Re: Ohc 1.5 Vs Ohc Vtec Thank you for reviving such a old thread!! You gave me a lot of material to troll my close friends regarding some of the posts they made here!!
Anyway, getting to your questions, please find my answers in bold! Quote:
Originally Posted by rohan_cherian AFAIK, the only difference between the B15C2 and the GXi is the SOHC VTEC head.
That includes the cams, the solenoid, the switching mechanism and the ECU. Plus, pistons, crankshaft, wiring harness etc etc..
Is it really possible for one to get the VTEC head onto a 1.5? Will it be expensive? Yes it will fit perfectly, will it work? NO (just by swapping the head, it won't. You will have to do a lot of other work which will not be economical for the the minimalistic gains)
Or can cheaper mods compensate/overcompensate for the lack of the top end whack of a 1.5 over a VTEC? Yes, you could, but it won't be cheap!
I'm a proper novice so I would really appreciate it if the jargon is kept to a minimum, or explained. No problem buddy! Its an evolving process, everyone has been through this phase! That's why we have forums like tbhp! We are here to help and learn! Hope this helps!
Thanks. |
