Old 9th December 2008, 15:44   #106
nitrous's Avatar
Thanked: 326 Times
Gurus, a question.
How can one run a JBL 607(70W RMS) on a 75.4(142W RMS) and NOT blow it?
The techniques I know of are:
1. Gains at minimum (or about a notch or two from min.)
2. higher HPF - 80 Hz ok? or does it need 100?
nitrous is offline
Old 9th December 2008, 15:51   #107
Thanked: 305 Times
That is not called tuning, which I have hear in few cars. So even when properly tuned with proper slopes and gains setting one can blow there stuff. It depends how you play your setup.
As Panky clearly mentioned he was under the DARU effect which has casued the mishap
low_bass_makker is offline
Old 9th December 2008, 15:59   #108
Thanked: 320 Times
Why not set of 2 components in series to make them 4 ohms, even my 607 feels like going to get blowed with 75.4.
Ajaybiz is offline
Old 9th December 2008, 16:14   #109
panky12345's Avatar
Thanked: 171 Times
Originally Posted by NOTORIOUS View Post
try rainbow slx , they are Rs 9xxx. i have finalized them for my swift after a audition by gunbir ji cheers:
tried.. they were so laid back, that even after setting treble to phull, I could hardly listen to highs! so, no rainbows for me!
I seriously recommend you audition my ride once the comps are finalized and then finalize something for yourself..
panky12345 is offline
Old 9th December 2008, 16:38   #110
zucchero's Avatar
thats strange panky.in my opinion rainbows are not laid back,definately not. rather i found them a little bright.
nice choice notorious.
zucchero is offline
Old 9th December 2008, 17:22   #111
abhinav.gupta88's Avatar
Thanked: 325 Times
I too felt the same panky
Laid Back when compared to JBLs and Illusions.
abhinav.gupta88 is offline
Old 9th December 2008, 17:53   #112
Thanked: 30 Times
Is this the one launched with new tweeters etc if I am not wrong ?
They were for 11 K something.
scarlet.fever is offline
Old 9th December 2008, 18:20   #113
m4ugr8's Avatar
Thanked: 129 Times
The Older SLX did not have any cross-over tunning options, The new one now is called SLX Deluxe which has the cross-over from the higher SAX series. These cost 11k something as correctly pointed out by scarlet.fever. What I had in my swift was the older SLX without any options at the Cross-over.
@Panky: You can try the ID CTX Compos, Heard them recently in my friends CRV and they sound a notch bright than the Rainbow SLX, though i find the SLX perfect, according to your listening prefrences you may like the IDs or else you have the Illusions as the perfect option for you
m4ugr8 is offline
Old 9th December 2008, 18:42   #114
frankmehta's Avatar
Thanked: 3,578 Times
Panky dada Bolo na. Why no illusions??? I think if you found the rainbows laid back and the Jbl bright, the electra is the one for you. Audition them but not on any 'third grade amps' get someone to play them on your 75.4 only. Trust me, they sound great. And you can play the regular chan chan as well as the REAL music and they will deliver the way you want..
frankmehta is offline
Old 9th December 2008, 18:51   #115
panky12345's Avatar
Thanked: 171 Times
Arrey sir, Illusions are a definite in! Was just exploring other options before buying them.
@ m4ugr8: how much does these IDs cost?? They look super -cool with the huge magnets and build quality. I'd love to audition them!
@ notorious: are these the same ones that others are talking about? if so, how come the difference in price?
Old 9th December 2008, 18:55   #116
Thanked: 325 Times
You can audition illusions on 1004 on my ride. Will be quite similar.
Old 9th December 2008, 19:08   #117
panky12345's Avatar
Thanked: 171 Times
yep, thanks abhinav! its indeed a help. faridabad is too far!
Old 9th December 2008, 20:40   #118
frankmehta's Avatar
also audition the new power series of components from JBL. heard quite a bit about them. and let us know about them too panky
Old 9th December 2008, 21:13   #119
smokin's Avatar
Thanked: 15 Times
So sad to hear about your Compos!! May god RIP them.
you can hear the illusions on kenwood 8401 too on my car will be visiting rohini within few days
smokin is offline
Old 9th December 2008, 21:19   #120
Thanked: 325 Times
Smokin, he would never audition them on a kenwood. Right panky?
