Old 28th April 2008, 18:36   #106
headers's Avatar
Thanked: 564 Times
Originally Posted by nitrous View Post
OT:
Welcome to Headers on Team-BHP
Its strange..you welcome me after being on the forum for 1.5 years and creating a racket.
headers is offline
Old 28th April 2008, 19:08   #107
shuvc's Avatar
Thanked: 359 Times
Originally Posted by shuvc View Post
I seem to have wriggled out of the problem. I did try grounding the HU as @gunbir had confirmed. That did not work.
I had my speakers wired in parallel. Left front and rear to one channel of the 75.4, right front and rear to another channel. Disconnected the rear speakers. Voila!
So now I'm running only the fronts and sub. Rears disconnected.
Spoke to soon. The whine is back. Although above 3K rpm. So it's not perceptible in city driving. Sigh.
Will update after I rewire.
shuvc is offline
Old 28th April 2008, 22:11   #108
sonic_boom's Avatar
Thanked: 16 Times
Shuvc, do you really think disconnecting the speakers is a solution??
sonic_boom is offline
Old 28th April 2008, 23:11   #109
bottle's Avatar
Thanked: 294 Times
was having a problem with whine in rear speakers as well .. even connecting rca wires directly from head unit to the amp without touching it caused it and disconnecting them stopped the whine. only solution was to reduce the gain/level for rear speakers on amp and it seems to work. set it to about 40% now. installer said that alternator is leaking current and there is a mild voltage all over the car body (metal) and to ask TASC to clear the grounding/fix it. need to check with them in the next service
bottle is offline
Old 28th April 2008, 23:23   #110
shuvc's Avatar
Thanked: 359 Times
Nope. Don't think it's a solution. Since I will be wiring the rears again. But I've been trying all sorts of things. Nothing has worked on a consistent basis.
A few more todos.
- amp power wire is very close to speaker wires near the amp. Will try to put some distance between them.
- will try reducing the gain on the amp
- might replace RCAs.
shuvc is offline
Old 29th April 2008, 08:17   #111
rocksterraghu's Avatar
Thanked: 239 Times
shuv, my suggestion would be to prioritize it this way:
1. Try reducing the gains
2. Check the RCAs
But I did not understand what you meant in your first point! Maybe a picture would help.
rocksterraghu is offline
Old 29th April 2008, 10:31   #112
amit_mechengg's Avatar
Thanked: 2,263 Times
there is one method which my installer told me. he said that i put a capacitor over the alternator and ground it. he said go to any car mechanic and ask him to do. however no one on the forum confirmed this. i had asked couple of times. can someone verify this?
amit_mechengg is offline
Old 29th April 2008, 13:26   #113
navin's Avatar
Thanked: 9,957 Times
Nope. Don't think it's a solution. Since I will be wiring the rears again. .
are you guys only having a problem with whine when the rear speakers are connected?
a few simple checks.
1. power wire should not run parallel to RCA wire. Power wire can cross RCA wire at 90 deg but it should not run parallel.
2. Use good RCA wire. I have heard of too many problems with brands like BOSS. Avoid them. It is just not worth the trouble. Stick to well known International barnds like Monster, etc..
3. For the RCA wire make sure it does not have too many sharp bends. these bends can casue small ractures in the shield or wire and then the problems start. This is especially true where the RCA is connected to the amp. Also make sur that the RCA wire is not stressed. It should be resonably tight but there should be some play. A wire that is too taut can snap.
navin is offline
Old 30th April 2008, 10:01   #114
bottle's Avatar
Thanked: 294 Times
navin,
the powerwires are on the left side of the car while rcas are running in the middle of the car between the seats under the carpet
while testing the amp was on back seat and we pulled out HU and ran the rca over the seats so that it would not be influenced by anything. was still getting whine
currently using audison wiring from gunbir and also tried soundstram rca wiring. no difference
the installer said alternator was leaking current since whenever he touched the rca to the metal it would give a screech
bottle is offline
Old 30th April 2008, 10:49   #115
navin's Avatar
which car is this?
can you source another alternator just to check. I have not seen a bad alternator since the late 80s. I figured they had the process down to a science.
navin is offline
Old 30th April 2008, 12:06   #116
headers's Avatar
Thanked: 564 Times
which car is this?
Its a Palio Stile 1.6
headers is offline
Old 30th April 2008, 13:34   #117
DerAlte's Avatar
Thanked: 2,920 Times
... the installer said alternator was leaking current since whenever he touched the rca to the metal it would give a screech
IMHO it looks like the installer is pulling a fast one, and he has no clue of good grounding!
The alternator is what it is - if it is really leaking, it will only be dissipating some of the converted energy in self-heating, leading to insulation failure some day. But that is not the problem at hand. There is always some ripple present in the rectified DC, which is filtered to some extent by the battery.
If the ground connection of the HU and/or the amp is not proper, this ripple appears in the output, since the voltage on the main battery rail is w.r.t. ground. If one can check with an osci, one can see the ripple on the Pow Sup -ive pin of the HU / amp W.R.T. battery -ive and also HU / amp BAT input (Ground Loop). With a good DMM, you could also measure the voltage diff. between HU/amp PS -ive pin and the Battery -ive (or alternator DC output -ive).
Please check ALL ground connections for corrosion - don't pass over any of those assuming that it looks OK. Redo the amp ground connection. Also check how much (DC) voltage is there between outer ring of the RCA connector and the nearest ground.
As far as the RCA "screech" is concerned, even you can make it produce peculiar sounds by catching the connector so that you are touching the signal and ground together (works even better if you lick your fingertip before that). This is the standard way of checking signal cables in PA systems. It only proves that the amp is working, since it is amplifying all noise presented directly at its input!!!
DerAlte is offline
Old 30th April 2008, 17:33   #118
bottle's Avatar
Thanked: 294 Times
which car is this?
Hope its not an alternator fault but will get it checked. Got a new alternator a couple of months ago only after the original one failed :( car is not yet a year old
Yup, Thanks
will get it checked out. could be the installer is mistaken but i dont think so. he did check grounding points for corrosion and scraped the metal around the grounding for the car battery even just in case. didnt work.
regarding the screeching sound i have no idea what it was about but they were going around touching the connectors to different parts of the car body
bottle is offline
Old 2nd May 2008, 20:12   #119
headers's Avatar
Thanked: 564 Times
Bottle..any updates on your ICE and its sounds?
headers is offline
Old 2nd May 2008, 21:27   #120
bottle's Avatar
Thanked: 294 Times
No sir havent gotten around to it yet. as of now reducing the gain/level for rear speakers to 40% has eliminated the whining sound. previously when it was at 50% it was faintly audible and at 60% volume on amp it was annoying. so driving around with this fix.
i usually listen to music front biased , faded to front by 2 so reducing rear levels gives me similar type of sound.
bottle is offline
