Old 11th December 2023, 19:12   #106
VMG
VMG's Avatar
Thanked: 47 Times
Re: DIY: Ford EcoSport LED Headlights upgrade
I would to upgrade headlamp of 2016 ES petrol DCT.
Pl let me know what kind of headlamp ( LED etc) and approx cost details.
VMG is offline
Old 18th December 2023, 11:35   #107
Thanked: 13 Times
I have been using DHC branded 75 watts 4300k LED in my cars.
They are very effective.
I think yours is the dual barrel type with projector for the low beam and reflector in the high beam. So it would be H7/HB3 ( please confirm) for the low beam and H1/H7 for the high beam ( again, please confirm).
The DHC branded 75 watts LED costed me 8500 per pair.
Try to get the 4300k color temperature as it works better in different weather conditions and road types.
You may also try out the 55 watts version .
I suggest you to first upgrade the low beam , upgrade the high beam only if you need it.
Suggested the brand as I have been using it for quite a long time and am happy with its performance, I am in no way related to the brand.
sj@8535 is offline   (1) Thanks
Old 18th December 2023, 12:13   #108
Reinhard's Avatar
Thanked: 18,120 Times
One important thing to note though is - the LED chips always emit white light - the 6000K white.
Any other colours that you see, including 4300K temperature, are actually achieved by adding appropriate tints over the LED chip. This - also means that the actual lumens output of the LED - is lesser than the equivalent white bulb without temperature tint.
Reinhard is offline   (3) Thanks
Old 17th June 2024, 14:01   #109
typlo's Avatar
Thanked: 249 Times
Originally Posted by DrAakash View Post
Bought Osram H7 LEDs off Amazon for 3499, fair price for a set of name brand LEDs, i think. Comes with two additional rubber gaskets(more on that later) and 2 zip-ties.
Really easy to install in the H18 holder of Ecosport, had to make a tiny modification in the bulb holder, it comes off the LEDs and can be secured with the bulb clamp, the actual bulb slides into it and is secured by frictional locking aided by 2 rubber gaskets. As plug and play as it gets.
I haven't aligned the headlights yet so i won't post pics, but the cut off seems as sharp as halogens, if not sharper.
The pic shows the H7 holder on the left, the right one is modified by me to fit the H18 holder. Looks neat to me, and fits like a glove.
Hello, can you please tell me how did you make this modification? If you can mention the exact tool and method to make such a precise cut, it would be helpful for all of us.
typlo is offline   (1) Thanks
Old 24th June 2024, 09:57   #110
Thanked: 123 Times
Hey there! Sorry about the late reply.. I've been tied up with work lately..
So.. You need a Dremel type tool. Handheld rotary grinder, i used the coarsest attachment they had.. It was a cylindrical black stone i think.
Mark the starting point and the depth of the indentation to avoid heartache later.
DrAakash is offline
Old 3rd January 2025, 21:49   #111
Thanked: 62 Times
Hi All, what is the best recommendation for the Ecosport headlights and fogs? I am traveling back from UK and would like to upgrade my Ecosport lights. Jan 2017 model.
shibu is offline
Old 8th April 2025, 00:37   #112
Hi Shibu. I can share my experience with you. I bought the Osram headlamps for High, Low and Fogs. Been using them since November 2021. Had no issues till now. The High and Low beams will have to be adjusted, no doubt. But the throw is great, the cut offs are sharp, and are very reliable. Did not need any modification, and the fan, the choke and the entire cable can be easily packed in the headlamp housing itself. No heating issues till date, and they work fabulous.
AFAIK, H1 is for highs, H7 are Lows, and H8/H11 marking ones are for Fogs. Fogs disperse, so even with low beams, oncoming traffic would feel its on High beam, but man! The way they illuminate the highway. With this setup, I've driven on pitch dark sections of Rajasthan, and the way all these when switched on, illuminate the darkest of the patches! Feels like day, every time.
do_da_doodle is offline   (1) Thanks
Old 12th April 2025, 13:19   #113
Thanked: 62 Times
Thanks, do-da-doodle, did you fit Osram HIDs?
shibu is offline
