Old 14th September 2009, 22:53   #1186
Rahulk76's Avatar
Thanked: 235 Times
Sample Schematic Layout of Delphi DICOR
Ill let the attached images do the talking
The Tata Safari 2.2L Technical / Problems Thread-dicor1.jpg
The Tata Safari 2.2L Technical / Problems Thread-dicor2.jpg
The Tata Safari 2.2L Technical / Problems Thread-dicor3.jpg
The Tata Safari 2.2L Technical / Problems Thread-dicor4.jpg
The Tata Safari 2.2L Technical / Problems Thread-dicor5.jpg
Rahulk76 is offline
Old 15th September 2009, 20:48   #1187
Hello All,
Two things I have noticed recently, would like to know if they are normal.
After a long drive with AC (always on while driving), water drips from somewhere near under the gear lever, is this alright?
Never bothered to look in the RVM earlier during hard acceleration, but that other day I just took a look and saw quite a cloud of black smoke. Same thing today evening, took off hard in 2nd, something I generally do when the road is free ahead, take RPM close to 3k before changing to 3rd and a quick 4th to follow and then after a small burst in 4th, take 5th and settle down, get a good surge in power till I reach 80-90 and then maintain a constant cruising speed of 90-100 mostly when the roads are good.
Under normal driving, where I generally shift at around 2.5K on the RPM, there is no black smoke, tried the same immediately after I noticed the smoke today eve. Normal behaviour?
I do not usually shut down at signals, AC is always running, I am getting 9.5-10 kmpl consistently with normal diesel on Bangalore city roads for more than a year now.
Input/comments are very much welcome.
Regards.
aburagohain is offline
Old 15th September 2009, 21:05   #1188
unni.ak's Avatar
Thanked: 84 Times
Originally Posted by aburagohain View Post
Hello All,
Yes, this is pretty normal. Nothing to worry.
Regards.
System D can help to some extent. But, diesels do smoke under hard acceleration. Thats just in the nature!! Nothing to be overly worried about since you have no smoke under normal driving.
unni.ak is offline
Old 16th September 2009, 07:20   #1189
harjeev's Avatar
Thanked: 296 Times
Small Update
The BEAR having run for 35K kms I was getting the tyre rotation done. The right side tyres were done without any issues. i.e. front to rear and vice versa.
However the front left side tyre dint budge (dint come off) and was somehow jammed!!! Thank god this did not happen at night with the family!!!
Further there was alot of play in the Front Left tyre. So I sent the BEAR to the workshop and they changed a part and now its fine. The part cost approx 800-900 bucks and was changed under warranty so FOC. I will upload a scanned copy of the bill later in the day!!!
harjeev is offline
Old 16th September 2009, 10:06   #1190
harjeev's Avatar
Thanked: 296 Times
Hey guys
here is the scanned copy of the invoice!!! The tyre rod was changed
The Tata Safari 2.2L Technical / Problems Thread-safari-tyre-play-check-15-sep-2009.jpg
harjeev is offline
Old 16th September 2009, 10:21   #1191
Thanked: 95 Times
Hello All,
Regards.
Your Bangy mileage is brilliant. I used to get 8-8.5 in Bangy and am getting the same in Mumbai now. Guess its up to driving style 'coz i have extracted 14kms+ in a purposely leisurely Bangy-Chennai drive.
DaiusPitar is offline
Old 16th September 2009, 13:29   #1192
jkdas's Avatar
Thanked: 1,497 Times
Originally Posted by harjeev View Post
Hey guys
Got mine too changed sometime back under warranty; I think two pieces.
jkdas is offline
Old 16th September 2009, 13:53   #1193
Rahulk76's Avatar
Thanked: 235 Times
Hey guys
JK
Can you please share these details, e.g. why they were replaced ?
Thnx
Rahulk76 is offline
Old 16th September 2009, 13:59   #1194
rideon's Avatar
Thanked: 24 Times
Rahulk76,
Thanks for sharing the Delphi Dicor Sample Schematic layout. This definitely helps me in understanding the technicalities a bit more for the Dicor.
Rideon.
rideon is offline
Old 16th September 2009, 17:19   #1195
harjeev's Avatar
Thanked: 296 Times
Originally Posted by Rahulk76 View Post
JK
Thnx
Small Update
The front wheel had a lot of play in it, Play in the sense that when the vehicle was jacked up and the steering wheel was locked. I was able to move the wheel with my hands. Move not as in rotation but left & right.
Are you getting my point???
So I thought that its better get it checked up before my basic warranty expires.1st Nov 2009 will be the 2nd birthday for the BEAR
harjeev is offline
Old 16th September 2009, 18:00   #1196
simply_sunny001's Avatar
Thanked: 19 Times
Harjeev,
I think basic Warranty is 1.5 yrs not 1 year.
simply_sunny001 is offline
Old 16th September 2009, 18:13   #1197
harjeev's Avatar
Thanked: 296 Times
Hi sunny
Its 2 yrs for the 2.2 and another 2yrs for the extended warranty!!!
You see I got the Headlight & the tie rod changed, whereas my BEAR is 1 year and 10 months old!!!
harjeev is offline
Old 16th September 2009, 18:28   #1198
Thanked: 19 Times
Hi sunny
Oh thats great cos for 3.0 it was 1.5 years. thanks for correction.
I hope you have got Extended Warranty too.
Old 16th September 2009, 19:13   #1199
jkdas's Avatar
JK
Thnx
It gave some metallic clang/ringing sound over potholes.
jkdas is offline
Old 16th September 2009, 20:03   #1200
v&v
v&v's Avatar
Thanked: 1,234 Times
Got the retro done for my beast.
1. Ecu software updation.
2. Ecu cover
3. Some updation left door only.
4. Timing cover change.
No timing pulley or belt change.
My initial feed back 3rd gear got more range.
v&v is offline
