Old 13th July 2010, 15:13   #4471
HellwratH's Avatar
Thanked: 57 Times
Well if I am not wrong EF lenses can still be used on EF-S mount so even if some one is selling EF 28-135 it is usable only that it will behave as 50 - 200 Lens on EF-S mount , So yes I agree in this case buying EF-S 55-250 makes more sense if both has same F stops and prices are comparable.
Depends on the effective FL MileCruncher is looking at . Both lenses have different effective FLs and applications. Personally I haven't read/heard rave reviews about 28-135, so I'd stay away. Again, if you can tell us the FL you're looking at, it becomes easier for us to suggest if it's a good buy or not.
HellwratH is offline
Old 13th July 2010, 15:28   #4472
Thanked: 130 Times
I just ordered Canon 18-55 IS for 99 EUR. Now I am looking for the buyer for my Canon 18-55 Non-IS lense, I think I will sell it for 25 EUR.
pawan_pullarwar is offline
Old 13th July 2010, 15:52   #4473
ajman28's Avatar
Thanked: 24 Times
Hello Bhpians,
Just wanted to thank all contributors for making my baby-step into DSLR a lot simpler. This forum was extremely helpful. Just got the Canon EOS 1000D kit (18 - 55mm lens). Mighty thrilled to flaunt an SLR but unfortunately still got to learn how to use the different functions (just realised it is not as simple as the P&S ). I have decided to test the waters before taking a plunge so decided on a small(est) budget
The CANON supplied bag didnt look very nice, infact it looked pretty cheap. I have still not got mine since they said it takes about 20 days after registering on site.
Please suggest on some good protection for the camera and lens.
Also, any suggestion on some good reading material into DSLR & photography?
Rgds,
Aj
ajman28 is offline
Old 13th July 2010, 17:31   #4474
nilanjanray's Avatar
Thanked: 2,946 Times
Originally Posted by NFS2024 View Post
I just loved the first two pics, it has come out beautifully.
Thanks. The elephant picture was taken at Masinagudi (Sigur).
OT: That particular pachyderm has had the honour of kicking my old car and pushing it for a few feet (I was not inside then, thankfully). Next time I need a push start, I might ask for its help.
nilanjanray is offline
Old 14th July 2010, 10:02   #4475
MileCruncher's Avatar
Thanked: 1,379 Times
Over here in India, you might be able to get 2k for the lens.
MileCruncher is offline
Old 14th July 2010, 10:19   #4476
Thanked: 66 Times
Originally Posted by MileCruncher View Post
No saar, I haven't bought a full frame camera. And its a EF-S lens. I went to Chimalgi and he was quoting for 16k for sparingly used EF-S 28-135MM.
Are you sure its EF-S??? I have never heard about a EF-S 28-135mm lens!! Please check again!!
Now which brand are we talking here for a new 55-250 MM. I have a feeling its not Canon.
I thought you were talking about canon lenses!! BTW, EF and EF-S means they are canon lenses!!!
Do you guys thinks 16k is a good price for a used 28-135 Canon lenses?
kkr2k2 is offline
Old 14th July 2010, 10:22   #4477
Yes it is a EF-S lens as it was mounted on a EOS 400D.
Old 14th July 2010, 10:47   #4478
Thanked: 716 Times
Milecruncher as I wrote before lens with EF mount lens can also be mounted on EF-S body so just becuase it was mounted on EOS 400D is not a sure shot way to say it is EF-S and not EF , So please check the lens specification to be sure.
If the lens is EF on EF-S body effective focal length range will change to approx 50 -200 mm.
amitk26 is offline
Old 14th July 2010, 10:53   #4479
tsk1979's Avatar
Thanked: 23,494 Times
Check the dot. If lens aligns with the "red dot" its a EF lens. If it alignes with the white squarish dot, its a EF-S lens.
That said, both EF and EF-S lenses have actual focal length in full frame(35mm) marked.
So 18-55EF-S is actually 18*1.6-55*1.6 lens.
tsk1979 is offline
Old 14th July 2010, 11:12   #4480
lohithrao's Avatar
Thanked: 226 Times
FOlks am planning to upgrade to a DSLR, now the que is which is a good one with which i can stick around for a while.
And which is the best place to pick the cam in Bangalore?
thanks
lohithrao is offline
Old 14th July 2010, 11:13   #4481
sree70's Avatar
Thanked: 15 Times
Freinds, I am intending to buy a good tripod for my
DLR camera - Canon 550D
lenses- kit lens (18-55) & Sigma 70-300APO DG Macro
budget - between 2k-4k.
Please suggest suitable choices.
Thanks in Advance.
sree70 is offline
Old 14th July 2010, 12:05   #4482
HellwratH's Avatar
Thanked: 57 Times
The only exception I have come across so far is the Tokina 11-16. Even though it's an EF-S lens, it has to be aligned with the red dot for mounting on the camera.
Old 14th July 2010, 12:27   #4483
tsk1979's Avatar
Tokina is a crop sensor lens. EF and EF-S norms regarding the alignment to red and white dot is followed by canon lenses.
Infact you can mount crop sensor lenses to full frame bodies(in case of tokina/sigma/tamron) only you will get vignetting at full wide, and you have to zoom to get rid of vignetting.
tsk1979 is offline
Old 14th July 2010, 12:35   #4484
Thanked: 716 Times
Humm and till now I was thinking EF-S some how gives same equivalent focal length by reducing the size , but yes I should have thought the equivalence is in terms of angle of view and focal length is always same so lens mount can not alter laws of optics.
Tanveer by same logic as above your 10-20 Tokina on Crop sensor body should also give effective angle of view which is equivalent to 16 - 34 mm and Tokiana being crop sensor lens just means that the amount of glass is less ( diameter of lens is smaller) and on a Full frame it will cause vignetting.
Or other possibility is that it is actually 6mm at wide end giving effectively ~10mm on 1.6 crop body ?but this looks highly unlikely.
amitk26 is offline
Old 14th July 2010, 18:43   #4485
recshenoy's Avatar
Thanked: 256 Times
thanks
You can get good deal from fotocircle
# G7,8,9, Brigade Plaza, S.C. Road,
Near Anandrao Circle, Bangalore
Tel: 22874356, 22872572
what are your areas of interest? landscape, portrait, nature,birds?
recshenoy is offline
