I have serviced my M 800 5Speed (73,000 on the odo) yesterday and have done the following work. Now the ride is improved and the breaking has improved.
1. Casrol Magnatec - Rs.900 for a 3ltr can, wanted to go for Synthetic , but budget issues
2. Castrol 90 Gear oil - Rs. 390 for 2 ltr
3. Golden Cruiser Coolant - Rs.160 for 1ltr
4. Oil Filter Purolater - Rs 79
5. Air Filter Rs. 120
6. Timing Belt Rs. 275
8. Waterpump Belt Rs. 90
9. Brake Pad - Front KBX - Rs.240
10.STP Engine Flush - Rs 250
11. TVS Brake Fluid - 95 for 500ml
12. Front Wheel oil Seal - Rs 76 for 2
13. Rear Cylinder Assembly KBX - Rs.400
14. Rear Brke shoes set KBX - Rs.330
14. Radiator Top hose with clips -Rs. 94
15. Spark Plug Champion set of 3 - Rs.185 - was hunting for Bosch but couldnt get it.
16. Drive Shaft Boot (1) - Rs.110
17. Cotton Waste - Rs.30
18. AP grease 500gms - Rs.70
Labor:
19. Lathe charges for Drum and disc polish - 300
20. Water Wash - 150
21. Mechanical Labor for replacing the above and other services like Tappet adjustment, Clutch adj, valve clearance etc.:1300
total set to Rs.5,554/-
I did a service around a year back and the brakes were almost worn out so I had to replacemost of the brake stuffs.
Please let me know if the above prices are decent for a normal garage - but the quality of work was good as I stayed both the days with the folks and was watching them work.
Now the next catch is when he adjusted the clutch, he said that clutch is almost done and may last for another 10K kms.
What would be the normal life of a clutch and what could be the cost of replacing the clutch components?
What else may get worn out shortly and may need replacement
Another doubt! one of the other person who came to the garage had an Esteem AC Compressor fitted to it without any mod work.
Am also thinking to hunt for one from the junk yard. The mechanic said he can fit it for me and a good one can be bought for 1.5K
Thanks for your support. |
