Re: Automotive air conditioner servicing & maintenance Quote:
Originally Posted by trinity0114 Hello
Facing a peculiar problem with the AC in my car. First of all the compressor dosent turn on after a cold start, I have to repeatedly switch on and off the ac button to bring the compressor to life, then the compressor abruptly cuts off on its own while the car is being driven and then again this process of hitting the ac button multiple times has to be repeated to turn on the compressor, the ac cuts of happens under different circumstances like while clutching or when the rpm falls too low or even on an open road while cruising but strangely the ac keeps on working when the car is stationary and the compressor dosent cut off even once
Car in question is Linea T-Jet |
I had the same issue with my Dzire when it was relatively new. The compressor would not come on randomly on some cold starts or if it did, it would sometimes not come back on after cutting off. Like you, the only solution was to mash the AC button until it worked and when it was working, it would cool normally.
There are two possible culprits : the AC compressor clutch magnets and the AC switch itself.
It might be possible to test the AC switch. Do this by turning on the AC as normal and if it isn't working press and hold the switch ain fully and see if the compressor starts working. If it does, then it is the switch. If not then it's likely the compressor clutch.
Note : This isn't 100% guaranteed to work and might only be possible if it is a "switch" and not a "button". No harm in testing it out though and something to consider if the clutch is fine or the problem persists after clutch replacement.
In my case, the clutch itself was bad and was replaced but the problem would still occur once in a while. Mashing the switch to get the AC to work had caused an issue and it was fully resolved by replacing the AC panel as well |
