Old 16th February 2016, 14:47   #3436
Jaggu's Avatar
Thanked: 15,907 Times
re: Review: 1st-gen Mahindra Thar (2011 - 2019)
Originally Posted by D.V.R View Post
Even I am looking to improve the perfomance of my Thar Crde. Where have you got the remap done and your feedback regarding it?
Remap was done by Code 6 http://www.code6.in/#service
I am very happy with the remap, still get the same FE also but very easy to drive and has a great power band. Would recommend the same to anyone.
Jaggu is online now   (1) Thanks
Old 17th February 2016, 13:50   #3437
KkVaidya's Avatar
Thanked: 760 Times
How is this thing compared to a Race Chip PRO 2 ECU - Cost wise and performance wise?
KkVaidya is offline
Old 18th February 2016, 13:27   #3438
4x4addict's Avatar
Thanked: 4,532 Times
Infractions: 0/1 (5)
HI Vaidya, performance boxes basically work by sending false signal's to the ECU to dump more fuel. It is not a very scientific approach, but cheap and simple.
Code6 does a remap of your engine. They have developed a custom map and this map is installed in your vehicle. Since it is a custom map, it is done more scientifically and the results are much better.
4x4addict is offline   (1) Thanks
Old 18th February 2016, 20:13   #3439
SPIKE ARRESTOR's Avatar
Thanked: 1,532 Times
Tini, could you explain how the performance box and code 6 remap is different? Do they do anything with the stock ECU ? How?
Spike
SPIKE ARRESTOR is offline
Old 20th February 2016, 15:05   #3440
4x4addict's Avatar
Spike
Code 6 deletes the stock ECU mapping and uploads a new map. As you may be aware, the ECU is locked by Bosch. Hence, they first crack the code and then delete the stock map after backing it up (for restoration if required). Then they write a new ECU map into the ECU. This is my understanding after talking to people who done the maps.
Performance boxes are external attachments that sit in between the ECU and engine. It basically fools the engine into dumping more fuel.
4x4addict is offline   (2) Thanks
Old 21st February 2016, 08:41   #3441
Tanmay K's Avatar
Thanked: 212 Times
A friend of mine has a 2013 Thar and he wants to replace the dashboard with the one in 2015 facelift model. Is this something that has been done/can be done?
Tanmay K is offline
Old 22nd February 2016, 13:27   #3442
Jaggu's Avatar
Have never tried one with Race Chip so i have no idea on this.
Thanks Mr T!
Yes and Spike instead of one parameter whole set of them is changed. I was little skeptical at the beginning, but once i rode Ashok's Code 6'ed Thar i did not even blink.
Jaggu is online now   (3) Thanks
Old 24th February 2016, 21:05   #3443
KkVaidya's Avatar
Thanked: 760 Times
I have heard that the new THAR has the steering wheel centered or or maybe they adjusted the seats so that steering is in center. Ask him to check with the dealership. I believe that can be done once the AC ducts & wiring is looped properly. But why does he want to change the dash when the new dash is in a shameful colour of beige?
KkVaidya is offline   (1) Thanks
Old 25th February 2016, 15:26   #3444
tomraven99's Avatar
Thanked: 176 Times
My Thar has developed loss of power especially on inclines. The problem partially resolves on disconnecting the Mass airflow sensor with lots of black smoke. However on replacing with a different sensor the problem still persists. The ASC thinks "it may resolve by changing the entire wiring". The MAF wiring harness showed correct voltages on testing with a multimeter.
Experts kindly advice on what could be the problem.Will remapping the ECU work?
tomraven99 is offline
Old 25th February 2016, 18:06   #3445
dhanushs's Avatar
Thanked: 10,181 Times
Did you try cleaning the whole air intake plumbing till the intake manifold. From the air filter, to turbo hoses, intercooler etc.. Had the same problem in my Manza. Too much oil clogged up the intercooler.
dhanushs is offline   (1) Thanks
Old 26th February 2016, 10:03   #3446
Thanked: 2,741 Times
Most probably you are starving on air. Clean the whole air intake channel including the air filter and throttle body.
Aroy is offline   (1) Thanks
Old 26th February 2016, 23:01   #3447
tomraven99's Avatar
Thanked: 176 Times
I guess the ASC must have done it while I mentioned the complaint. Ill try and take it to a second workshop and see. Could a faulty EGR cause symptoms like these?
Old 1st March 2016, 15:35   #3448
KkVaidya's Avatar
Thanked: 760 Times
What is the average fuel consumption you get in your Code6ed THAR?
KkVaidya is offline
Old 2nd March 2016, 14:19   #3449
Jaggu's Avatar
Anything between 9-10 in BLR peak hour traffic with AC and about 11-12 on highways with AC and 100 kmph cruise, the soft top makes a racket and am on offroad tyres so don't do very high speeds on highways. Only occasional bursts.
FE i felt was slightly better in city compared to before, maybe due to the fact that vehicle can be in higher gear at slower speeds. Highway never had an opportunity to measure the stock FE.
And if you do pedal to metal drives, FE drops.
Jaggu is online now
Old 7th March 2016, 08:22   #3450
Thanked: 803 Times
Hello GTO -
I have been a part of this esteemed community for a while and believe me, the hours spent on the forums just keeps increasing by the day, hats off to you guys on managing TBHP.
I am planning to buy a THAR, had a few questions, I would be really thankful if you may help -
1) Is there a thread dedicated on using the 4H, 4L, 2H and N modes on a 4X4, I went through all the threads but they were more bookish than plane jane simple, when what and how to use. If you may help me put it in simple words, it would greatly help.
2) Which of the above stated gears do I drive in, in normal city conditions ? My 99% driving would be on normal tarmac.
3) As a Jeep owner, what are the other things that I need to be careful about, which would typically not be the case in a sedan.
4) If you have driven the updated 2015 Thar, how do you find the AC? This is of prime importance, I do not want to travel to work being all wet.
Thank you GTO for all the help here.
Cheers,
Torquedo
Torquedo is offline   (1) Thanks
