no signal / warning on coolant, check engine came neither the overheat signal came again?
3. As the diagnosis is potential engine damage, I am concerned that could this have been due to parts malfunctioning (oil pump and coolant hose/pipe were the issues in July 2012 models)?
There is a lot of money, care and love given to this vehicle and M&M claims that this is equipped with many smart features then why those features didn't come to save a potential engine damage, is my biggest worry.
So far all I heard from the ASC was this has happened due to normal wear & tear but to highlight, I had the 40000 km service done at the same ASC in January this year and after that the car has just ran another 500 km why any such potential issues/ risks were not diagnosed then?
On top of this, I have received mixed information from the ASC some of them are:
- Its an engine seize and require half-engine replacement
- Dismantle the engine to identify the actual damage
- Run as is with knocking noise but maintain the coolant and oil level
These have given me doubts about the capability of the engineers at the mentioned ASC hence I request involvement from Mahindra directly to investigate the root cause and suggest the best and economical solution.
Also, would like to highlight, I have asked a couple of times to check the ODI logs to see what warnings came and what didnt but that never happened but the flat recommendation was to dismantle the engine. Didnt get the name and number of the Regional Customer Care Manager despite of my multiple requests to the ASC Managers /Supervisor.
I and many of my blood relatives have trusted Mahindra for the vehicles and the best in class customer support since years and with the same hope I am writing this note.
Looking forward to your response and attention on this matter. |
I essentially did a rebuild as the dealer knocked down the engine without my consent.
On top of everything I feel there could be something with the particular batch of vehicles. Worst part is, the service guys couldnt even check engine levels.
Guys see if anyone can be of help, I shall convey your response across to him until he gets into tbhp
