Old 25th August 2009, 20:55   #1096
Originally Posted by LionX View Post
AFIK that is a functionality provided by TATA in safari. The AC will be cut off at higher RPM when the car needs more power. I think ECU has been programmed like that. I usually feel it while taking off from signals in 2nd gear and RPM above 3000.
I can't recall reading that in the user manual, never had that problem either though my ac usage is quite low. Anyone else had this issue?
Originally Posted by Alter_Ego View Post
Ok one silly question... I have been at loss of instincts as to when I should refill the air in my tubeless tyres.
I drive my safari 3.0 everyday for about 30Kms.All city driving.
So what should be the time interval within which I should re-air the tyres??
As its been more than a month and I dont feel there has been any loss of pressure in the tyres..both lookwise and feelwise while driving??
Any pin pointers to pop this stupid bubble?
You should check your tyre pressue weekly, the tyres will last longer that way, you won't feel much difference as you become accoustomed, it's safer to keep your tyre pressue near optimal at all times, you may not need to fill them everytime, get one of those little hand held gauges, then if you need to fill go to the nearest tyrewallah.
stefanm is offline
Old 25th August 2009, 22:07   #1097
Thanked: 579 Times
Originally Posted by stefanm View Post
I can't recall reading that in the user manual, never had that problem either though my ac usage is quite low. Anyone else had this issue...
Haven't noticed it yet, since I have not yet pushed the vehicle till now.
But yes, I have noticed this in the Indica, I reckon it was the V2, and in my drive from Cochin to Palaghat, I was very much impressed with this feature. Floor the accelerator and the ac is cut off ensuring full power to the engine. Wouldn't be surprised if the Safari also has the similar feature.
HappyWheels is offline
Old 26th August 2009, 00:48   #1098
Was this driving on an incline, like a ghat or mountain with lights and other ancilleries swithched on?
stefanm is offline
Old 26th August 2009, 09:46   #1099
Thanked: 579 Times
^^ Nope. Plain road; while overtaking coming down to 4/3rd gear and acceleration kind of scenario and it was during day time, with no a/c.
Old 26th August 2009, 10:06   #1100
LionX's Avatar
Thanked: 1,210 Times
@stefanm,I got this information from a service advisor, don't think it is written anywhere in the manual. I felt this as a useful feature, no need to worry.
LionX is offline
Old 26th August 2009, 10:42   #1101
dkamath's Avatar
Thanked: 162 Times
Guys, if it's a feature to cut the AC off only for the engine to harness more power/torque, then i feel it's a no-brainer. You just can't drive around with 4 people seated in and foggy glass all around, more so when it's raining. The engine was not pushed either, in any of the gears (have upshifted at about 1750rpm or so, in the lower gears, but not beyond that rpm). The radiator fan was running, and the engine temperature was slightly beyond the half mark (< 5 deg.). So why this cut off?
dkamath is offline
Old 26th August 2009, 10:54   #1102
gowda79's Avatar
Thanked: 195 Times
Never ever went through such situations on any of the ghat section drives at day or night with 100% AC.
gowda79 is offline
Old 26th August 2009, 11:20   #1103
Thanked: 42 Times
You don't need to go in an incline to simulate this. Just engage the first gear (and keeping the clutch pedal pressed, to remain stationary) ; push the accelerator beyond 2k RPM. With the windows down, you can hear the distinctive "TAK" sound of the compressor kick-out.
I was told that this is only for the 1st & 2nd gear, to conserve power by a Service Engineer
maheshmenon is offline
Old 26th August 2009, 14:05   #1104
gowda79's Avatar
Thanked: 195 Times
Do you really push that hard ???
gowda79 is offline
Old 26th August 2009, 17:26   #1105
sidcruise79's Avatar
Somehow I dont like the follow me home Head Lamp function in the Safari. It must drain the battery a lot, especially as I have HID's.As of now what I do is immediately put on the parking lights and switch them off when the head lamps come on at night after opening the door. This switches off the head lamps and tehy don't stay on for long.
Is it possible to have an option of enabling/disabling it....
sidcruise79 is offline
Old 26th August 2009, 17:29   #1106
Thanked: 463 Times
After getting out, you can even press "Unlock" button first and then the "Lock" button on your remote, that will take care of it.
dadu is offline
Old 26th August 2009, 17:54   #1107
Lukeskywalker's Avatar
Thanked: 1,244 Times
Thanks for the tip Dadu, I was about to ask if the 'Follow Me Home' feature can be disabled. It's quite irritable being told "Saar, headlights are not switched off" everytime one locks the car in the evening.
Lukeskywalker is offline
Old 26th August 2009, 18:10   #1108
Alter_Ego's Avatar
Thanked: 114 Times
Originally Posted by v&v View Post
Hi think once in 10 days. As the payload is on higher side, it may effect the average. I have checked in my case there is around 1- 2 psi difference in my safari.
Thanks v&v and stefanm.
By the way any idea how much those little hand helf gauges might cost me?
Alter_Ego is offline
Old 26th August 2009, 21:43   #1109
Thanked: 463 Times
Just a clarifier, this does not disable them but its a method to switch them off immediately. I posted this long time back in this thread only.
dadu is offline
Old 27th August 2009, 09:11   #1110
jaysmokesleaves's Avatar
Thanked: 1,466 Times
The drive by wire on the Safari is very sensitive to throttle inputs. If you blip the throttle the ac cuts off. This can happen while normal driving or climbing even. If the ac cuts off while climbing, its probably because you blipped too fast. I used to experience this earlier until I realised That it was my fault and not a technical snag. Ever since this does not happen any more.
jaysmokesleaves is offline
