Old 10th April 2025, 23:38   #9706
Thanked: 15 Times
Re: Maruti S-Cross : Official Review
Originally Posted by kit_dennis View Post
Sorry, I dont know. If you look at the total bill, the total came to 14.5k including the fan, pipe and labor(it was bit laborious to dismantle). Attached some photos after taking out the parts. Unfortunately I dont have the photos of the new parts.
Yeah it’s same set of things that stopped working in my car and it’s the same motor also. May be I will check with shop where you got it repaired. Thanks.
smrutisourav is offline   (2) Thanks
Old 20th April 2025, 11:47   #9707
Thanked: 372 Times
The S-Cross was based on the SX4 Platform. Now that both models have been discontinued is the platform still in use?
carhead is offline
Old 28th April 2025, 18:23   #9708
Hammer & Anvil's Avatar
Thanked: 1,201 Times
2018 S Cross, 1.3L Diesel, 68000 km. Mumbai based.
Thermostat failed on the highway and by the time we could pull over the car heated and i seem to have blown my piston rings.
The car is consuming oil and blowing smoke on acceleration, at idle ie behaves like a puppy.
My mechanic suggests I sell the car, but i think i should get a fair idea of the engine rebuild. If anyone has done this before or can tell me about this- what this entails and the effort, reward and risk that go with it, I would be obliged.
Hammer & Anvil is offline
Old 28th April 2025, 20:21   #9709
condor's Avatar
Thanked: 16,902 Times
Any non-normal behaviour noticed in recent past ?
condor is offline
Old 1st May 2025, 22:23   #9710
The fault has been raced to a turbo buring oil up. Could rdrive the car about 100km without any drop in oil level but the min you punched up the throttle and the turbo comes online, you get a nice cloud of brown dusty smoke out of the exhaust.
The only 'symptom' seen was the average that was consistently in the 18.5-19.5 kmpl range, has dropped to 13.7-14Kmpl.
Any idea on repair, turbo costs, labour.... salvage parts stores?
My enigne is a D13A, the same that goes into an Ertiga.
TIA.
Old 2nd May 2025, 09:12   #9711
govigov's Avatar
Thanked: 1,222 Times
[quote=Hammer & Anvil;5963931
My mechanic suggests I sell the car, but i think i should get a fair idea of the engine rebuild. If anyone has done this before or can tell me about this- what this entails and the effort, reward and risk that go with it, I would be obliged.[/quote]
TIA.
OK, as far as I remember, the 2018 has the updated thermostat assembly, when you say failure of thermostat, there are two potential failures, one is the assembly failure and coolant pours out of the failed hose connection. The second one is the actual failure of the the thermostat valve itself. Usually, the thermostat valves are designed to fail open, so the coolant will flow, but the car will take longer to warm itself.
Which of these failure did you get? Was there a engine hot light ''ON" in the dash? How long did you drive with that light on?
Secondly, you are talking about turbo consuming oil. This is a more possible scenario. The turbo seals may have gone bad. Unfortunately, turbo repair is not so common and folks usually push for replacement as it is more money and easier to do than a repair. If your routine has turbo getting spooled up before the oil getting warm, then it may have more chance of failure.
Thirdly, your oil has to go somewhere. If it is going via the turbo to the inlet side, and then getting burned, you also need to clean the egr and the inlet manifold, intercooler as all of these components especially, the intercooler will be filled with oil. If the oil is getting burned via the piston rings , the blowby would be extreme. You can check blowby using any of the tutorials in youtube. If the consumption is as you say it is for the fault of piston rings, then expect a huge amount of blowby. Remember, small amount of blowby is ok. Check on a good running engine if in doubt.
govigov is offline   (1) Thanks
Old 9th May 2025, 17:48   #9712
Thanked: 15 Times
Originally Posted by smrutisourav View Post
there are two radiator fans in scross, one of them costs 12k+ and another one is 18k+. Do you remember which one was replaced for you?
Cheaper one is based on winding core and the other one is a magnetic core (this cannot be repaired).
Link of 1st one: https://boodmo.com/catalog/part-1712062m10-31618879/
Link of 2nd one: https://boodmo.com/catalog/part-1712062m00-31618878/
Sx4 diesel's fan motor did not match, but thanks to @researcher found that the pajero sfx is a direct fit but needs a wire cut. Found the part with Parts drive india https://www.instagram.com/partsdriveindia/?hl=en
IMG_5276 2.HEIC
Old 9th May 2025, 22:06   #9713
Mr.Boss's Avatar
Thanked: 7,588 Times
Surprised to see the part for Pajero is still available but not for a low volume Suzuki.
BTW, going by the snap the motor rotation direction is either reversed or the sticker is stuck upside down.
Mr.Boss is offline
Old 9th May 2025, 23:05   #9714
Thanked: 15 Times
Suzuki part is available on order, takes 7 days but costs INR 18k+, whereas Pajero one I got at INR 3400.
Yeah the sticker installed is upside down.
