Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flowing exhausts....its all in here!
Thread Tools
Old 26th August 2007, 14:37   #16 (permalink)
gd1418's Avatar
Default Cleaning kit
One can get K&N filters and cleaning kits in Delhi from its authorised dealer:
Mr.Grover
Bharat Car Accessories
2268/68, Abdul Aziz Road,
Karol Bagh, New Delhi
Cell: 9811225557
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
gd1418 is online now   Reply With Quote
Old 26th August 2007, 14:52   #17 (permalink)
rishibravo's Avatar
gd sir ..to be very frank I got my K&N extreme from him and it wasnt a very nice experience (both the price and the install). I wont like to mention how much I paid. I would not recommend Bharat car to anyone unless there is no other option left.
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 26th August 2007, 15:29   #18 (permalink)
gd1418's Avatar
Oh,oh. I was planning to install a K&N Extreme in my Scorpio from him. In that case who else do you reccommend?
__________________
Old 26th August 2007, 16:36   #19 (permalink)
rishibravo's Avatar
you are in ggaon... Why dont you talk to Arush. I am sure he would do the job for you.
__________________
Old 26th August 2007, 21:09   #20 (permalink)
rishibravo's Avatar
ok so I utilized my sunday and cleaned my K&N with my newly acquired K&N cleaning kit and its very easy to do. Here are the before and after pics of my K&N extreme
Before Cleaning:
After Cleaning:
I still have to take a drive and see if the cleaning has made any difference. The amount of dirt which came out after the wash really scared me. Believe me you should be thankful to your filters
__________________
Old 26th August 2007, 23:33   #21 (permalink)
kpzen's Avatar
Damn..!! Life of a student-First accumulate money to get the K&N and now need to get this cleaning kit for 1K too..
__________________
Prajesh
If you think your teacher is tough, wait till you get a boss.
kpzen is online now   Reply With Quote
Old 27th August 2007, 09:37   #22 (permalink)
rishibravo's Avatar
A cheaper solution is to get it cleaned from somewhere. Shouldnt cost you more that 200 bucks.
__________________
Old 27th August 2007, 09:45   #23 (permalink)
saumil's Avatar
Lightbulb
Any recommendation as to where i can get it cleaned in Mumbai?
__________________
Challenge Everything...
saumil is offline   Reply With Quote
Old 27th August 2007, 10:18   #24 (permalink)
crazydiablo's Avatar
I also need to get down to cleaning it one of these days. Its run for 19K and looks dirty now. Since I dont have the stock filter, I will lose one half day for the whole process. Cleaning kit has been with me for some time now.
Make sure the filter is dry and properly oiled before plonking it back. Too much oil and too less oil, you are in trouble.
crazydiablo is offline   Reply With Quote
Old 27th August 2007, 14:24   #25 (permalink)
BUSA's Avatar
Four Seasons Tardeo, near Cross roads.
__________________
thecarsandmore.blogspot. com
Old 27th August 2007, 14:57   #26 (permalink)
razor4077's Avatar
How about a step-by-step guide on cleaning one of these? I'm sure it'll be useful for all of us trying a DIY for the first time.
razor4077 is online now   Reply With Quote
Old 27th August 2007, 16:32   #27 (permalink)
BUSA's Avatar
Step 1 - Remove Filter
Step 2 - Spray with KnN Cleaning Oil
Step 3 - Wash with Water
Step 4 - Let filter Dry(Naturally)
Step 5 - Re-oil with KnN Oiling
& Voila.....!!
__________________
Old 27th August 2007, 16:44   #28 (permalink)
rishibravo's Avatar
Default Step by Step Guide to recharge your K&N filter
I would like to share the step by step procedure for cleaning your K&N filter. The instructions for cleaning a stock replacement filter can be seen found here and it was the same on the instruction leaflet in the K&N recharger kit. It was pretty helpful. The cleaning process for conical filter is the same but a little tricky
Tips before you start:
  • Make sure you have ample of time with you because you will need the time for the filter to dry up.
  • Do the cleaning and oiling in an open area and definitely not in a room (I learnt this the hard way...come to my room and you can still smell the cleaner)
  • If you are dealing with a universal filter then you have to give it a lot of time to dry. Because of the mesh on the surface it will appear to be dry but if you place a tissue on it and press gently you will find out its not. In order to make sure that the filter is completely dry I would suggest you leave it to dry overnight.
Step by Step Procedure:
  1. Take the filter out carefully off the plumbing and preferably when the engine bay is not hot to avoid any injuries .
  2. Once the filter is out, gently tap it with any hard object to remove the superficial muck and dirt sticking to it (Always tap on the rubber housing of the filter and never on the mesh/pleats ). take a worn out dry tooth brush or any soft bristles brush to remove any dirt that you can see sticking to the filter.
  3. Now take the cleaner bottle (which in my case was an aerosol spray ) and spray on the filter in this order(as it says in the leaflet) : * Spray the inside (cleaner side) of the filter. * Spray the outside (dirtier side ) of the filter.
  4. Spray enough cleaner throughout the filter so that it looks saturated. Wait for 10 mins ( Do not let the cleaner dry off on the filter)
  5. Wash the filter with cool low-pressure water. Flush the dirt out of air filter by applying water to the clean side of the filter.
    Do this process close to the drain because your filter is dirtier than you think. After the wash inspect the filter for any dirt . If there are dirty patches then apply the cleaning spray on that area and wash it off.
  6. After washing shake off the excess water from the filter ( and it requires a lot of shaking ). Now let the filter dry for a few hours (preferably overnight).
  7. Once the filter is COMPLETELY dry apply the K&N filter oil (in my case this is also in form of aerosol spray). Do not spray in a zig-zag fashion or in circles but Spray along the length of the pleat till a uniform pinkish red colour is obtained. The colour is similar to the colour of a new K&N filter. Dont forget the top portion of your filter if its an extreme filter (you have pleats there too).
  8. Allow the oil to get absorbed by the filter for 20-30 mins and then check for any damages to the filter.If everything looks fine then install the filter back and tighten the clamp screw. Your K&N is now recharged .
PS: Please wash your hands properly with soap after handling these cleaning kit bottles
EDIT: I hope I didnt go overboard with this. I felt I did after I saw BUSA's to the point procedure
__________________
Old 27th August 2007, 17:59   #29 (permalink)
razor4077's Avatar
Nope... not at all! Was very helpful indeed. Thanks for the step-by-step
Will try it out this wknd!
Old 27th August 2007, 18:18   #30 (permalink)
narayan's Avatar
thanks rishi bravo - i was just about planning to have the filters cleaned and this thread really helps
do share the experience after u replaced it ( any perceitible improvement in pick up ? )
narayan is online now   Reply With Quote
Thread Tools
Performance Conical Filter and Sparkplugs for Pulsar 150dtsi..??? ramie2400 Motorbikes 43 12th March 2008 17:02
K&N Conical Extreme Air Filter for Sale Slash Shifting gears 5 26th November 2007 18:12
Whats wrong with this K&N conical filter assembly rishibravo Modifications & Accessories 25 18th April 2007 18:48
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 19:33
Fitting K&N Conical Filter. MexXxentric Modifications & Accessories 10 14th June 2006 12:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
