Old 28th January 2007, 13:29   #1
raajks's Avatar
Thanked: 119 Times
Lancer sfx, slx and glx -- Body differences (If any?)
I have a basic question on the body of the Mitsubishi Lancer.
Is there are difference in the size of the body (Length, Breadth or Width) between the different variants of the Mitsubishi Lancer. (Normal and Sports)
I am not looking at interiors or any other difference.
My focus is only on the body and wheel base.
Lets get technical on this one
raajks is offline
Old 28th January 2007, 13:41   #2
lamborghini's Avatar
Thanked: 5,937 Times
No there isn't any major difference.
The SLXi just comes with Alloy wheels and the SFXi has skirtings all around which reduce the ground clearance.
The SFXi also comes with 14inch alloy wheels.
lamborghini is offline
Old 28th January 2007, 14:10   #3
gamerno1's Avatar
just what lambo said
Since i bought my lancer just a few months ago, the only difference between the 3 were:
GLXi - Basic
SLXi - 13" Alloys / Rear Spoiler
SFXi - Front, Rear, Side Skirts / Rear Spoiler / 14" Alloys
gamerno1 is offline
Old 28th January 2007, 14:53   #4
Gamer,
the SLX doesn't come with a spoiler.
Only the SFXi.
And even the GLXi comes with 13" wheels but not alloys.
Old 29th January 2007, 08:52   #5
raajks's Avatar
Thanked: 119 Times
Thanks Guys!!! for that info
raajks is offline
Old 29th January 2007, 08:54   #6
Vid6639's Avatar
Thanked: 44,137 Times
This is the SFXi cosmetic bodykit:
http://www.team-bhp.com/forum/indiancarpicture-506.html
Vid6639 is offline
Old 30th January 2007, 10:59   #7
devarshi84's Avatar
Thanked: 213 Times
Just to add that sfxi has a different ground clearance than the other lancers. Its due to the bodykit and alloy wheels.
devarshi84 is offline
Old 30th January 2007, 12:01   #8
Vid6639's Avatar
Devarshi It's not due to the body kit. It's infact due to the wrong tyre size selected for the car.
That is what reduces the ground clearance. The lowest point is the 2 rails on the bottom.
they are lower than the side skirting. Change the tyres and the ground clearance is then proper.
have a look in my garage the car's got a higher stance.
Vid6639 is offline
Old 31st January 2007, 05:12   #9
devarshi84's Avatar
Thanked: 213 Times
nope. Mitsubishi sfxi has 175mm ground clearance while others have 182mm of Ground clearance.
Old 31st January 2007, 08:32   #10
Vid6639's Avatar
Devarshi your right in the numbers but it's not due to the body kit it's cause of the tyres.
The GLXi tyre's size is 175/80-13. The ground clearance as you have pointed out is 182mm. The radius for the tyre comes out to 305mm.
The SFXi comes with 185/60-14.The radius for this tyre is only 289mm. Which is a drop by 16mm. This is the only reason the ground clearance is bad. The specs on the HM site are incorrect for sure. The speedo error due to this tyre size is huge. It Shows a better mileage as well since the tyre is 5.33% too fast.
If you change to 185/65-14 the radius goes upto 298mm and the error is 7mm which is how you get the 175mm GC.
I have put in 195/60-14 which gives me a radius of 295mm.
The SFXi body kit does not change the car's ground clearance. If it did the body kit would be the part hitting the cars underbelly.
Anyways thats the GC difference between the SFXi and GLXi.
Vid6639 is offline
Old 31st January 2007, 13:39   #11
raajks's Avatar
Thanked: 119 Times
What would be the best tyre option for SFXi?
Will 15 inch wheels make any difference with the tyre option suggested?
raajks is offline
Old 31st January 2007, 14:06   #12
Vid6639's Avatar
raajks,
refer to this thread:
http://www.team-bhp.com/forum/tyre-a...ncer-sfxi.html
Vid6639 is offline
Old 1st February 2007, 09:56   #13
devarshi84's Avatar
Thanked: 213 Times
Sorry Vid, I didnt read your post properly.
I never really measured the details but I knew the fact that there is a difference. I was putting forward the same point as you but without facts. :P
Old 18th March 2008, 13:26   #14
wanderlustindia's Avatar
Thanked: 63 Times
205/55/15 is a good tyre upsize for the Lancer. 15*6.5 alloys should go well with these tyres.
wanderlustindia is offline
Old 18th March 2008, 14:50   #15
ram_hyundai's Avatar
Thanked: 53 Times
I have seen lancers with different type of boot lid.Some old ones got different grills and some how i feel there is a marked difference in the body shape of the lx and sfx.
ram
ram_hyundai is offline
