Old 20th August 2007, 22:34   #16
i don't know.. i mean what do i compare the noise to? but ya.. it is more noisy than i would like it to be.. i am waiting for a couple more months to collect all the 'issues' and sort them out at one go. the left-side (passenger) side suspension is creaking (at random times).. this could be a potential nightmare. i haven't even got time to check the tyre pressure to see if it matches the recommended pressure.
I checked the tyre pressures and one was at 34psi. Reduced that to 31 and the noise is better. May be worth a try?
I have a problem with the seatbelt indicator not working and the audio alarms for low fuel etc not sounding. They checked that all is working and it may need some computer coding to switch them on.
deepakvrao is offline
Old 20th August 2007, 22:34   #17
Laura rims are 16x 6.5j
Camry AT comes with 215/16" Yokohama A430. So this could be another tyre option.
Thanks - will check them out
Old 21st August 2007, 00:18   #18
iraghava's Avatar
Thanked: 281 Times
Yokohama A430 is not officially available in India.
iraghava is offline
Old 21st August 2007, 03:12   #19
hellspawn's Avatar
Thanked: 9 Times
Infractions: 0/1 (10)
one question that comes to my mind,the laura has an onboard tyre pressure monitoring system.wont the change in tire size,width etc cause errors in the readings.just curious.
hellspawn is offline
Old 21st August 2007, 06:45   #20
The ryre sensor has to "be set" when the tyre pressure is set. I bought it used and maybe it was not set by the previous owner AND thanks for reminding me, I forgot to set it to after checking all the tyres.
Old 21st August 2007, 12:07   #21
iraghava's Avatar
Thanked: 281 Times
Correction from a source, Yoko A348's are standard on the Camry & are officially available in India in 215/60 r16.
iraghava is offline
Old 27th August 2007, 14:51   #22
kaushik_s's Avatar
Thanked: 165 Times
Originally Posted by deepakvrao View Post
Guys,
Was thinking of Goodyear but hear I see a lot of recommendations for Yokohoma/Michellins etc. Frankly I have not seen these in any store in Bangalore - OTOH I have only been to standard MRF/Bridgestone etc. Maybe they will be available in JC road?
Doc, there is a Tyre shop on CMH road just opposite to Casa Picola and they do stock michelins (I got mine from them). And that guy was telling that he can even source Yoko's also.
kaushik_s is offline
Old 29th August 2007, 00:38   #23
Thanks Kaushik,
Just saw this post - will check it out.
Old 25th September 2007, 16:06   #24
karan561's Avatar
Thanked: 23,030 Times
Tyre Upgrade for Laura @ 44K kms?
Hey ,
My car has completed about 44k kms and i need to change my tyres shortly. here are a few pics. of the car and the tyres closeups.
CHECK THIS OUT : SIDE WALL AIR BUBBLE.
[COLOR=#22229c][/COLOR]
karan561 is offline
Old 25th September 2007, 16:13   #25
karan561's Avatar
Well the STOCK tyres are 205/55 R16 BRIDGESTONE TURANZAs . So i want suggestions on which Tyres to buy on the basis of a good combi of ride quality , performance , tread pattern.
(Already have Potenza g-IIIs in my corolla so wouldnt want the same)
And yes can i upsize it to 215/55 ? or even better 215/60 ? or 205/60 ?
Help me out guys !
Thanks.
karan561 is offline
Old 25th September 2007, 16:39   #26
Akshay1234's Avatar
Thanked: 12,915 Times
215/55 would be better. 215/60 is a no no.
Akshay1234 is offline
Old 25th September 2007, 16:39   #27
BUSA's Avatar
Thanked: 23 Times
Firstly Bridgestones are quite prone to side wall bubbles.
Anyways 205/60 and 215/60 are the absolutely wrong upsize for the Laura, a better upsize would be 215/55 or 225/50 or 235/50.
Tyres i would suggest the Michelin Energy XM1's for comfort and PP2 for performance.
Rest about which tyre is available in which size is best left to be told by the Tyre Dealer from Delhi, mind you there are Bangy tyre dealers too on the forum and one in Faridabad as well
BUSA is offline
Old 25th September 2007, 16:40   #28
lohithrao's Avatar
Thanked: 226 Times
How did you find the performance of "Turanza's"? I have them on my OHC and till now no complaints.
btw have seen Accords also come with Turanza's...
lohithrao is offline
Old 25th September 2007, 16:44   #29
karan561's Avatar
How about EAGLE F1s ? I am really desperate to get that tread pattern in . Just worried about the life of that kind of a tyre.
karan561 is offline
Old 25th September 2007, 16:46   #30
karan561's Avatar
Originally Posted by lohithrao View Post
Had faced a similar side wall air bubble @ 4k kms mark , but got it changed for free as it was under warranty @ skoda ... otherwise no complaints. The tyres are really grippy even under hardcore cornering conditions.
karan561 is offline
