Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 13th December 2014, 12:04   #91
sriny_blr's Avatar
Thanked: 52 Times
Re: Mahindra Transfer Cases
Gents,
Can anyone help me with the Specifications of a 2005 model MM550XD (ex-army) ?
Sreeni
sriny_blr is offline
Old 15th December 2014, 13:25   #92
ex670c's Avatar
Thanked: 2,170 Times
Originally Posted by sriny_blr View Post
Gents,
Hi Sreeni,
Please use the search function in the sub-forums.
http://www.team-bhp.com/forum/4x4-ve...war-horse.html
http://www.team-bhp.com/forum/4x4-ve...4-jeeps-3.html
http://www.team-bhp.com/forum/4x4-ve...le-option.html
http://www.team-bhp.com/forum/4x4-ve...8l-petrol.html
Arka
ex670c is offline
Old 16th December 2014, 08:54   #93
sriny_blr's Avatar
Thanked: 52 Times
Hi Arka,
Thanks I did search forum on this and have gone thru 2 of the above 2 posted links and following closely few of the BHPians 550 threads closely.
But not very clear on the specs for the particular model for year 2005
Engine - XD3P.
T/C - T18
GB = KMT90 or BA10 or NGT 520/530 ?
Did 5 speed avatar on MM550 started in 05 or 06 ?
Sreeni
Old 17th December 2014, 10:56   #94
ex670c's Avatar
Hi Sreeni,
The NGCS MM550XD came with a NGT520B from 2006.
IIRC Sreejesh's War Horse came with a NGT520B .
Arka
ex670c is offline   (1) Thanks
Old 17th January 2016, 12:18   #95
Thanked: 705 Times
Can anyone help me identify this Mahindra Gearbox and what type of transfer case attaches to it?
jyobeb is offline
Old 31st January 2016, 18:40   #96
ringoism's Avatar
Thanked: 4,490 Times
Could that be the 4x4 version of the BA-10, as used in pre-NGT 4x4 Armada/Bolero/Scorpios? If so I'm assuming it would take the Borg Warner TC; the splines and mounting pattern look strangely familiar (I've got the Armada Borg Warner in the Marshal)...
ringoism is offline   (1) Thanks
Old 31st January 2016, 21:09   #97
Thanked: 705 Times
Actually discovered it's an NGT530R
jyobeb is offline
Old 31st January 2016, 21:11   #98
Thanked: 705 Times
With the borg warner case fitted.
jyobeb is offline   (1) Thanks
Old 5th February 2016, 21:59   #99
Twinn's Avatar
Thanked: 286 Times
Looks like you had the fabricate an adapter?
Twinn is offline
Old 5th February 2016, 22:42   #100
Thanked: 705 Times
Actually it's a mahindra adapter plate.
jyobeb is offline
Old 7th February 2016, 10:22   #101
prabhuav's Avatar
Thanked: 129 Times
That is indeed a NGT530R. The bell housing is large and meant to mate to the mHawk, with the slave cylinder inside it.
The New NGT530, that comes in the That, the bolero storm and the Xylo (all there with the 2.5L engine) shares the from part of the gearbox housing with the 530R. The real housing is different.
The older 530 was a close cousin of the BA10 - came with the 2.6L CRDe engine..
prabhuav is offline   (3) Thanks
Old 6th July 2016, 20:07   #102
Thanked: 46 Times
shiftster site is not working, any way to get that??
jobug is offline
Old 6th July 2016, 21:13   #103
Thanked: 46 Times
Cconvert brog warner electric shift to manual
Hi all,
I am a newbie here. I have a strange problem. I own a Scorpio Getaway 2011 make. My problem is the electric shifter is not properly working. Is there any way to change it to manual shifter? I have seen a guy fitted with shiftster on Armada Grand in the forums, but shiftster site is not working. Any options there? Kindly help me.
jobug is offline   Received Infraction
Old 8th July 2016, 09:13   #104
4x4addict's Avatar
Thanked: 4,648 Times
The shiftster is a crude mechanism for which you need a trap door to open and put your hand below. It is not a practical solution.
There is a person in pollachi who makes manual conversion for the electrical borg warner. Please contact him. don't wire any money ahead.
go there and get it fixed. Cash & Carry.
There is also a senior Borg Warner employee who is plugged into the off-road/automotive community and he will help you to diagnose and fix your t-case problem. I will ping you pm you his contact details.
4x4addict is offline
Old 25th January 2017, 08:40   #105
mohang_j's Avatar
Thanked: 18 Times
Hi 4X4addict
Please share the contact details.
mohang_j is offline
