▲ Go to Top ▼ Bottom
Old 20th January 2016, 19:29   #106
Thanked: 21,451 Times
Re: DIY Install: LED cabin lights for the Maruti Swift
Swapping to LED's on the Rear registration lights
Simple Process:
  1. Open the boot lid; open the black cover by pulling the plastic clips;
  2. There are 6 of them holding the cover;
  3. Pull the connectors powering the bulbs by pressing down on the tab located on the top;
  4. Hold the bulb holder and rotate it anti-clockwise (12-10 O' clock position) to free them from the boot lid;
  5. Pull out the OEM T10's and replace them with the Osram T10 LED's.
  6. Refit the holder and boot lid cover.
  7. We are Done!
Osram LED T10/W5W
DIY Install: LED cabin lights for the Maruti Swift-1.jpg
The Bulbs
DIY Install: LED cabin lights for the Maruti Swift-2.jpg
Black cover on the boot lid
DIY Install: LED cabin lights for the Maruti Swift-3.jpg
Plastic clip that holds the cover
DIY Install: LED cabin lights for the Maruti Swift-3a.jpg
Connector for the registration plate lights - Remove by pressing the tab on the top
DIY Install: LED cabin lights for the Maruti Swift-4.jpg
Rotate the bulb holder anti-clockwise (12-10 o' clock position) to remove the lights
DIY Install: LED cabin lights for the Maruti Swift-5.jpg
OEM T10 vs Osram T10 LED's
DIY Install: LED cabin lights for the Maruti Swift-6.jpg
Test Shot
DIY Install: LED cabin lights for the Maruti Swift-7.jpg
Before (i.e OEM T10's)
DIY Install: LED cabin lights for the Maruti Swift-8.jpg
After (i.e Osram T10's)
DIY Install: LED cabin lights for the Maruti Swift-9.jpg
a4anurag is offline   (5) Thanks
Old 5th February 2016, 13:16   #107
Thanked: 108 Times
Anuraj,
Attempting to do a DIY for Swift.
Will the following model work ? Worried about the dimensions
http://www.aliexpress.com/item/48-LE...227641741.html
lambuhere1 is offline
Old 5th February 2016, 13:37   #108
Hey, IMO it will not fit in the interior lamp casing. 16 SMD is more than sufficient.
Old 5th February 2016, 14:15   #109
mukeshgoel's Avatar
Thanked: 2,412 Times
Anuraj,
Hi.
I am using something similar in my swift.
http://www.team-bhp.com/forum/diy-do...ml#post3697791
I bought it from ebay @159 (124 + 35 shipping charges).
http://www.ebay.in/itm/271623727959
mukeshgoel is offline   (1) Thanks
Old 5th February 2016, 14:49   #110
Is it fitting in the cabin light casing?
a4anurag is offline
Old 10th February 2016, 13:04   #111
Thanked: 108 Times
Originally Posted by schakravarthy View Post
The front stock cabin light bulbs were replaced with LEDs. A bigger LED was connected in parallel at the rear. The bulb is placed at a discreet location (it's not visible unless you are looking for it).
The light throw at night is amazing, the entire cabin is lit up in a soft bluish-white light; but not jarringly so.
Sirji,
Can you kindly shed the light on how the bigger LED was connected in parallel ? Was it done at authorized service center or was it a DIY ?
How is the light fixed onto the frame ? Dual duct tape ?
Is the light connected to internal dome switch ?
And the model of the light : Is it 24 SMD or 16 SMD ?
Any additional photos of the setup will be really helpful
Old 10th February 2016, 18:09   #112
schakravarthy's Avatar
Thanked: 4,514 Times
'Twas a DIY. I connected it in parallel to the cabin light.
I made a small pin hole in the headliner and passed the wire through it. The tension was enough to hold the light in place.
Yep.
No clue, sir. I bought it at a local accessories shop. Iirc, I had paid around Rs.200/- for it.
I only have more pics of the bulb and illumination; no installation pics.
And, I can't get you more pics either, I sold the car.
schakravarthy is offline
Old 17th September 2016, 13:36   #113
Thanked: 108 Times
A bit OT :
Did anyone do a DIY for installing a BOOT LIGHT in FIRST GEN SWIFT VXI ?
Not sure about th electrical wiring issues, was planning to do something in Dasara holidays. Need to order parts.
Planning it in such a way that when the boot lid is open, the LED light will glow within the boot.
Appreciate your guidance
