| Modifications & Accessories Engine swaps, forced induction, tyre upgrades, free flow exhausts; it's all in here! |
| | Thread Tools |
| | #76 (permalink) |
| Senior - BHPian | ![]() not as bright as i wanted them to be. Planning to upgrade them to bigger high brightness LED's ![]() the lights are not blue . they are a bluish white. check out the previous posts for the actual LED color. i think the white balance was messed up in my can when i took it
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 11th February 2009 at 00:19. |
| | #77 (permalink) | |
| Senior - BHPian | Quote:
__________________ "It only ends Once. Anything that happens before that is just Progress" ---- Swift ZXi | 5100 | 60.9 | 475a | 1300a | 8" | |
| | #79 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
How many LEDs did you use? And also, are these two sets of lights?
__________________ "You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer | |
| | #81 (permalink) |
| Senior - BHPian | didnt get time to upgrade the taillamps, but did swap the LED's in the interior light with bigger ones. I swear this is the last time i post pics of the interior lamp, and will show the numberplate lights next time ![]() ![]() the earlier ones(two rows in the back) were smaller and more bling ( blue white in colour). these are pure white and brighter too!
__________________ '07 Indica DLG - Almost a DLX |
| | #82 (permalink) |
| BHPian Join Date: Dec 2006 Location: Kolkata
| I'm running four white power LEDs in series directly in my Zen. The LEDs are square with four legs, very bright and operates on 50mA. Look at the below mentioned datasheet for example: http://www.vishay.com/doc?81260 These type of power LEDs are available in market. The white ones are available at Kolkata for about 15-20 Rs. a piece. |
| | #85 (permalink) |
| Senior - BHPian | ![]() the board and the DIY adapter to fit in the bulb's socket ![]() how it fits where the bulb used to ![]() testing! ![]() stuck inside the numberplate light assy with double sided tape ( I love that stuff) ![]() lit up!
| | #86 (permalink) |
| BHPian | I went shopping and ended up buying 100x10mm white LEDs and !00x520 ohms resistors and 5xuniversal PCB (2inchx3inch) Price: Rs 2.75 per LED 15 paise per resistor Rs 5 per PCB I am no electronics guy. I went to this shop on SP road in Bangalore and just asked for LEDs thinking i will connect in series. But the shop keeper was keen on knowing what i was upto as he till date never had a person buying only 100 pieces. reson being he was a wholesaler. When i explained the DIY plan, he suggested me to use 520 ohms resistor with each LED as the brightness will be uniform. Made sense to me as he was earning only Rs15 for 100 resistors. Okay, Brought the stuff home and also purchase a soldering kit for 50 bucks from the same guy. First tried my hand at soldering and was feeling confident. Then planned the way i needed the lights. Also used a sand paper to make the LEDs rough as the light looked like a spot light that a wide spread one. Note to all electronics guys: You may puke looking at my circuit diagram and the way i have soldered. Here is the circuit diagram. ![]() Rest of the pics are self explanatory. I did the same for the Tata safari roof lights and the number plate light also. Will post the pics later
__________________ Cheers! Shreyas "Two Wrongs don't make a Right, but three Rights make a Left!" Last edited by shreyasma : 22nd February 2009 at 23:25. |
| | #87 (permalink) |
| Senior - BHPian | hey, the last pic is for the number plate lights right? did you have to take the number plate light apart ? shreyas, bend the outer LED's outwards, increases the spread of teh beam for the numberplate lights ![]()
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 23rd February 2009 at 07:49. |
| | #88 (permalink) |
| Senior - BHPian | 520 ohms and one LED might not be the best option. 1 - you are wasting about 75% of the power on the resistor 2 - at 14.4V, the resistor is dissipating almost 250mW, its max power dissipation. they will get hot and may die soon. If they do, consider changing to 2 or 3 LED's in series and reducing the resistor values ( will be glad to help you with the values ) . You might have slight variation with the engine on and off, but the resistors and LED's should live longer. they are cheap, but removing the thing and desoldering/resoldering them is a painPS: I recently had a chance to see the Prices of some LED lighting stuff, and the prices are 10x how much its costs to make these. Isnt DIY great ![]()
| | #89 (permalink) | |
| BHPian | Quote:
Arey bhai..please do help with the values. i dont understand all these even if i try.
__________________ Cheers! Shreyas "Two Wrongs don't make a Right, but three Rights make a Left!" | |
| | #90 (permalink) |
| Senior - BHPian | LED Series Resistor Calculator I would recommend 100 ohms in series with three White LED's 270 ohm, half watt ( bigger) resistors with two white LED's these values will be different for other colours
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 23rd February 2009 at 11:31. |
| Thread Tools | |
Similar Threads | ||||
| Unlocking the Ford Ikon : DIY Boot Release set-up | benbsb29 | Modifications & Accessories | 92 | 31st August 2009 12:21 |
| DIY: Matte black- Alloys, Calipers, Bumper trims on the 1.6 Ikon. | danlalan | Modifications & Accessories | 13 | 8th April 2009 00:51 |
| Quality Super Bright LEDs, where can I find them ? | s0uljah | Modifications & Accessories | 20 | 20th February 2009 17:20 |
| Skoda Octavia Angel Eyes and LEDs | abhinav.gupta88 | Modifications & Accessories | 77 | 15th January 2009 17:29 |
| Experiment! Replacing conventional headlights bulbs with LEDS! | frankmehta | Modifications & Accessories | 17 | 1st December 2008 00:55 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
