Old 26th June 2018, 19:00   #3691
Thanked: 3,346 Times
Re: The Bicycles thread
Originally Posted by petrolhead_neel View Post
Posted a query sometime ago, but didn't get any help. :(
Check out Hero Traveller (INR 9545):
https://herocycles.com/TRAVELLER-700...ed/product/274
Hero Zephyr 7S (INR 11430):
https://herocycles.com/Zephyr-7S/product/250
Specs are very good for the price points.
anandpadhye is offline
Old 29th June 2018, 17:07   #3692
Thanked: 789 Times
Originally Posted by anandpadhye View Post
I have done hill rides primarily on metrix, will do these on Ultra soon
Thanks for the detailed explanation Anand! Actually what I was trying to undersand is ratio that I can use for climbs. I am not referring to Sinhagad kind of climbs but steepest ups and downs we have on highways around Pune.
In an ideal scenario, one should buy a bike with 105 minimum, but with limited budget I might have to settle for claris. So I have analyzed my usage pattern and the ratios that I use on my current bicycle.
On steep climbs I have used 28 chain ring x 22 cassette which gives me a ratio of 1.27. On slopes, naturally, I have used 48x14, the smallest cog that my bicycles cassette has. But this is not a big factor in the conclusion that I am arriving at.
Most of the bikes with Claris come with 11-32T or 11-30T cassettes. Due to this the jumps are bigger from one gear to another. If I buy a bike with Claris, I am thinking of buying a new cassette, most probably 13-26T, that has smaller jumps, and install on the bike.
This will give me a lowest ratio of about 1.31, much closer to what I used on Hybrid. Also, with lighter road bike compared to hybrid, I hope this would be sufficient for climbing.
I had finalized Giant Contend 3 but looks like the availability is quite poor. The stores are just giving some random timelines. One of the store even said, 2018 models stock won't be coming now and in 3 months time 2019 models would be launched.
shipnil is offline
Old 3rd July 2018, 14:46   #3693
Have you checked out the new road bike from Montra "Redeem":
https://montra.in/road-bikes/redeem-2018/
For INR42500, Rear Derailleur: Sora Front Derailleur: Deore.
50/34 in the front, 11-28 in the rear.
BTW, I did Sinhagad on Metrix past Sunday. Made it to the top without touching the feet down even once but it was hard. First 3km I managed in the middle chainring (36T), for most part of the remaining 5, I had shift into the smallest chainring. But I made it!
Ultra 700 does not have the 3rd chainring, it's got only 52/36. Not sure if I would be able to make it to the top on Ultra (it's lighter than Metrix by 3kg, so that will help but not sure if that can fully compensate for the missing low gear). I will try soon and update.
Old 3rd July 2018, 21:08   #3694
graaja's Avatar
Thanked: 25,621 Times
This will give me a lowest ratio of about 1.31, much closer to what I used on Hybrid. Also, with lighter road bike compared to hybrid, I hope this would be sufficient for climbing...
Sorry about the delay in reply. Had been traveling most of last week and could not respond.
The actual ratios that would be suitable for you depend on mainly two factors - the grade and your FTP (functional threshold power). If you have a high FTP, you can climb at a higher ratio. But the steeper the climb becomes, you will still need lower ratios.
When I was riding my Scott Speedster, I was weighing around 89kg and was not that fit. The Speedster had a 50/34 crank and 12-30 10 speed cassette, which gave the lowest ratio of 1.13, and highest ratio of 4.16. And in the hill climbs of Kotagiri and Valparai, I used to be on the lowest of the gears and still would long for a lower gear. In flats, I used to be able to ride at the highest ratio.
Now I am 78 kilos and much fitter than earlier, and my Scott Solace has a 50/32 crank and 11-32 11 speed cassette, which gives a lowest ratio of 1 and highest ratio of 4.54. In flats I ride with the highest ratio. But I have not taken the Solace to a hill climb yet. So, I am not sure what ratios I will be using now.
The general thumb rule is if you expect lots of hill climbs, go for the lowest available lowest ratio. If you have a higher power, you can always ride at higher ratios, but if the climb becomes too steep, you will run out of ratios.
In your position, I would sacrifice shift smoothness and go for the lowest available ratio.
graaja is online now
Old 3rd July 2018, 22:27   #3695
Sudipto-S-Team's Avatar
Thanked: 292 Times
Are There Any Zwifters on team-bhp
Of late I have started Zwifting on my Elite Qubo (the full name is too complicated for me to remember but if you insist I can find it out again) at home and enjoying it thoroughly in Watopia. I was wondering if any team-bhp member is a Zwifter and whether we can ride together. My screen name is SRoy. Please let me know if you are there. I am sure there are others around.
For those who might not know - Zwift is a $ubscription based computer game kind of thing for your smart trainer (for cycles). Here you choose a cycling route and the software tells your trainer how hard or easy the path is and you choose the gears accordingly. If it is a hard incline you immediately understand. You can see yourself cycling on the computer screen. Believe me - it's hard, fun and closest that comes to real world cycling at home. In certain ways it's a lot tougher than real cycling.
Sudipto-S-Team is offline
Old 4th July 2018, 10:06   #3696
From 89 to 78! That's massive!!Also, Solace must be lighter than Speedster so you must try those hills now to see how lighter (and fitter you) on lighter and stiffer bike perform compared to the previous ride on the same route.
Old 4th July 2018, 11:46   #3697
yogi1771's Avatar
Thanked: 16 Times
Re: Are There Any Zwifters on team-bhp
Have been on Zwift from the time it was free but not that regular find indoor training very boring. My screen name: Y.Shetty.
What time do you train maybe will join you?
yogi1771 is offline
Old 4th July 2018, 22:31   #3698
Thanked: 789 Times
That's a TT bike. Right now I think I would want to go for a normal road bike.
Thanks for your explanation Raaja! Need some advice on selection. I have more or less finalized on a Giant bike with Claris, mainly because it is a reputed brand and I wanted a black bike (read, non flashy). But now I see there is some sale going on Btwin Triban 540 bike, that has Tiagra groupset. It is on sale at 55k, after discount (list price 69k) now. The only thing that is bothering me is its color Red. Am confused. Shall I check out Triban and buy if size fits or wait for Giant
shipnil is offline
Old 4th July 2018, 23:19   #3699
ebonho's Avatar
Thanked: 11,175 Times
My brevet bike.
Nice to see this thread active and guys grinding hard!
Cheers, Doc
ebonho is offline
Old 4th July 2018, 23:22   #3700
ninjatalli's Avatar
Thanked: 17,770 Times
Just ride both bikes and take the final call. Giant in the end is a mass brand; not a far shift from Btwin.
ninjatalli is offline
Old 5th July 2018, 08:53   #3701
Thanked: 2,736 Times
Originally Posted by ebonho View Post
My brevet bike.
All the Best Doc.
Glad to see you post on forum again, that too on this thread .
sukiwa is offline
Old 5th July 2018, 09:17   #3702
graaja's Avatar
Believe me, the color will be the least of the attraction - you will be. So don't worry about the color and go by the components and comfort
As Ninja said, Giant is also a mass market brand and the Triban would be as good as Giant.
Old 5th July 2018, 09:19   #3703
ebonho's Avatar
Originally Posted by sukiwa View Post
All the Best Doc.
Thanks bro. How's your cycling going? Same GT?
I have my last shot at the SR on September 29. The BRM 600 (no idea what route they're gonna give - they've already done the relatively flat and easy Kolhapur Curry in January, so ..
Just got back on the saddle after Jan. Got ITB during my 400, but pulled myself through on willpower and plain cussedness. But DNS'd the 600 after that.
Cheers, Doc
P.S. I'm coming back here after a couple of years. Have they removed the Thanks option?
ebonho is offline
Old 5th July 2018, 10:28   #3704
graaja's Avatar
I am sure you will complete the SR this time. Good luck and all the very best
Old 5th July 2018, 14:42   #3705
ebonho's Avatar
Thanks buddy.
Trying to do a few things differently.
Training volume.
Climbing volume.
Saddle height and tilt.
Handlebar position.
Some strength training.
Stretching.
Need to get a foam roller. Also need to get back to my cycling weight of 80 kilos - the last 5 months of inactivity have pushed me back to 90.
Cheers, Doc
ebonho is offline
