The ICE bug has bit me
.The stock system on the Fluidic Verna is pretty decent but it lacks in the BASS department majorly. Strangely , although all the 4 OEM speakers are exactly the same 5.25" with 15 watt RMS , the rear speakers sound very low or very poorly even after fading everything to the rear.
I have been going over a lot of forums and threads but I still have just a few more doubts before I get all the parts ready for the install. Some of the threads I have gone through are mentioned below.
http://www.team-bhp.com/forum/sound-...velty-ice.html http://www.team-bhp.com/forum/ask-gu...upgrade-2.html http://www.hyundai-forums.com/rb-201...ont-doors.html http://www.hyundai-forums.com/rb-201...ent-guide.html
Anyways I got a few stuff's off of my other car which I don't use much, so thought of installing few of those stuff's here in my Verna. I would like to retain the Head Unit as I want the steering wheel and BT controls to remain intact.
Some of the old stuff's that I have are mentioned below with their power ratings.
1)
Rear Speakers - JBL GTO 937 , 6"X9" 3 way ,
2 Ohms 100 Watt RMS Oval Speakers.
2)
Subwoofer 1 - JBL CS 1204T Bass Tube - 12" ,
250 Watt RMS at 4 Ohms
3)
Subwoofer 2 - Pioneer TS - W305F , 12" ,
300 Watt RMS at 4 Ohms
4)
Amplifier - Pioneer GM - 6200 F ,
60 Watts RMS @ 4 Ohms or 75 Watt RMS @ 2 Ohms
Some of the things I am yet to buy to complete my setup are below. I will be shopping for the new stuffs entirely online , so please suggest brands that are available in India.
1)
Front Component Speakers - Please suggest a brand between JBL , Rockford Fosgate and Infiniti in the price range of 10,000 Rs. The size should be either 5.25" or 6.5" with an RMS of
100 Watts @ 2 Ohms so that it can match my rear speakers. Hopefully my Pioneer Amp can support all the 4 speakers together.
2)
Subwoofer Fully Closed enclosure - This is for the W305F sub which is a free air use sub. I believe a square sub will be perfect but I do not know what should be the exact dimensions/volume for the enclosure so as to get the best bass sound from this sub.
One person in this thread
http://www.caraudioforum.com/showthread.php?t=351853 has suggested that the best volume would be 3.5ft³ enclosure, including sub-displacement with length 34", height 15.5" and depth 15.5". He calculated it from this thread
http://www.bcae1.com/spboxnew2.htm
I think it will easily fit in my boot but most of our forum members go for a 1ft³ enclosure for the best sound from their 12" woofers. So I'm confused if I should go with
1ft³ or 3.5ft³ enclosure. Please advise on this.
3)
Mono Block Amp - This will be either used only for the JBL bass tube or the Pioneer enclosed sub. I won't be using both the sub's together. Based on which sub sounds best , I will use that. Please suggest a good mono amp that can handle either of the subs at a price range of 10-12,000 Rs.
4)
Hi-Low converter - Since I'm using the stock unit with just speaker level outputs , what would be the best converter to buy so that it can feed to both the Amps that I will be using. Price upto 3,000 Rs.
5)
Wiring Kit - Please suggest any good wiring kit , good brand. Price upto 3,000 Rs.
6) Am I in the right track or is there anything else that I need to purchase ?
I have attached pics of my Pioneer Amp below so that you know what kind of wiring is needed.
