Thread Tools
Old 28th May 2007, 17:33   #1 (permalink)
Default SX4 ICE - Subwoofer Install?
Getting my SX4 this week. Does anyone know if the ZXi variant has a preout to connect a subwoofer amp? problem is I already have an amp which does not have speaker level inputs.
Any info is appreciated. Thanks,
Manish
1000w is offline   Reply With Quote
Old 28th May 2007, 18:27   #2 (permalink)
navin's Avatar
Any idea what HU the Zxi comes with?
__________________
Scixelsyd Etinu
Old 28th May 2007, 18:43   #3 (permalink)
Not sure, That info would have really helped, thats why asking the forum gurus if anyone has any info. Also went throu the SX4 forum (SX4 Forums), but couldnt get much details there either. The US model (4x4) has a slightly diff HU but I guess the connector pinout should be pretty similar
Old 28th May 2007, 19:56   #4 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
1KW...
The SX4 has a Nippon / Kenwwod OE unit which is actually a single DIN unit with a 2DIN facia. Yes it has a single pair of full range preout.
__________________
Often imitated, never duplicated!
gunbir is online now   Reply With Quote
Old 30th May 2007, 22:35   #5 (permalink)
EVO6's Avatar
You can use a electronic crossover which will take his single RCA input and then split the signals for front rear and sub with a requisite HPF and LPF for all the different channels. Also this crossover has individual gain settings.. If it is to be used only for a subwoofer then u can use only the sub out of the same and use the high level output for the fronts and the rears and later you have an option to add another amp for the front and the rear..
If you choose the use all the outputs of the crossover then u need to have a minimum 5 channel amp or then 2 amps .. one which is a 4 channel for the front and the rear and a 2 channel amp for the subwoofer..
Another option is that you use this single low level (RCA) output to drive only the subwoofer amp. Most amps have built in cross over for HPF or LPF. And use the high level output from the amp of the HU to drive the front and the rear speakers..
Cheerss
__________________
Speed Thrillssss And Kills Every Other Car On The Road !!!!!!!!!--- EVO 6
EVO6 is offline   Reply With Quote
Old 31st May 2007, 01:43   #6 (permalink)
gunbir's Avatar
Exactly.
Originally Posted by angelfire View Post
Hey Gunbir...How`s the Nippon player on the SX4??...A friend of mine got an SX4..but the Ice upgradation looks a bit difficult...with a single pre-out that is..
The player is average as build quality goes. Cant comment on the sound as I wasn't really expecting much from the OE speakers and didn't Thankfully it does have a pair of preouts so thats good. Beyond that it has MP3/WMA playback and thats about it. No more features s such. If you want to replace this unit and install a regular DIN/2DIN HU get the SI2228B Kit from Scosche.
__________________
Old 31st May 2007, 07:37   #7 (permalink)
mithun's Avatar
If I replace the stock HU with a new HU, will the audio controls on the steering wheel work ?
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 31st May 2007, 11:11   #8 (permalink)
low_bass_makker's Avatar
only when you install the interface which will let you control it.....but there are infrared remote controls available for pioneer and other brands.....
Old 1st June 2007, 23:09   #9 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
EDIT: look like LBM has already answered it...Are inter faces available anywher??..for nippon...
You dont need an interface for Nippon. Only if you change the HU you need an interface for the steering remote buttons to work properly.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 2nd June 2007, 04:48   #10 (permalink)
taken from...http://www.team-bhp.com/forum/new-in...ht-ripped.html
Old 2nd June 2007, 13:07   #11 (permalink)
gunbir's Avatar
And here is the rear....
__________________
Old 24th July 2007, 10:26   #12 (permalink)
crimsonskies911's Avatar
Thumbs up SX4 ZXi - Integrated HU Audio Thread!!
I would like to get my speakers upgraded on my new SX4 Zxi which comes with an OE HU (Nippon). I am not sure whether I should go for components both at the front and back or Components at the front and coaxials at the back. Please shed some light on how should I go about this. The Dealer informed me that teh 4 OE speakers are of 6" and fitted on the doors with the 2 tweeters at the top of the front doors. I just want the factory fitted speakers to be replaced with the new ones. I am also wondering about the placement of the Crossover unit without visibly protruding inside the cabin.
Can you also please suggest some mid level (price) comps and speaker units.
Thanks in Advance for all your help!
crimsonskies911 is offline   Reply With Quote
Old 24th July 2007, 10:32   #13 (permalink)
navin's Avatar
the crossover can be hiddeninteh dash or in the door.
a good starter budget would 10K for 4 speakers. quite obviously the sky is the limit.
__________________
Scixelsyd Etinu
Old 24th July 2007, 12:33   #14 (permalink)
as Navin Ji has said what is the budget for the same...
and 10k is the entry level for the same..
Old 24th July 2007, 12:46   #15 (permalink)
Hi Navin and low_bass_makker,
Thanks for the replies. Budget is not a problem as long as it sticks to my conditions. No extra cutouts, subs and amps. Is it better to go for comps at both the front and back? If so what is the advantage?
Thanks again.
Thread Tools
Tires for SX4 ZXI prince85 Tyre & Alloy wheel Section 32 9th July 2008 01:29
Tyres for SX4-Zxi sids911 Tyre & Alloy wheel Section 54 8th December 2007 21:13
SX4 ZXi or Corolla HE ? Vishesh Sedans 50 16th November 2007 19:17
SX4 VXI or ZXI hey_basu Sedans 28 21st July 2007 21:46
How about mobile ph integrated with stereo in SX4? sathya_nars Modifications & Accessories 5 4th July 2007 13:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
