Thread Tools
Old 9th June 2006, 22:12   #1 (permalink)
kb100's Avatar
Default GLOSSARY of ICE TERMINOLOGY
For the AUDIO INNNOCENTS - as Sam puts it... Its worthwhile to start a glossary of terminology used in ICE world! ... Perhaps we can make this a sticky too... I'll get this going... everyone can add (even narrations where required)... at some point the mods can consolidate and sort everything in alphabetical order for everyones convenience...HERE GOES!!
1. NOOBIE = AUDIO INNOCENTS ;o)
2. AMP = AMPLIFIER
3. HU = HEAD UNIT
4. SUB/SW = SUB-WOOFER (speakers that produce only low requencies usually less than 100hz)
5. MONOBLOCK = Amplifiers with a single channel of amplification - usually used to drive subs.
Fantastic Idea KB. THis way we can have a ready reference. THis thread will allow only 2 types of posts. (1) People asking what a particular term means and (2) People answering the questions asked in (1). No Off Topic. No Backslapping. No Thank yous. No digressions will be tolerated. I would love this thread to be readable by Noobies.
__________________
A closed mouth gathers no Feet.
kb100 is offline   Reply With Quote
Old 9th June 2006, 22:52   #2 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
in case of SW,
DVC = Dual Voice coil Sub, having 2 voice coils in same SW. either 2 ohms or 4 ohms each, to give u great wiring options to extract the max outta ur amp and SW set up.
SVC = single voice coil Sub, either 2 ohms or 4 ohms.
__________________
SINGH IS KINNNNNNNG..
panky12345 is online now   Reply With Quote
Old 9th June 2006, 23:05   #3 (permalink)
Bass&Trouble's Avatar
Just some exceptions, some subs have voice coil nominal impedance other than 2 ohms and 4 ohms also.
There are also other subs with multiple voice coil configurations, like quad voice coil subs, which have 4 taps.
__________________
Operator! Give me the number for 911!
Old 9th June 2006, 23:20   #4 (permalink)
panky12345's Avatar
yes sir B&T, i fully acknowledge....i was abt to write it....then thot its for new entrants, and had i written those, they wd have felt the same way as i feel when navin replies.
__________________
Old 10th June 2006, 07:18   #5 (permalink)
antardaksh's Avatar
I still wonder what does ICE mean ;(in car entertainment) i guess!
antardaksh is offline   Reply With Quote
Old 10th June 2006, 08:21   #6 (permalink)
panky12345's Avatar
yes antardaksh, it means In Car Entertainment only. Welcome to TBHP!!
may u have a pleasent stay here.
__________________
Old 10th June 2006, 09:47   #7 (permalink)
What does single din and double din mean?
Mistakenguy is offline   Reply With Quote
Old 10th June 2006, 11:13   #8 (permalink)
panky12345's Avatar
in simplest words, Single Din means normal width HU's as are available in markets....these are normal sized stereos (HUs) that you see around in web sites, car shops etc (90% of the time). and if u spot a HU which is bigger (double app - seems like 2 HUs combined to form a single unit) its called a Double Din. have urself search on google for "single din" and "double din" images once for more clarification.
__________________
Old 10th June 2006, 11:19   #9 (permalink)
low_bass_makker's Avatar
single din->
double din->
Old 10th June 2006, 12:07   #10 (permalink)
navin's Avatar
Tweeters: Speakers used for reproducing high frequencies like the tweeting of a sparrow.
Woofer: Speakers used for reproducing low frequencies like the woofing of a dog.
Midrange: Speakers used between a woofer and tweeter
Midbass: Midrange with some woofer capability or woofer with some midrange capability.
Crossover or XO: Used to part audio signals from amplifier and send signals to woofer and tweeter and/or midrange.
Power Cables; Used for connecting your battery to the Amplifer or Head Unit or other accessory like Equalliser. These differ from speaker cables and Interconnect cables in topology and design but not in basic function of transmitting electrical signals.
Interconnect cables: Cables used to connect your Haead Unit to an Amplifier or Equalliser or to connect and Equalliser to Amplifier. etc. Most common Interconnect cables used in car audio use RCA connectors and are hence often also called RCA cables.
RCA: Radio Corporation of America. Formed the standard of the RCA connector used for most Interconnect cables. Others are DIN, XLR, etc... but there are not often found in car audio.
__________________
Scixelsyd Etinu
Old 10th June 2006, 13:09   #11 (permalink)
jkdas's Avatar
Thanks to Sam...............
What is compo?
Shrt form for component. A component set is a set of speakers where you get 2 mid woofers (generally 5.25" or 6"), a crossover network and a pair of tweeters. These sound very nice in the front of your car.
What is co-ax?
sounds like co-axial, but again, co-axial what.. cable?
Co-Axial means speakers with a common axis. For example, regular car speakers have a woofer, midrange and tweeter built all on the same axis.
I assume channel means a channel of amplification in amp? For a stereo you have 2 channels, what is 4 channel then?
A 4 channel amplifier is basically 4 seperate chanels of independent amplification in one body. You can use 2 channels to drive the front speakers in stereo and the other 2 to drive the rear.
What is bridging?
Instead of running pair of speakers on 2 channels, if you combined the power of two channels to give you one powerful channel to drive (for example) a subwoofer, that is called bridging.
Thanks to Autophile........
HPF = High Pass Filter, it cuts / attenuates the below the value selected. Eg HPF at 80Hz means the frequency below 80 Hz will be attenuated. The attenuation depends on the slope of the crossover. Used for speakers, tweeters, subwoofers (Subsonic filter)
LPF = Low Pass Filter, it cuts / attenuates the above the value selected. Eg LPF at 80Hz means the frequency above 80 Hz will be attenuated. The attenuation depends on the slope of the crossover.Used in midranges, subwoofers.
BPF = Band Pass Filter, combination of HPF and LPF it cuts / attenuates the above and below the values selected. Eg in case of subwoofer HPF at 20Hz and LPF at 80Hz means the frequency below 20Hz and above 80 Hz will be attenuated. The subwoofer will play frequencies from 20Hz to 80Hz.
TA meands Time Alignment of speakers. It is used to delay the speakers which are nearer in respect to farther speakers so that the sound from both the speakers arrive you at the same time. Results in better sound, imaging, sounstage.
(this is CNTRL + C plus CNTRL + V job)
__________________
-__-
Old 10th June 2006, 13:27   #12 (permalink)
jkdas's Avatar
DAC : Digital to Analog Convertor
Burr Brown: A hig end DAC
__________________
-__-
Old 11th June 2006, 11:11   #13 (permalink)
Vivekphadnis's Avatar
We are always talking about how a HU, amp or speaker sounds. So I think it would help if we define some basic terms like bright, boomy, muddy. I could do a google and dig up definition of such terms. What say?
Also, terms like harmonic, intermodulation distortion could be added on later.
__________________
Thank God for DIY audio.
Vivekphadnis is offline   Reply With Quote
Old 11th June 2006, 18:53   #14 (permalink)
Sam Kapasi's Avatar
hey McLaren, Navin warned us before hand. Lets not get humour into this thread. It's for people that dont know terminology. Let's not confuse them.
As for the newbies, please dont fret over CCTB, disregard ok, it's an old joke.
OK so here's a little gyaan, not too technical, i'm keeping it very simple:
2 of the most common forms of Subwoofer boxes. (There are many more but these are the most commonly used)
1) Ported AKA Vented AKA Bass Reflex type box:
A box in which we fit the subwoofer and make a hole, to allow some the reverse bass pressure to escape and add to the overall bass. The hole is not just any ordinary hole. Just like the size of the box is carefully calculated, the diameter of the port(hole) is carefully calculated along with the length of the tube in the port.
A wrongly made port will spoil the sound completely, as will the wrong size of the box. Boxes and ports are made using various parameters, often supplied with the woofer. Remember 50% of the woofers sound is the box.
Generally a vented box is used to achieve a louder volume of bass.
2. Sealed box:
As the name suggests, this box fits a woofer and is completely sealed. There is no port/hole anywhere in the box. This smaller kind of box gives a little less bass, but the bass is tighter, faster and more precise/accurate. You can avoid a deep resounding "BOOM" using a sealed box.
Please do accept that this is seriously watered down information and there are many exceptions and many variations to these rather broad explanations I've given. I just want the newbies to be able to nod when they hear these terms being thrown around.
__________________
Live the YetiLife®
Old 12th June 2006, 20:39   #15 (permalink)
Burr brown which is now owned by Texas Instruments is a company which makes DAC there are many other compnay which make DAC....
a small write up for DAC useful for newbies
http://en.wikipedia.org/wiki/Digital...alog_converter
DAC manufacturing companies
http://www.semiconductor-manufacturi...-Converter.htm
High end dac other than burr brown....
http://www.analog.com/en/prod/0,,761...1955%2C00.html
Thread Tools
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever Ask the Gurus 18 25th October 2008 01:39
iS my ICE OK? sandyrocks Ask the Gurus 11 27th November 2007 12:58
Ice!!! vivekiny2k Ask the Gurus 15 14th August 2007 17:58
Need your help on ICE....Please!!! shiv Ask the Gurus 3 4th May 2007 21:51
Car Glossary needed on Team-Bhp navdeep Technical Stuff 6 8th March 2007 10:05
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
