Old 16th May 2011, 11:23   #3151
nagarjun's Avatar
Thanked: 332 Times
Re: Android applications
Originally Posted by chevelle View Post
Is there any app where i can access files on my computer and possibly copy it to galaxy S.
Like i have a mp3 file which i downloaded on my computer, if i want it wireless, what are my options apart from Bluetooth transfer?
Chevelle, you can use the ES File explorer. It works on Wifi. You just need to share the folder on windows and then you will be able to access that folder from the ES File explorer.
nagarjun is offline   (1) Thanks
Old 16th May 2011, 12:30   #3152
Thanked: 658 Times
re: Android Thread: Phones / Apps / Mods
I had ordered, LG p500 through Letsbuy.com on 6th, still haven't received the phone. Even though i got around 1600 discount on a coupon, service is pretty pathetic. they took 1 week to ship the phone and from 11th its showing in transit in Fristflight courier. I am loosing my patience waiting for my phone.
shamanth is offline
Old 16th May 2011, 12:44   #3153
OHCVtec's Avatar
Thanked: 36 Times
I got mine delivered in 2 days flat, through Blue Dart. My experience with Letsbuy was very good. You might want to call up the courier company and check if your parcel is not stuck anywhere, it has happened to me earlier.
OHCVtec is offline
Old 16th May 2011, 12:51   #3154
Rehaan's Avatar
Thanked: 36,183 Times
Originally Posted by vjabraham View Post
How does the refund work if you do not like a paid app?
You go back to the app in the market, and the "install" button will now say "refund".
Given that there is only a 15min window from the end of the download -- i think perhaps google just doesn't charge your card until after 15 minutes.
Samba filesharing is good the other way around (ie it makes your phone a shared network folder)
cya
R
Rehaan is online now
Old 16th May 2011, 13:05   #3155
sandeep3in's Avatar
Thanked: 135 Times
call divert -Samsung ACE
Call divert option – The Nokia phones had an option to do a call forwarding in case of no answer .You have an option to select the time before the call is forwarded .
However on the Samsung galaxy ace there is no option to select the time before the call gets forwarded.
Has any one faced such a issue and any ways to overcome the same.
sandeep3in is offline
Old 16th May 2011, 14:44   #3156
dar3dev|l's Avatar
Thanked: 100 Times
Guys, looks like the coupon code "rcomlsb" has expired again, I tried it today to buy the LG P500 and it didnt work
dar3dev|l is offline
Old 16th May 2011, 14:46   #3157
drmohitg's Avatar
Thanked: 7,573 Times
Just saw that flipkart has dropped the price of samsung galaxy s by 2k. Does this mean that the launch of the Galaxy s2 is gonna be any day now in India?
drmohitg is offline
Old 16th May 2011, 17:21   #3158
chetans's Avatar
Thanked: 86 Times
I am facing probs in using tethering on ubuntu 9.10 with lg optmius p500.
1. wi-fi hotspot.
easy to configure, wherein we can give name to the wifi connection.
the ubuntu successfully detected the connection. but somehow was not able to access the net.
what might be the issue?
2. usb tethering:
There is no provision to give name to this connection in phone.
the ubuntu lappy was picking the connection that was setup for home broadband. I did try all the conenctions available, but with no access to net.
Anyone faces these issues?
chetans is offline
Old 16th May 2011, 18:45   #3159
driving_smartly's Avatar
Thanked: 306 Times
Samsung has announced Gingerbread updates for its following devices
1. Galaxy S
2. Galaxy Ace
3. Galaxy Fit
4. Galaxy Mini
5. Galaxy TAB
driving_smartly is offline
Old 16th May 2011, 20:31   #3160
chevelle's Avatar
Thanked: 554 Times
Thanks. I installed it, but when i add new server or scan it, it doesn't detect my computer through LAN. I scanned, but it doesn't display my computer name.
I disabled firewall in computer. But no luck. I tried manual installation and it gives error like login failed, wifi not connected and such options. none of which are true.
Any help?
chevelle is offline
Old 16th May 2011, 20:33   #3161
Bluengel180's Avatar
Thanked: 758 Times
Samsung announces Gingerbread update roll out for Galaxy S, Ace, Fit, Gio, Mini, Tab | AndroidOS.in
Bluengel180 is online now
Old 16th May 2011, 21:07   #3162
nagarjun's Avatar
Thanked: 332 Times
Not sure what happened suddenly, I was using it a while back and had uninstalled it. Installed it again and tried, but facing the same problem, "not able to find the server". Will try few more options and get back to you. There is some discussion on the same in the forum mentioned below ES File Explorer - Page 2 - Droid Forum - Verizon Droid & the Motorola Droid Forum
nagarjun is offline
Old 16th May 2011, 22:51   #3163
Thanked: 24 Times
I just noticed a wierd behavior with alarm clock. Try this:
1) Set alarm for a particular time. Close alarm ap. Goto task manager and clear memory. The alarm d
Fails to work.
2) As before set the alarm. But this time close the clock app using the standard back button. Do not clear memory. In this case the alarm goes on as usual.
This seems to suggest that android 'Clear memory' function closes even the alarm clock.
Iam on i9003 froyo.any body else has noticed this behavior?
djkher is offline
Old 16th May 2011, 23:31   #3164
amit_mechengg's Avatar
Thanked: 2,263 Times
i am planning to buy the new Motorola XT5 quench/zeppelin which runs on android 2.1 OS.
http://www.flipkart.com/motorola-zep...bctfgsdzhdc8kv
The specs are as below
DisplayType: TFT capacitive touchscreenResolution: 320 x 480 pixelsColor: 256K colorsSize: 3.2 inches
CPU: Qualcomm MSM7201A 600 MHz Processor
Internal Memory: 512MB ROM, 256MB RAM; 2 GB MicroSD card included
I am having a few doubts which only Android phone users can answer:
1. Will the screen be crisp with the above specs
2. With the 600 MHz processor and 512MB ROM will it be fast and lag free?
3. Can i upgrade the 2.1 android to 2.3 gingerbread? does the phone support it.
4. does the GPS with A-GPS runs comfortably without consuming the talktime i.e download charges of net.
any other perfect suggestions within 13000 rs?
amit_mechengg is offline
Old 16th May 2011, 23:41   #3165
Thanked: 758 Times
Motorola Zeppelin Lite Xt5 Xt502 Price In India: Buy Motorola Zeppelin Lite Xt5 Xt502: Price, Reviews: Flipkart Mobiles
The screen is far from crisp.and the quench wont be getting any android updates either
if you want a crisp screen in that budget go for the DELL XCD35.only android below 15k with a 800*480 screen,and 512 ram (unlockable) as well
a 600mhz processor is fast enough for android.what you'll miss out on are 3d games and flash support
The XCD35 also comes with all india MMI maps.so you wont need a data connection while using GPS
